Storm Doris Thursday 23rd - Major disruption on some routes
gavin
25 Dec 2006
The met office have named Storm Doris for Thursday currently, the worst affected areas are expected to be the East Midlands, East of England, North West England, Wales, West Midlands, Yorkshire & Humber where winds could hit 80mph for a short time
The exact track of the storm isn't final yet as such the exact areas which will be worst affected is still subject to change
With high wind speeds, disruption to rail services is entirely possible from fallen trees etc
If you are planning on traveling on Thursday you would be advised to check the forecast and be prepared for last minute changes
The current estimate for the worst of the winds is in the amber warning below
Trackman
28 Feb 2013
Lewisham
Thanks for the heads up, I don't usually take notice of storm warnings from the met office in my area (alerts from my phone) but I'm travelling on Thursday to Manchester (eek!). fingers crossed etc.
Wivenswold
24 Jul 2012
Essex
I should add some caution on this storm, the track and development will not be known for sure until tomorrow evening at the earliest. The Met Office weather warnings are fairly general at the moment.
You'll probably start hearing the phrase "Weather Bomb" which is a media name they made up to make a winter storm sound more severe than it is. It's an extrapolation of a meteorological phrase used when an area of low pressure intensifies quickly and the pressure is said to "bomb". It's nothing new.
Where the process of "bombing" or "Explosive Cyclogenesis" (to use the scientific term) occurs is crucial in deciding how bad it will be. If it happens over the UK, then there will indeed be a narrow band of very high winds (gusts maybe to 70mph). If it delays and happens over the North Sea then everyone will be on here asking what the fuss was about.
It's one to watch, especially if you're planning to travel between the peak hours on Thursday but it could also turn out to be nothing out of the ordinary.
Blindtraveler
28 Feb 2011
I awoke today to a pile of notifications from Accuweather's brilliant app about this. I am London bound via WCML and should VT lift ticket restrictions shall take advantage so as to build in delay time.
londonmidland
22 Dec 2009
Leicester
Just an advanced warning of possible disruption due to a developing area of low pressure is expected to move across the UK on Thursday.
High winds and strong gusts are the main concern at the moment. Midlands Northwards seem to be in the firing line.
Some of the charts which are appearing now, showing the wind speeds in km/h
Wivenswold
24 Jul 2012
Essex
Going on the models as they are playing out at the moment and each run of them will produce slightly different results, I'd suggest OHL problems around Merseyside, Crewe, Grantham, Peterborough and later in the afternoon, Diss.
theironroad
21 Nov 2014
As the last storm that the media predicted would be called Doris (from. The a-z American style list which I guess the UK will abandon soon..) never materialised, then expect a light breeze and weather associated with a northern hemisphere winter (it's mid February btw).
A bit of wind doesn't need to become a Disney drama.
Shaw S Hunter
21 Apr 2016
Over The Hill
Given that already now, in the early hours of Wednesday, the wind is already picking up here in South Lancashire I rather think this storm is for real. The weather forecasts earlier showed clearly that there are no fewer than three fronts associated with this system so expect plenty of rain.
Wivenswold
24 Jul 2012
Essex
There's no evidence that the Met Office will abandon the naming system as it's been considered a success in raising awareness.
There was such a tabloid-style fuss made about the 1987 storm which was actually forecast, wasn't a hurricane but did, admittedly, change course unexpectedly and hit the UK instead of France pushing the strongest winds further north. So now the Met Office will always err on the side of caution. There's nothing to suggest this is being overplayed at the moment.
Unfortunately much of the fact is drowned out by hyperbole in the press, a slightly worse than normal depression becomes a "Hurricane", a few chilly days will be called a "Killer Freeze". Sadly, people believe what they read in newspapers and then blame the Met Office.
Groningen
14 Jan 2015
Ha, ha, ha; the Netherlands tomorrow! Windforce 11 and speeds at the coast around the 150 kilometers an hour!
Schermafbeelding+2017-02-22+om+08.06.13
Even down South it's more than a little windy at the minute. Nothing that's going to bring the wires down, but it's early days.
rg177
International Transport
22 Dec 2013
Newcastle-upon-Tyne
I'm having a little rail trip this next couple of days staying in Chester, and I've just scrapped the idea of going to North Wales tomorrow and instead I'm heading towards Hereford then probably across towards Birmingham in the hope that I won't encounter as much disruption...
