ThameslinkUser
The services that have no first class are the ones that are booked to have either entirely or partially 3 car operation. It will be to boost capacity and makes sense.This doesn't make sense on any level.
I mean it's no different to Class 700s, except those were procured with the ability to have a special message noting the area is declassified for approximately 10 seconds every 5 minutes...All the rolling stock has first class labelled as such.
If all three car trains are standard only then at least there is some logic. Hopefully they won't be labelled up as first. Given that all Southern trains are 377s or 387s now, I'd be inclined to introduce first on all routes. Some people might upgrade in order to get a seat. Otherwise abolish it entirely.The services that have no first class are the ones that are booked to have either entirely or partially 3 car operation. It will be to boost capacity and makes sense.
As established already, this is the option all parties (seemingly aside from the Treasury) want.Otherwise abolish it entirely.
I'm surprised 1st class has lasted on Southern considering it was axed by South Eastern & London Northwestern services which probably had a similar volume of 1st class season ticket holders or other genuine 1st class passengers (so excluding those who sit in 1st class with a standard class ticket only moving if the OBS pops up checking tickets "oh this is 1st class, I didn't notice")As established already, this is the option all parties (seemingly aside from the Treasury) want.
There isn't much to remove. A few labels and a yellow stripe on the outside. Assuming the extra revenue exceeds the cost of the bits of paper on the headrests, there's no obvious reason to get rid of it.They also had a great opportunity to remove it whilst the 377s were getting refurbished
That's absolutely right. From a guard point of view, all first class being classified based on route really means is that people who sit in first class without the appropriate ticket will simply not get fined for being there, which could happen on other services. In general, unless you know the rules, first class is de facto always in use to passengers, and they won't sit there.This doesn't make sense on any level. All the rolling stock has first class labelled as such. Other services on the same track have first class and there are first class fares available. It's just bizarre.
I will need to point out that there is one route where first class is in operation on class 377/3s, and that is the Redhill to Tonbridge line. It used to be a through service to london, but even when it was cut back to a shuttle, it was retained on the shuttle trains which the 377/3s operate. They would likely need to decide to declassify that route (as they probably should do considering its pointless on a shuttle service of only 30 minutes end-to-end) before they could look at removing first class on those units.If all three car trains are standard only then at least there is some logic. Hopefully they won't be labelled up as first. Given that all Southern trains are 377s or 387s now, I'd be inclined to introduce first on all routes. Some people might upgrade in order to get a seat. Otherwise abolish it entirely.
The key question is whether journeys into Brighton have been improved by the increase in capacity.Although the title of the page is talking about the consultation, I have been wondering, now that the changes are implemented, what does everyone (who travel on any part of the west coastway line) think of the new changes?
You can argue that with the West Coastway line as far west as Angmering, where it has gone from 2 tph to 4 tph. The main negative with improvements however is west, where although there is now a direct service from Littlehampton, and for the whole line as far west as Havant, there's 3 tph. However, the main negative is with the Chichester to Brighton service, where running via Littlehampton is slower than taking a late train (i.e. it leaves Chichester a few minutes earlier than the next service (originating from Southampton), but due to running through Littlehampton, then arrives later, meaning many passengers who know the line well won't use it all the way to Brighton.The key question is whether journeys into Brighton have been improved by the increase in capacity.
The main negative is the increase in journey times from Southampton to anywhere beyond the Arun Valley, but in part that is counteracted by what should be a more consistent and reliable service.However, the main negative is with the Chichester to Brighton service, where running via Littlehampton is slower than taking a late train (i.e. it leaves Chichester a few minutes earlier than the next service (originating from Southampton), but due to running through Littlehampton, then arrives later, meaning many passengers who know the line well won't use it all the way to Brighton.
This shouldn't be that big of an issue though. Journey time was always the sacrifice you made if you were going from Southampton to Victoria or Clapham Junction anyway.The main negative is the increase in journey times from Southampton to anywhere beyond the Arun Valley, but in part that is counteracted by what should be a more consistent and reliable service.
That is the same negative? A 25 minute connection at Barnham or Chichester isn't a great prospect for anyone travelling from East Surrey or North West Sussex beyond Cosham. However, those are the difficult things which the timetable people have to balance and you can understand why Brighton to Portsmouth connections were favoured over the Southampton ones.The other main negative is the removal of direct trains between Southampton and Fareham to Gatwick which have existed for over 30 years.
