SWR Metro fleet permanent withdrawals
Nicholas Lewis
9 Aug 2019
The May 2022 LTP diagrams have no 707s (or 701s) in. I assume 707 diagrams will be added in on an STP basis until they go in August. But it suggests that SWR have planned on the basis of the remaining 707s being transferred before the 701s starting entering service. The loss of 707s is filled in for by further movement of 450s from mainline to suburban work. There is a fair amount of 450s booked on Chessington/ Guildford via Cobham/ Woking diagrams.
450's to to Chessington?
shows they have had far too many 450's for the out suburban work so about time they sweated the assets this operator is taking more tax payers support than any other one.
Dibbo4025
21 Mar 2018
Is there any difference in the cab set up times between 450/455/701/707?
If there isn’t then (traction knowledge allowing) it’s not a big deal to use different stock ad-hoc.
No noticeable difference, in fact 8 450 has a slightly shorter change end time than 8 455. Main issue is the 450s door cycle time, officially needs an extra 15" dwell but in practice, with the current timetable not really an issue, just might not recover minor deals quite as well
As for 701s, no official times, but should definitely be able to match 455 times, be a bit less than ideal if it turned out they couldn't
Goldfish62
14 Feb 2010
They're high performance units. They should easily match if not beat the 707s and leave the 455s standing.
Southern Dvr
13 Oct 2010
The conversation was about cab preparation times. On SN 455s have a 4 minute cab preparation time compared to a 377 at 2 minutes.
Performance wise the 701/707 would be pointless if they couldn’t match a 455!
Messroom gossip seems to suggest there’s suddenly an issue with 455s going to Bournemouth. It sounds like they’ve quietly been removed from the SA.
Gather the working ran on 22/04/2022 so clearly was fake news.
pompeyfan
24 Jan 2012
Turns out it wasn’t fake news at all, and they were removed from the sectional appendix (SA), an extension of compatibility had to be issued which should appear in the WONs (Weekly operating notices) and PONs (Periodic operating notices) before making it into the SA
Wolfie
17 Aug 2010
Turns out it wasn’t fake news at all, and they were removed from the sectional appendix, an extension of compatibility had to be issued which should appear in the WONs and PONs before making it into the SA
Bureaucracy (as in they should have been gone by now, had the replacements been anywhere near on time, and someone forgot to extend the paperwork) or more than that (as in: has anything physically changed) though?
Not knocking necessary paperwork but having worked for Government for years l know that the tail can end up wagging the dog....
25 Oct 2020
Epsom Downs
It would have been fine if the usual points at Branksome from P2 into the depot were ok. Because they had to go via Poole which didn't have the paperwork to enter from P1 that was the admin issue.
Goldfish62
14 Feb 2010
Ah -apologies. :oops:
The rolling stock requirements are still nowhere what they were pre-Covid. For starters Reading line services require around 14 fewer units daily on Mon-Fri.
Could you post a link to the source showing taxpayer support by TOC? Hopefully it's quoted per scheduled km to give an accurate comparison.
Nicholas Lewis
9 Aug 2019
You can find info here its total payment and has been updated for a few more periods since I last looked at it and actually shows a good improvement although data is nearly six months out of date.
miklcct
2 May 2021
Cricklewood
Are the Waterloo - Woking and Waterloo - Guildford suburban routes staying with fully 455s in the foreseeable future?
TEW
16 May 2008
No. They see a number of 450s from the May timetable.
TEW
16 May 2008
I wonder if this won’t happen until the 707s go, as currently they have enough 455s to cover current duties
It would make sense but will require some shuffling of the diagrams. On Weekdays an 8-car which has been working Suburban services then attaches to a 4-car in Woking East End Sidings and works to Alton the next morning for example.
Bigfoot
2 Dec 2013
707s have lost some of their route availability (beyond Basingstoke and Haslemere essentialy) due to ride height modifications being made ready for their transfer to south Eastern in the summer. They are definitely going...
Juniper Driver
17 Jul 2007
SWR Metals
22 Aug?
TBH I was surprised at the demise of the 456's.
25 Oct 2020
Epsom Downs
Unit shortages back again? Noticed some short formations (5 carriages) yesterday and today on the Putney line
No. There are booked 5 cars previously discussed on one of the SWR threads. Long time since there was a deficit of 458s available to required amount.
m4tt
10 Apr 2021
Can anyone confirm if 5907 and 5918 are still at Strawberry Hill C.S.D? If so are they visable from any overpass or public access point as they are my last 2 /9s for pictures. Thanks
TEW
16 May 2008
Noticed 3? 458s stabled at Farnham. Not sure how long they have been there or why. The standard timetable sees no 458s stabled at Farnham.