Sent from my SM-A310F using Tapatalk
Saint66
15 Dec 2013
Herts
Still lots of uncertainty about the track, even this close. However, the METO have been quite bullish with the use of the word damaging so far over quite a large and populated area of the country, so certainly an interesting 36 hours ahead.
cuccir
18 Nov 2009
Snow warning has now also been upgraded to amber in central and southern Scotland. The Met Office is quite blunt on this one (my emphasis):
Heavy snow is expected on Thursday. Accumulations of 10 to 15 cm are likely quite widely with 20 to 30 cm falling on hills above 300 metres. This will lead to disruption to transport and perhaps power supplies.
PHILIPE
14 Nov 2011
Caerphilly
ATW preparing for Doris. Extract from special Journey Check announcement:-
Expected disruption caused by Storm Doris
QUOTE
[High winds are expected to affect many parts of Wales during Thursday 23rd February 2017 brought in by Storm Doris. As a result, for safety reasons trains will have to run at reduced speed on the following routes:
Holyhead - Llandudno Junction (Via Bangor)
Aberystwyth - Caersws (Via Machynlleth)
Pwllheli ? Machynlleth
Fishguard Harbour / Milford Haven / Pembroke Dock - Llanelli (Via Carmarthen]
As a result of these speed restrictions, services on these routes may be subject to delay and short notice alteration.
We also ask that customers take extra care while making journeys]
al78
7 Jan 2013
*sign* there's always one. :roll:
It is not being treated as a Disney drama, it is a case of warning of possible transport disruption, power failures and property damage. 80 mph gusts are capable of knocking down trees and taking bits off buildings, which then become airbourne debris. An 80 mph gust in the centre of Manchester, if it really got that strong at street level (i.e. not at the tops of buildings), would be about a 1 in 200 year return level, so a long way from being normal weather conditions.
96tommy
18 May 2010
Travelling from London to York tomorrow evening so hopefully the wires on the ECML stay up.
marks87
23 Jun 2010
Dundee
The important phrase in there is "media predicted". At no point was a storm officially named.
The naming system will stay. It's effective at increasing awareness because it gives a single point of reference for all interested parties (the public, Met Office, Government, local authorities, transport companies etc.).
duffield
31 Jul 2013
East Midlands
Maybe a bit foolish, but I'm deliberately planning to do Leeds->Armathwaite and back tomorrow, right in the middle of the predicted storm. Hoping for some fairly spectacular blizzards etc. (but not quite spectacular enough to stop the trains :D:D).
4 Jan 2011
Nelson
I'll be on the line tomorrow aswell. If you can actually see out of the window then there's a high possibility that you will see what I call an 'upwards waterfall' where streams on the mountains are being blown back into the air! It happens regularly on Mallerstang!
And "Kinder uplift", as you might call it :)
matchmaker
8 Mar 2009
Central Scotland
Don't know if this is caused by Doris:
http://www.bbc.co.uk/news/uk-scotland-north-east-orkney-shetland-39053418
Rail service have been disrupted after an Aberdeen to Inverness train was damaged when it hit a fallen tree in Aberdeenshire.
The incident involving the 10:13 service happened close to Inverurie.
ScotRail Alliance said no-one was injured in the collision, but that the damage included a smashed windscreen and engine failure.
Deepgreen
12 Jun 2013
Gomshall, Surrey
A cover-all. With 30cm of snow, roads will be much worse affected than rail (given the 300m qualification and that there are few railways at this altitude in the amber area), and the Met Office follows other national organisations in playing safe.
sheff1
24 Dec 2009
Sheffield
Indeed. It used to be due to normal winter weather but now it is, apparently, caused by one or more of a "Weatherbomb", "Killer Storm", "Deadly Hurricane" etc.:o:
Deepgreen
12 Jun 2013
Gomshall, Surrey
Not likely to be snow, even on the highest parts of the line, with temperatures only down to about 3C and heavy, driving, rain. You might be lucky, though.
gavin
25 Dec 2006
Some nasty wind gusts around tomorrow for most the winds ease by late afternoon
