Star Bridge down section signal
Colin1501
10 Apr 2019
Bit of a longshot this, but does anyone remember - or have a picture of - the down section signal at Star Bridge box, between Coulsdon South and Merstham?. I know it was a two-aspect colour-light at the northern entrance to Merstham tunnel. However, I have a distant recollection (1970s) of seeing it from a northbound train, and I'm sure the signal head was unusual. As I recall, the two lenses were quite a long way apart vertically, almost like the four-aspect 'searchlight' signals that were common on the Eastern Region.
It's such a long time ago that my memory may be playing tricks, but I'd be grateful if anyone can confirm, or else put me right!
big all
23 Sep 2018
redhill
You may get on better calling it Star Lane :D
Can't remember it having other than a normal 2 aspect, maybe a 3 aspect with plated over central aspect but cant remember it being much different or unusual other than being combined and on top of a location case I think?
Colin1501
10 Apr 2019
Thanks for this - very helpful. But on the name, I do mean Star Bridge. Star lane box was on the parallel Quarry line.
30907
Southern Railway Signalling society has the signal box diagram but its low res but does appear to show a colour light on the approach to Merstham Tnl
https://www.s-r-s.org.uk/html/src/R1971.htm
I don't think the symbol you presumably refer to - a circle "attached" to the track - is a signal at all. A treadle? The diagram for Merstham appears to show the down distant within the tunnel itself.
However, the diagrams are dated 1950 and 1953, so arent necessarily relevant for the 70s.
Gloster
4 Sep 2020
Up the creek
The very last item shown on the Down line on the right-hand side of the diagram (beyond the bridge) - a small circle connected to the track by a short line - is, according to other SRS diagrams, a treadle. Unfortunately, I can’t go back in time to my signalling training course at Beckenham Junction, where there were lads from both Star Bridge and Star Lane.
30907
Star Bridge down IBS home shown on the link below
Thanks - hadn't thought to look there!
It's the box section signal (or starter in old money) and clearly 2-aspect as the OP describes.
It doesn't answer their question though - I wonder whether it was a 3-aspect head with the yellow blanked off, in anticipation of it taking over the role of Merstham down distant? Or would that not have been the procedure - these days I am sure the signal head would have been replaced? Just speculation, I am not a S&T engineer!
36270k
7 Jan 2015
Trimley
A cab view video from the 1970's/early 80's in the down direction will give the answer if it exists on u tube.
Comparing the two diagrams, the Section Signal in circa 1950 (lever 3) has become an IB signal with the same lever number, and the Home (? - lever 2) has become a 3 aspect colour light. This means that with a train in section beyond the overlap of signal 3, a following train can approach with signal 1 showing green and only brake on sighting signal 2 at yellow. Previously it would have to be cautioned at Signal 1 then brought nearly to a stand at Signal 2 before being allowed forward to Signal 3. So this is a minor increase in capacity.
I'm not sure when this section was fully re-signalled but it can't have been much after 1983 (and a search indicates Three Bridges power box opened that year). It seems to me quite possible that either the above change, or the replacement of Signal 3 by a three-aspect head with the yellow blanked out, was part of the stageworks for the full MAS scheme.
Gloster
4 Sep 2020
Up the creek
Star Bridge closed on 26 February 1983 according to the Signalling Record Society’s Signal Box Register, Volume 4.
