Station rationalisation - those where a platform or two could easily be removed
BeijingDave
26 Jul 2019
This thread may have been done before, but not for a while.
Stabling aside, which stations could easily lose a platform or two without negatively impacting services?
Penrith is an obvious one (is platform 3 even booked for anything?) and so is Stirling (9 platforms, and the morning starters from little used platforms could easily be shifted to other platforms).
D6975
26 Nov 2009
Bristol
Penrith P3 is used mostly for freights to be overtaken. The apparent surfeit of platforms at Stirling are used for stabling units.
Purple Train
16 Jul 2022
Despond
Lincoln Central could lose at least one of the east-facing bays (if they haven't been removed already).
The exile
31 Mar 2010
Somerset
I think history has taught us that, unless there is an extremely pressing need (and that doesn’t include housing, retail or car parking), the answer should be “none”.
Trainguy34
29 Apr 2023
Kent
Margate P2 Doesn't get any service, the services from P1 could be moved over so that there isn't just a strip of land in the middle of a station, it would be on the outside!
devon_belle
21 Jul 2022
Most fast line platforms on quadruple track lines could be removed with the only impact being during engineering works or infrastructure problems on the slows.
Removing them isnt free. So unless the long term maintenance costs are outweighing the capital costs, or they are unsafe etc... no one is going to do much.
steamybrian
26 Nov 2010
Kent
Norwood Junction platform 7- When was it last used? Any trains booked to use it ?
Norwood Junction platform 6- Is this regularly used?
Christmas
10 Mar 2018
Stirling needs all of its available platforms as they are all used daily. Stirling is an operational depot, not just a station. Trains are stabled in all of the buffered platforms. Where would you suggest they put the trains at night when there are still services that need to get to and from Alloa? Where will they be cleaned and serviced when the through platforms are still in use? Just because you think that there is an over provision of platforms doesn't make it true.
PGAT
13 Apr 2022
Selhurst
Platform 7 is isolated and unelectrified. Platform 6 is regularly used by Victoria - West Croydon services because an Overground train is booked to overtake it
Western 52
19 Jun 2020
Burry Port
The west facing bay platform 5 at Cardiff which was filled in 50 years ago would be very useful now
Very true! It's a capacity reduction lesson from the past. If we want growth in the industry, we need to retain platforms unless removal is essential for some reason.
Brush 4
25 Nov 2018
Indeed, the title of this thread is oddly negative, a common trait on here. So, lets reverse this.
From memory, platforms that have or are being reinstated.
Swindon down, Taunton middle, Newquay, Axminster, Hartlepool, Sunderland, Barry Island?. More I'm sure.
steamybrian
26 Nov 2010
Kent
Many heritage railways have reopened lines to NR stations which BR had abandoned platforms such as Keighley & Worth Valley (Keighley), North York Moors (Grosmont), Spa Valley Railway (Eridge) and Dean Forest (Lydney)
Princes Risborough (down platform) was reopened for NR services and subsequently the down bay was rebuilt for Chinnor & PR services.
Clapham Junction platform 2 (plus additional new platform1 ) was reopened for new WLL services also Kensington Olympia a new southbound platform (adjacent to old one).
Many stations have been reopened at minimal cost because the platforms were left in situ after closure with prime examples being the Settle- Carlisle stations closed in 1970.
D6975
26 Nov 2009
Bristol
Bristol 13/15. 13 used to be parcels only while 15 was the depot access line and the track didn't even line up with the platform in places. And don't forget Waterloo, the Eurostar platforms were OOU for quite a while before being reinstated for SWT use.
The exile
31 Mar 2010
Somerset
Newport 4 (and effectively 1 - it was always there but spent a long time effectively unused, I think - or have I got the numbering the wrong way round.) Lots of the eastern end bays at Edinburgh Waverley. Time was when there was only the short bay platform 2 for the North Berwick trains.
It doesn't seem to have been disastrous to Euston's operation to remove 17 and 18, though it has already happened.
They were removed to enable HS2, not because they were redundant. Performance will have dipped, but to a manageable extent.
Taunton P1 (the west-facing bay) gets no real use, and even P6 (the east facing bay) can only be accessed through a reversing move outside the station, so is only used a handful of times; most terminating services from the east thus use P2 or P3. I suspect P6 will be even more redundant if the proposed reopening of Wellington and Cullompton leads to more terminating trains being extended to at least Exeter.
One of the North Kent specials called in that platform last year, where another Ramsgate train was scheduled to pass (not sure why it was necessary), but other than that yes it's rarely used.