With Clapham Junction, thats probably not really an issue, because there's a train into London Waterloo that calls there, so I suspect some people going there would probably pay more for SWR if the Southern option will take about twice as long now.This shouldn't be that big of an issue though. Journey time was always the sacrifice you made if you were going from Southampton to Victoria or Clapham Junction anyway.
Quite right, I suppose thats a good idea for Southampton staff to advise to people asking how to get to Gatwick Airport when they see no direct train on the departure board.That is the same negative? A 25 minute connection at Barnham or Chichester isn't a great prospect for anyone travelling from East Surrey or North West Sussex beyond Cosham. However, those are the difficult things which the timetable people have to balance and you can understand why Brighton to Portsmouth connections were favoured over the Southampton ones.
(In practice, most people will, I expect, reduce the wait time by catching the stopping portion on the Arun Valley.)
Why doesn't East Surrey count? The Southampton to Victoria train called at Gatwick Airport which isn't much more than a stones throw from East Surrey.Quite right, I suppose thats a good idea for Southampton staff to advise to people asking how to get to Gatwick Airport when they see no direct train on the departure board.
(by the way though East Surrey doesn't really count, because the former Southampton to Victoria service didn't have any stops in Surrey)
Indeed, this linked thread, post #696 has a 3rd June shot of a 387 on that working.Southern rubbing salt in the wound by using Gatwick Express stock on Southampton to Brighton services.
Is Brighton to Southampton now exclusively Class 387?Indeed, this linked thread, post #696 has a 3rd June shot of a 387 on that working.
June 2024 Timetable Change
1N02 (05:14 Brighton-Southampton) was a Gatwick Express (387 203) this morning - it passed me as I walked the dog. The return service was, annoyingly, cancelled - so no photo. Tomorrow, I'll discover whether the new timetable has a 387 booked for that working, or whether today's appearance was a...www.railforums.co.uk
No.Is Brighton to Southampton now exclusively Class 387?
This morning at Havant I heard the announcer say to change at Barnham for services to Gatwick Airport, for the 0800 service, which I’ve not heard until then . At least why are taking some criticisms into account. Yet still is a bit misleading to put GX trains on services which don’t even go to Gatwick.Southern rubbing salt in the wound by using Gatwick Express stock on Southampton to Brighton services.
It's a slight improvement on the last timetable which had GX trains passing through Gatwick non-stop. Thankfully that's now been sorted.Yet still is a bit misleading to put GX trains on services which don’t even go to Gatwick.
I'm not absolutely certain about that, because there is the single London Bridge to Littlehampton service which doesn't stop at Gatwick, and I think I saw that being operated by Class 387s at some point, so are you sure that they have now been organised in such a way where Class 387s will not be allocated to the service under any circumstances?It's a slight improvement on the last timetable which had GX trains passing through Gatwick non-stop. Thankfully that's now been sorted.
It's been 377s since last weeks timetable change, at least every day I've travelled on it. Obviously it could still be 387s in the event of a late notice stock swap, but this would seem fairly unlikely given some 377s turned up on a Gatwick Express diagram earlier this week.I'm not absolutely certain about that, because there is the single London Bridge to Littlehampton service which doesn't stop at Gatwick, and I think I saw that being operated by Class 387s at some point, so are you sure that they have now been organised in such a way where Class 387s will not be allocated to the service under any circumstances?
To be fair, given the number of trains Southern (likely on the orders of the DfT) has scrapped without replacement (in the form of a new or cascaded fleet of a comparable amount), both Southern, and GX for that matter, probably need to use each others fleets more than ever going forward, at least until passengers number go up enough that some new trains could be ordered, which probably wont be for years at this rate, unless labour somehow manages railways better when they inevitably get into power next month.It's been 377s since last weeks timetable change, at least every day I've travelled on it. Obviously it could still be 387s in the event of a late notice stock swap, but this would seem fairly unlikely given some 377s turned up on a Gatwick Express diagram earlier this week.
The continued refinement of the timetable to get the most out of the existing rolling stock shows that incremental changes can still deliver a capacity boost.The chance of any new rolling stock being ordered in the near future is basically 0.
No. Likely 4 387s and 4 377sIs Brighton to Southampton now exclusively Class 387?
Thanks, I just remember in some paper (probably somewhere in this forum) it was mentioned that southern was planning to allocate class 387s to Brighton to Southampton services. Must have been a longer term aspiration or something along those lines i reckon.No. Likely 4 387s and 4 377s
