adrock1976
Every so often, it is mentioned for the former stations at Beattock and Abington to be reopened, which as well as reconnecting the towns of Moffat and Biggar to the railway network, this would also mean that Lockerbie and Carstairs would no longer be the longest distance between them without another station. The trains would run Carlisle - Stirling every 60 minutes, and could be named/advertised as Eden Forth (after the river in Carlisle and the Forth Valley area around Larbert - my own mad thought).
For both Beattock and Abington to reopen, realistically it would be after HS2 happens, either with purpose built new high speed line, or quad track the existing ex Caledonian at least between somewhere south of Beattock to somewhere north of Abington (ideally quad track Lockerbie - Law Junction so as freight trains and the new Carlisle - Stirling does not get in the way of the HS2 trains).
I have based the run times on the Class 397 and compared it with the Azumas that were diverted via Carlisle this week, with both having similar run times. I have tried to have good connections where possible, such as at Carstairs (for Edinburgh - the trains Edinburgh - Glasgow Central via Carstairs seem to be randomly timed rather than a 2 hourly frequency), and Motherwell (for Dalmuir via Glasgow Central Low Level). Connections at Stirling from Inverness, Aberdeen, and Alloa/Dunfermline Queen Margaret (if ever extended that far beyond Alloa) are reasonable southbound, but I could not get them to be no more than 10-15 minutes northbound. At the Carlisle end, this new train would connect into and out of the Birmingham train in both directions. At Cumbernauld Carbrain (Carbrain can be suffixed if the proposed station at Abronhill/Kildrum ever opens, and it also fits with the three letter code CUB), connections to/from Falkirk Grahamston/Grangemouth are around 15-20 minutes.
The only way I could get this to work would be the Beattock - Abington section to be quad tracked so as to join up the three loops at Beattock, the Summit, and Abington together so as to allow other trains to overtake without having to persistently duck and dive into those loops. Also, the end to end journey time is slightly longer than driving via M74/M73/M80/M9 (I used the Automobile Association journey planner Carlisle Station to Stirling Station), but is broadly similar to changing at Edinburgh or via the two Glasgow Stations (remember it is 30 minutes to interchange Queen Street - Central). Also, Carlisle Station - Moffat via M74 is 50 minutes therefore maybe around 10 minutes quicker when factoring in the bus link to Beattock station. Carlisle - Abington by road is over 1 hour, plus 15 minutes to Biggar, where the train and bus link has it broadly similar. Biggar - Motherwell Station via A721 is around 50 minutes, similar to the bus link and train from Abington.
Being as both Beattock and Abington stations are close to the M74, these could also be made into a park and ride facility where buses could link to Moffat and Biggar. Also, at Carstairs, trains would connect into a bus link to and from Lanark. These bus links would be integrated with the railway ticketing system, with the railway specifying the service levels and timetables (some of the SPT supported services have only two journeys in each direction in Biggar and Lanark - early/mid morning and lunchtime/early afternoon, which is a throwback to the Royal Mail Postbus) rather than to the whims of the bus companies.
A few questions I have:
1) Is it better to quad track the section I have outlined in the attached file, or for there to be a new alignment dedicated to the HS2 trains?
2) I have assumed a revised straighter alignment Carstairs South - East Junctions cut off for Carlisle - Edinburgh. Is this still going ahead?
3) I have based this on a 60 minute frequency. Would InterCity East Coast trains diverted via Carlisle still be able to run this way, or would they never be able to if a Carlisle - Stirling service was introduced?
4) I have based the headways on the standard three minutes. Is this enough or does there need to be a greater headway due to freight trains even though I have quad track Beattock - Abington?
