Speedometer
finlaywilson2
18 Sep 2023
manchester
Can anyone recommend a good and accurate rail speedometer?
Having just travelled on the Eurostar, mine failed to work but I plan to use one for my tgv ride this afternoon.
skyhigh
14 Sep 2014
If you're referring to an app they all rely on the same GPS signal and one will be as accurate as another. If your phone has no GPS signal no app will work.
Peter Mugridge
8 Apr 2010
Epsom
None of them will work on the 374s as the windows have teh same coating as the Voyagers do.
They will work on the 373s and on TGVs - the windows on those allow GPS signals through ( caveat - I haven't yet been on the newest generation of TGVs so cannot vouch for the windows on those ).
Cymroglan
2 Jul 2011
Apologies for piggy backing on this thread, but I haven’t actually got a speedometer app. Can anyone recommend a good one for me, please? I’m an iPhone user! Thanks.
43096
23 Nov 2015
I've used GPSSpeed HD for iPhone.
Peter Mugridge
8 Apr 2010
Epsom
If you don't want your phone battery draining too quickly, you could always buy a sports GPS unit?
The one I use is intended for cyclists; it does as a result unfortunately have the Dalek exterminator like circular mount on it, but it's only an inch long so isn't too much of an issue. battery is good for up to 18 hours, and can be charged while in use.
Cymroglan
2 Jul 2011
That’s a really great suggestion. Thanks!
Peter Mugridge
8 Apr 2010
Epsom
Couldn't remember the make and model earlier while I was at work. Now I'm at home I can fill in the gaps from earlier!
If it helps...
It's a Lezyne Mega C and this is what it looks like; I use it set to a page that shows both current speed and distance travelled:
Cymroglan
2 Jul 2011
If it helps...
That’s really helpful, I appreciate your kindness, thanks!
Willie Bee
26 Aug 2018
Whitley Bay
I have an Android phone and downloaded a free speedometer app.
However, I have a backup iPhone (wife's hand-me-down) so I thought I would take a look at the app you suggested.
This app is £2.99, which is fine but I am just wondering why you picked it, when there are so many free ones available .. are there extra features that are worth having?
thanks!
43096
23 Nov 2015
thanks!
It has the facility to record a journey and then extract it as a CSV data file was the main reason.
Willie Bee
26 Aug 2018
Whitley Bay
OK, many thanks
As I don't even know what a CSV data file is .. I doubt I'll be using that feature ... but I'll check it out anyway, in case I do :D
43096
23 Nov 2015
OK, many thanks
CSV is Comma Separated Values; basically a data format where the columns are separated by commas and which allows import into almost every spreadsheet or database system.
