Splitting the Northern line
AlbertBeale
16 Jun 2019
21 minutes each way makes up to 42 minutes running time, plus a couple of minutes to turn round at Morden. With a train every 12 minutes this is too tight for three trains, even allowing for the fact that the current service has a small stand in the loop plus running time round there.
Thanks again.
CarrotPie
18 Mar 2021
̶F̶i̶n̶l̶a̶n̶d̶ Northern Sweden
That’s four extra trains. In theory that could be provided from the four trains which stable in Highgate between the peaks, but in practice this is going to represent quite a performance risk.
However I think even this change would require two extra trains in service. It was this saving of two trains that allows Battersea to be covered.
There are insufficient trains to do anything more without compromising maintenance time between the peaks.
What's the chance of the Northern line getting more trains before the 95TS needs replacing?
Sad Sprinter
5 Jun 2017
Way on down South London town
It isn’t the case that all off-peak trains go to Battersea. Only half the service does - those from Edgware still reverse via the loop, and I don’t think there are any immediate plans for this to change.
It isn’t the case that the Bank trains take up all paths to Morden, as every 3 minutes is only 20tph. In theory I’m sure it would be possible to fit in an extra 5tph to/from Morden, which would be half the loop trains. However with running time of 21 minutes to Morden you are talking about a minimum of 45 minutes extra time. That’s four extra trains. In theory that could be provided from the four trains which stable in Highgate between the peaks, but in practice this is going to represent quite a performance risk. It’s also likely this would require stepping back at Morden right through the day.
I guess a compromise might be to provide a CX service on Saturdays. However would that many people bother to wait potentially 12 minutes for a CX train, when there are excellent cross-platform interchanges available towards the west end at both Stockwell and Kennington? Is it worth making the Bank service less even?
Worth also mentioning that the current crewing situation, since Covid, is such that delivering the current service is essentially impossible on a daily basis without multiple cancellations, and has been so for some time. So no realistic prospect of any extra mileage on that score in the shorter term.
If I was going to make a change to the Northern Line it would be to go back to having Mill Hill East served by a shuttle train. The random 6-minute gaps to High Barnet are a pain (it actually represents a 12-minute gap to/from Barnet south of Camden Town), and Mill Hill also suffers in the form of getting an erratic service during disruption. However I think even this change would require two extra trains in service. It was this saving of two trains that allows Battersea to be covered.
Thanks, so it seems like more trains are (partly) the answer. What if CX trains turned around at Tooting Broadway instead?
Pretty much zero. Plans can change of course, but with the 95 stock now being past half life (assuming 40 years) it just wouldn’t be worthwhile buying either extra trains to form a mixed fleet, or 95 stock clones. The latter probably wouldn’t be a viable option anyway.
The only remote possibility is if the Jubilee fleet were to be replaced, it might be relatively easy to convert some of those to run on the Northern. However there is enough difficulty replacing the 50-year-old Bakerloo trains, as well as the ongoing debacle with the 92 stock, so the prospect of anything happening on the Jubilee is as remote as ever. Extra trains for the Northern would also require extra stabling space, though there is a bit of spare land at both Highgate and Edgware, and potentially subject to some minor work three trains could be stabled at Golders Green in the sidings south of the station, and there are three siding unused roads at High Barnet. Space for 10-12 trains should be fairly easy to provide. Beyond that will require more significant work - and it won’t have helped that Khan is busy trying to use car parks for housing schemes, as that’s more space gone!
Not ideal. As in addition to going from 20tph to 25tph, you’d be introducing the problem of trains having to detrain at Tooting Broadway, and the siding berth there is so tight that the entry is very slow. Even if it were theoretically possible to timetable this, it would be introducing a significant performance bottleneck, which might well ultimately pull down the entire line. Also worth adding that by not reaching Morden, the extra trains would be of direct benefit to fewer people, which further reduces any case for them.
Another problem with making regular use of Tooting Broadway is that there are no facilities for drivers there. This isn’t ideal in itself, and would likely attract some resistance from the unions - and probably reasonably so.
Sad Sprinter
5 Jun 2017
Ironically it was the partial reasoning for the Bushey Heath extension to provide more stabling capacity
NSE
3 Mar 2010
Whilst there will be demand to run trains from Morden via Charing Cross, in my experience, the vast majority clear out at Stockwell for the Victoria Line. If I board at Balham/Clapham and I’m heading north, 100% guaranteed to get a seat after Stockwell. With that and the cross platform at Kennington, yes, Morden trains would be nice direct via CHX all day, but it’s really not a show stopper.
Worth noting this is London. There will always be demand from somewhere to someplace, but that doesn’t mean it deserves a direct service all day.
Mikey C
11 Feb 2013
Pointless splitting the lines until you have extra trains available to run an increased frequency on each branch, which is the main driver for this.
Otherwise you end up with the farcical situation many Southeastern passengers have where to increase capacity the "untangling" of the lines into London Bridge meant that many lost the choice of Cannon Street or Charing Cross as a final destination, except that they never actually gained the benefit of more frequent trains. Indeed many now have lower frequencies than before.
Irascible
21 Apr 2020
Dyfneint
Frankly, I doubt people choose homes and job based on not having to change tube lines
I've certainly picked somewhere to live in London that offered an uncomplicated journey to work as one of it's primary features ( especially after having the nightmare of three changes to just get to work for a while ), but I was always renting there. Changing multiple times can add a surprising amount to a commute - it's not enough to really care about if you're going somewhere just to go shopping or look around, but doing it every day can wear you down a bit.
This plan always seemed to me to be there so Camden station could be redeveloped, rather than the other way round.
There are two separate issues in respect of Camden, both essentially unrelated.
Firstly, were the line to be split then there would need to be additional provision for interchange at Camden Town, like was done at Kennington in preparation for Battersea opening. Camden is a more difficult prospect in this respect as the platforms are further apart, and there’s some additional complications such as the former lift shafts, and the deep shelter. So not a straightforward piece of work.
Then you have the completely separate issue that the station struggles to cope with crowds at certain times, especially weekends. Why on earth hoards of people want to visit Camden Town is a mystery to me, as the place is a total and utter dump, but there we go. Indeed the immediate vicinity of the station looks increasingly hurrendous at the best of times, with copious quantities of rubbish, broken glass, needles, rough sleepers, aggressive beggars and blatant wronguns hanging around. It’s the sort of the place where if I had guests from abroad I’d be ashamed to take them. To be honest, if there’s a finite amount of money to spend on improving a station, I’d suggest there’s other places where the money would be far better spent, not least Holborn.
