Steepest gradient for a station?
TukayAway
29 Nov 2010
Luton
I've tried searching for this but have sort of come up short. The best I could find is that trains aren't allowed to be split/coupled on anything more than 1 in 500 and new stations should be on the level, although reopened stations do get some leeway.
Off the top of my head, the North end of Farringdon slips away greatly, and the northbound platform at Kings Cross coming from Moorgate must have been steep. It makes sense that they'd all be fairly level at least to help the trains depart but there must have been some exceptions surely?
3 Dec 2008
Huyton
Beddgelert on the WHR is 1 in 40 and is afaik the steepest in the country.
We're allowed to split/join there too.
Not sure about mainline though sorry
Cherry_Picker
18 Apr 2011
Old Hill is probably 1 in 40.
The whole of Old Hill Bank is bloody steep. Towards the top of it is Rowley Regis station and the platforms there noticeably curve up like a miniature skip jump.
Joseph_Locke
14 Apr 2012
The NR standards go pretty much as follows:
If you can, not steeper than 1 in 500.
(an older rule of thumb was 1 in 250).
If no terminating or reversing, you can go steeper than 1 in 500, but you need to consider "alternative means of ensuring safety" - this can range from requiring the driver to stay in the train to sand drags interlocked with the platform starting signal, etc.
Up to 1 in 100 or so you can normally justify the design based on the cost of making it flatter - however on HSTSI lines the limit is 1 in 400 (however section 4.2 of GI/GN 7616 (available at rgsonline) is as clear as mud.
The other consideration is train performance - there's no point saving money by "getting away with" 1 in 60 if the service is operated by class 150s - they'd never move off fully laden (well, you know what I mean) or, if it's in a leafy tree-lined cutting, the trains may never stop, in leaf fall season ...
Against all this, the probability of a runaway (based on historic data) by a stationary train from a platform in service is about zero, so it is all a bit cautious!
hairyhandedfool
14 Apr 2008
It's uphill both ways out of City Thameslink, with the southern end of the platforms (down by the lifts) probably not that different to the average gradient to Blackfriars.
The relaxation in the rules on gradients in stations was probably a result of RSSB project T815. The report (downloadable via the link below) includes a list of stations on severe gradients and concludes that there isn't a safety issue with exceeding the previous limits.
This research was required to inform the Infrastructure Standards Committee on the continuing need for a requirement for platforms to be located on track with an average gradient not steeper than 1 in 500. As part of meeting capacity improvements across the railway network new stations are being built and platforms are being added to existing stations. In many cases the locations of these platforms are constrained and have to be accommodated on existing track with existing vertical alignment. The research concluded that this measure is no longer required and that there could be benefits in terms of more flexibility as to the location of stations and cost reductions for platform improvement schemes. A proportion of the estimated £50m to £70m of investment per year could be saved by this research. The research was carried out on behalf of the Infrastructure Standards Committee and involved a desk top exercise using rolling stock, station and operational expertise together with reference documents. It may lead to changes in Railway Group Standards in due course.
http://www.rssb.co.uk/RESEARCH/Lists/DispForm_Custom.aspx?ID=499
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Isn't Glasgow Queen Street a particularly busy terminus at the bottom of a bank, with gradients of 1 in 44 coming out of the tunnel and still at least 1 in 100 on the platforms?
There have been incidents.
61653 HTAFC
18 Dec 2012
Liverpool Lime Street is similar, and there's been incidents there too (including one that killed a 142!).
Also Bradford Interchange, but in all these cases the platforms are level (or at least the end nearest the stops is). The historic concern was always that if there was a station on an incline the train might roll away if the crew left without securing it properly.
matchmaker
8 Mar 2009
Central Scotland
Worst incident was 1928. 3 killed.
http://www.railwaysarchive.co.uk/docsummary.php?docID=1911
Ministry of Transport Report said:
"The first (Edinburgh) portion of the 9.45 p.m. express passenger train, Glasgow to Edinburgh and London, had just left Queen Street Station when a collision occurred between the rear end of this train and the engine of an empty carriage train which was being shunted from a siding into a platform line at the station. I regret to state that one passenger was killed, two more sustained severe injuries, and died in hospital; and 52 suffered from injuries and shock, of whom 15 had to be detained in hospital."
You wouldn't know nowadays about the operational difficulties Cowlairs Incline used to cause, as modern Sprinter class DMU's tackle it with little difficulty.
steamybrian
26 Nov 2010
Kent
Part of the platforms of City Thameslink are on the 1 in 29 to Blackfriars.
matchmaker
8 Mar 2009
Central Scotland
Look at any station on the Glasgow Subway. They are on a "hump". Gradients of 1 in 20 approaching and leaving each station! The tunnels under the Clyde are 1 in 18.
Any adhesion worked advance on that?
transmanche
27 Feb 2011
Quite a few tube stations are built on steep humps - and the DLR has some very steep climbs.
But Wikipedia suggests that the narrow-gauge Pöstlingbergbahn in Austria has an 11.6% (or 1:8.62) section.
Ploughman
15 Jan 2010
Near where the 3 ridings meet
According to the gradient plot Goathland on the NYMR is 1 in 138 through the platforms.
This comes after the climb up the 1 in 49. Before continuing South at 1 in 90
Shuttles do split and run round but only after moving into the loop to do so.
Normal running entails downhill trains passing over a turnout that would lead into a sand drag.
Xenophon PCDGS
17 Apr 2011
On the Middleton Junction station to Oldham Wernerth station link line between the original Manchester and Leeds Railway and the Oldham Loop Line, there was a very steep upwards gradient of 1 mile 383 yards, of which over one mile was at the ruling gradient of 1 : 27, which was said to be the steepest locomotive hauled incline in Britain.
