444s are hardly a microfleet when with the 450s.
At 45 units they're hardly a microfleet anyway! There are many fleets smaller than that..
The unit fitted with AC traction motors last year was U.2416. Currently being rewired in Bournemouth Depot.
Also known as the Explodey AC Traction...?
I still honestly don't see the point in re-tractioning something that only realistically has a lifespan of another 2 - 5 years.
The Desiro Verve is the answer to replacing the 442s IMO. If SWT won then we probably would have seen a similar thing to SWR but no 442s and many more 707s to replace the rest of the metro fleet.If it were still SWT and the 707s had been kept, I'd have expected a 23m iteration of the Desiro City to bolster mainline capacity, since even if not a Desiro UK, there was proven use of Siemens kit and there'd be some cross-compatibility with the 707s.
As things stand, I expect it will largely depend how SWT come out of the supposed upcoming franchise reform. There may be a downturn in traffic big enough to simply not warrant any replacement of ageing stock at all. If the 442s are too problematic they might simply be done away with and not replaced with anything.
Long-term it makes sense to replace the 159s and 442s (if they're still around) with a bi-mode longer distance unit that can be used on essentially any route on the network, if there is reason to invest in such a thing.
Maybe, there is always the possibility that Siemens could have upped the acceleration.Why the assumption that SWT would have gone with 707s? They would have been just as non-compliant with the bid specification if SWT had proposed them - indeed the only reason that they did get them to begin with is because it was the only metro stock that was actually available.
Surely roof mounted grab rails wouldn't be that hard to fit?It's not the acceleration that is the concern, like you say that can easily be fixed. It's the distinct lack of roof mounted grab rails in the vestibules that prevent them from meeting the 4 passengers/sqm standing capacity
There's an argument that in 5-10 years time SWR could ditch the 442's, 444's and 158/159's to then create a new bimodal train for all their long distance services. With then the 450's replaced 10-15 years after that.
One other thing to consider is that with Crossrail 2 allowing more services to run out of Waterloo to places beyond Woking then there's likely to require extra units. If that's the case then the replacement of the 444's (rather than keeping them as a micro fleet for 10-15 years) could make sense.
Such a "replacement" could mean more 444's being used instead of 450's on some of the middle distance services which would be able to use either unit type.
Even if Crossrail 2 is delayed beyond where it is a consideration, then there's the possibility for the 444's to be used running Paddington, Heathrow, Woking and either Guildford or Basingstoke to provide the rolling stock for the Southern Approach to Heathrow services.
That would then allow a order for ~100 x 5 coach bimodal units to replace the current services run by 442's, 444's and 158/159's
Class 444s and 450s have a section 54 agreement keeping them on lease to the SWR (and any successor franchises) to latter part of this decade.
Precisely. By all means suggest a similar individual vehicle design that is the same for both the west of England and mainline, but the balance of third rail to diesel routes will never require the whole combined fleet to have bimode traction. It would be an utter waste of money.What does the operator of services from Waterloo need 100 bimodal 5 car units for? There is only one non-electrified route and the timetable would almost certainly be written around keeping units self contained to a particular route. Even if 100 units were justified, the majority would be straight electrics and 5-car units aren't a good replacement for 2 3-car units. Does demand on the Salisbury to Southampton service justify 5-car units?
...however some forum members are probably already dreaming of allowing for extensions to Plymouth via Oakhampton...![]()
I'm sure that there's other services which people could develop which wouldn't be possible currently.
I would propose a mixed fleet of 3-car and 5-car bi modal units for the West of England routes. Services on the London route could be run as 3+5 or 5+5 with one portion detaching at Salisbury. The 5-car would continue beyond Salisbury but at quieter times a 3-car could be used. 3-car units would operate the Salisbury 6 (perhaps even then overcapacity?)
I would even suggest transferring the Bristol-Portsmouth route to SWR and have this route also use the same 3-car or 5-car units based at Salisbury but there are probably a number of reasons why this couldn't happen.
GA's FLIRTs look great, could an equivalent of these be a possibility?
Thereby cutting capacity west of Salisbury.
By replacing with a direct replacement of 3-car all round, there is a lot of wasted cabs which is why I made the suggestion of 3-car and 5-car allowing flexible formations.
In my limited experience (I live on this line) it has been quiet West of Salisbury outside of peak times so hence my suggestion for 5-car being adequate. Clearly I’m wrong. Have you used/frequented the line?
Now is there demand? Probably not. In 10 to 20 years time could well be a different matter, especially if we are rapidly moving towards a more carbon economy with much more working from home making private car ownership less financial sense due to the high up front costs.There are but they probably aren't as remunerative as the current services.
Waterloo to Weymouth via Yeovil needs some considerable work to make it feasible given the single track, the reversals at Yeovil (or Westbury). Is the demand from Weymouth (and maybe Dorchester) enough to justify a service without the loadings which the service gets at Poole, Bournemouth, Southampton and Winchester.
I can't see anyone at Overton, Whitchurch or Grateley being happy about losing a fast service for operational convenience of sending the stopper to Salisbury. It seems to miss the point that running 12-car trains to Basingstoke is justified but extending those full length stopping trains to Salisbury never would be.
Good idea, Porterbrook can consider converting the 350/2s into Battery-Hybrid-EMU instead of pure Battery EMU.Siemens currently offer the Desiro Verve as a battery hybrid unit, but there is no off the shelf diesel bi-mode offering. Like Pompeyfan says though, offer them enough money...
Yes, and I admit that I have been on comfortable 3-car services west of Salisbury. I have also been on full 6-cars, especially on Sunday evenings towards London which have been full and standing before Salisbury. You are right that there is wasted space in terms of cabs but the layout of a 159 is also one that provides a lot of passenger space that perhaps couldn't be replicated well in new build stock.
I have also been on Saturday morning 444s towards Bournemouth when they are only formed of five coaches and again, there can be issues with five car not quite being enough but ten car being too much.
Guys I wondered why don't WMT consider retain 350/2s and move 350/1s to SWR to work with the existing 444s/450s knowing that 350/1s are MS units and their contact shoes are surplus in WMTGood idea, Porterbrook can consider converting the 350/2s into Battery-Hybrid-EMU instead of pure Battery EMU.
