Further times now on travelinsw. Selection below (not all as there are some other Barnstaple, Torbay and Plymouth ones):
21 and 21A combine to run every 20 mins from Barnstaple to Northam with 2 an hour continuing to Westward Ho! and one an hour to Appledore, so Appledore loses one bus an hour and frequency cut from every 15 to 20 on the core route.
New 21B replacing the 21 and running every 30 mins Barnstaple Rail Station to Ilfracombe
21C back to hourly winter timetable
155 minor changes except Mill on the Mole extension reduced to 2 hourly. This is to allow for the change to the 346 which now leaves South Molton 10 mins earlier and so there isn't time for the Mill extension as the driver changes from the 155 to the 346.
157 can't see much change
24 to Taunton sped up by 5-7 minutes which was needed as it gets far too much running time
301 minor running time adjustments
360 first journey from Exeter runs later and so it now returns from Bridford and Christow at/after 0930 which will work better from pensioners
4 extended to Uni (Mon to Sat only) and increased in the evening to every 30 mins Mon-Sat. Stopping both sides of the road in both directions outside Exeter College will cause much confusion I suspect.
4A appears unchanged
44/44a minor running time changes
6 minor timing changes
6A major cut of 3 buses a day so only 4 on Saturday now. I guess the trial extra services failed due to the much faster train unsurprisingly
6B once a day Tavistock-Okehampton down the main road not via Lydford
B increased to every 20 mins Mon-Fri
I/J increased to every 20 mins Mon-Fri and diversion to serve Digby and Sown station dropped
K hourly Cowley Bridge (West Garth Road) - High Street - Pennsylvania hourly and no evenings or Sundays. Covers existing F to town and existing P route town to Pennsylvania
So to confirm, there are no further Exwick buses and service to those 3 stops will be lost.
