Sorry. I'm a bit dense. Touch into the TfL system with what?Use Bridge Pass to access Guildford Station, train to Clapham Junction, then touch into the TfL system to carry on journey, only paying for the section from Clapham to X.
An Oyster card, perhaps, or a contactless payment card.Sorry. I'm a bit dense. Touch into the TfL system with what?
You're correct about the pink ones. There is apparently a yellow reader inside the boundary at Clapham Junction, although it's right by the gates, so I always tend to just go out and back in again. All of this kind of depends on the idea that users are willing to get off at Clapham and are making a journey which can be completed on Oyster and is noticeably cheaper from Clapham, and that the the gates can't successfully detect and ignore a touch-and-no-exit, which seems a stretch tbhI thought pink Oyster Card Readers were only used to tell the system that you have travelled from A to B via the station where the pink reader is located (usually to avoid zone 1). I didn't think it was for starting a journey (having always exited at Clapham myself to touch back in on a yellow reader). Maybe I've been wrong all these years (wouldn't surprise me) but didn't want to take the chance of being charged more because of it (or worse, a penalty fare). Happy to be corrected.
Platform 17 has yellow readers so no need to exit and reenter. I have used them myself when switching from a paper ticket to Oyster.I thought pink Oyster Card Readers were only used to tell the system that you have travelled from A to B via the station where the pink reader is located (usually to avoid zone 1). I didn't think it was for starting a journey (having always exited at Clapham myself to touch back in on a yellow reader). Maybe I've been wrong all these years (wouldn't surprise me) but didn't want to take the chance of being charged more because of it (or worse, a penalty fare). Happy to be corrected.
You can start a journey using a pink reader but can't finish one.I thought pink Oyster Card Readers were only used to tell the system that you have travelled from A to B via the station where the pink reader is located (usually to avoid zone 1). I didn't think it was for starting a journey (having always exited at Clapham myself to touch back in on a yellow reader). Maybe I've been wrong all these years (wouldn't surprise me) but didn't want to take the chance of being charged more because of it (or worse, a penalty fare). Happy to be corrected.
That'll be why I haven't spotted it before. I tend to flit between platform 8 and 1. Too far to walk to 17!Platform 17 has yellow readers so no need to exit and reenter. I have used them myself when switching from a paper ticket to Oyster.
It will open and let you out, and subsequently charge you an incomplete journey fare.I'm still on this Guildford bridge pass thing. I've arrived at Clapham without a ticket and go to one of the exits at Grant Road, St John's Hill or Brighton Yard. If I tap the contactless card from my bank on a yellow reader at one of the exit gates (not having tapped in anywhere) what will the gate do?
That's true with Oyster and TfL Contactless. As I said earlier though, I think you can get through with an SWR Smartcard without paying. Lean over and touch "in", then touch out and exit as normal.This is getting to sound less straightforward and more expensive than people thought. What it seems to come down to is unless you vault over the gates at Clapham your free journey with your Guildford station bridge pass will wind up costing you.
Really? At peak time a single from Guildford to Waterloo will cost £16.10. Using a bridge pass and touching in at Clapham Junction would appear to take that down to £3.50.What it seems to come down to is unless you vault over the gates at Clapham your free journey with your Guildford station bridge pass will wind up costing you.
The fare is the peak contactless fare from Clapham Junction to Waterloo.I'm sure you're right, but where do you get your incomplete journey fare of £3.50 from?
Nothing to do with incomplete journeys - it is how much it would cost to get to Waterloo.I'm sure you're right, but where do you get your incomplete journey fare of £3.50 from?
Alternatively, you could try reading all of the post.The reply is yours, Haywain, but now you're saying something different. If I'm missing your point pls let me know.
Where does that post say anything about £3.50?The post in its totality reads:
"It will open and let you out, and subsequently charge you an incomplete journey fare."
I just don't understand how that is £3.50. Is that an incomplete journey fare?
"The November 2022 study monitored the use of test-specific bridge passes and also counted the number of pedestrians passing in and out of the station.
A total of 1,787 bridge passes were lost, an average of 71 per day.
Yes, comprehensively. Try reading the two posts completely independently of each other. Or just ignore both of them and forget you ever saw them.Am I still missing your point?
Or spend an additional £1.75 on a child single to open the barriers.There is an easy plan B - spend an additional 15 mins and walk over to London Road.
There are yellow readers inside the station at Clapham Junction. You do not need to leave clapham junction. The other week I used a paper ticket to clapham junction, and then tapped in with my debit card to use the london overground - this is very common. Hundreds of people turn up at Clapham Junction on paper tickets every single day to change onto the tfl system, they're not paying minimum fares etc, they're tapping in on the visible yellow readers. So if you can get to clapham junction from Guildford with a bridge pass then it you can just pay the tfl contactless fare - personally I think that is a big if, ticket inspections are pretty regular on the fast line from GuildfordWhat I've been trying to do was to establish just how easy it is, having travelled to Clapham Junction using a bridge pass to board the train, to get out of the station. I'm still not 100% clear. But given the existence of the barriers at the three exits (I've only used Grant Road but have never seen fewer than two prople on duty there) I don't think this would be straightforward.
In the past the main barriers have been manned and the back entrance open.Tonight I passes the back entrance of Guildford Station after 23:00 and it was unmanned with the barriers open. No idea about the front as I wasn't passing that way.
Those creating the peak struggle to avoid them and even off peak you have to go through two barriers, and off peak passengers are the worst for random slow walking obstruction!The footbridge route may well be slightly longer but when it's raining cats and dogs the shelter of the bridge is welcome. And you don't need to be a rocket scientist to avoid peak travel periods.
The redevelopment is limited only to the actually station building site rather than the platforms as well unfortunately. Would have been great to add another bridgeWe looked at moving to Guildford a few years ago. One of the biggest factors for us against moving there was that most of the houses within walking distance of the train station were on the west side of the station, and the walk to the town centre on the east side of the station was generally quite unpleasant (congested roads, narrow pavements, one way system, underpasses etc). It's a real shame how the redevelopment of the station missed an opportunity to put in permanent non-paying footbridge - and rather shows how car-centric a lot of planning in the area still is.
I'm surprised that at a minimum SWR haven't created a mechanism for holders of The Touch smartcard to be able to use that to pass through the station barriers and use the footbridge for free. It's at least far less open to abuse than the current pass system.
