Talerddig loop could be extended?
Bristol
How long is the existing double track (loop) section and whereabouts are any stations?
Only if the existing double track section is significantly longer than the length of the existing trains that use the line, moving the block marker boards (with appropriate changes to the signalling system) may be a more practical possibility.
The loop is about 8 miles from Caersws station and 13 miles from Mach station, off very approximate Google maps measures. (pin on Loop: https://maps.app.goo.gl/2QjxUzNhYFAaoVj18)
The mentioned Carno station proposal would be about 3 miles closer to Caersws than the loop's current position.
bahnause
30 Dec 2016
bülach (switzerland)
Hence why I said “And”.
Leaves are the biggest issue, though, and should be tackled course. There needs to be less pandering to the green lobby: it is a safety issue that, as we have seen this week, has the potential to kill people. That consideration far outweighs the tree-hugging.
Why would you cut down trees, when there is already another solution available? Is it the most cost effective solution? Most railways cope with trees being around without major problems or have local mitigation strategies in place. Trees are an essential asset to cope with a warmer and wetter future.
6Gman
1 May 2012
I don't think the bar to reducing the vegetation issue is primarily the green lobby.
It's money.
And the fact that many of the trees concerned are on private property.
And there are a hell of a lot of them!
millemille
28 Jul 2011
Would anyone know what the speed limit is over the points and along the Talerdigg loop?
Bristol
The railway doesn’t really cope well with trees. Apart from causing adhesion issues, they also cause big problems during both wet and windy weather.
I don’t disagree trees are an essential asset, however there’s plenty of places they can exist without causing problems, and next to railway lines isn’t one of them.
So as far as I’m concerned just butcher as many as possible. This doesn’t deal with those outside the railway boundary, of course.
Lurcheroo
21 Sep 2021
Wales
Image included below, the straight through route ('Down Loop') is 95kph through the area, the actual loop ('Up Loop') is 50kph. Both lines are bi-directional.
As was stated earlier, in theory the first train should always be put into the up loop but it certainly does happen where the first train gets put into the down loop and held there whilst the 2nd train is routed through the slower up loop. Usually when this happens the 2nd train is very close by so I guess it’s usually a misjudgment of timing.
bahnause
30 Dec 2016
In a few minutes I will hop on my train and drive up one side of the hill and then down the other side. 560 tons of train, pulled and mostly braked with 84 tons of locomotive. It is rather steep (2.6-2.8%) and mostly full of trees on both sides. Half of the leaves are still on the trees, the other halve is gone. Light rain. As usual, it will not be a problem. I can guarantee, there wouldn’t be a railway line without the trees. It would
be mudslides in spring and avalanches in winter.
There is much more to vegetation control than cutting down trees.
Llanigraham
23 Mar 2013
Powys
Wasn't the proposal to move the loop to Carno and reopen the station there dismissed because it would screw up the timetable?
(And to be honest, most of the people I know in Carno are quite happy to drive to Caersws and get free parking, which would be difficlut to provide at a reopened station)
30907
I suspect so. It's only 2min extra, but the (planned) hourly service requires such tight timing that it would scupper any portion working from the coast.
Lurcheroo
21 Sep 2021
Wales
I would think that the 197’s will change this though as their acceleration is much better than the 158’s and will reduce the running times, in particular Caersws - Carno would be a section that should benefit greatly as it’s a slog up the hill.
That doesn’t necessarily mean it improves the case.
InkyScrolls
20 Jul 2022
North of England
That's excellent, good for you. But here in the UK vegetation is a huge issue and one which needs addressing.
Tomos y Tanc
1 Jul 2019
Like you, I'm finding it hard to recall some of this!
I don't think it was a timetable issue that nixed Carno reopening, it was more a matter of Network Rail applying urban passenger targets to a rural station. You see some of this up-thread, where someone used the horrible phrase "wash its face" to oppose a useful and simple reopening.
It wouldn't benefit a huge number of people, but it would benefit some, and would have many more users than most of the stops on the Cambian Coast and HOW lines
It is a timetable issue, the Cambrian has loops based upon the hourly timetable (and even then line speed increases had to be added to make it properly.work). Bow Street worked as its on the last section so could eat the turnaround at the emd.
Lurcheroo
21 Sep 2021
Wales
With the 197’s bound to alter various timings, will it be a simple case of re-adjusting the timetable to make the hourly service (and current calling pattern) work properly? Will it then just be as simple as having more turn around time at Aberystwyth ?
If so, then does that make the Carno reopening case any stronger ?
56xx
19 Jun 2021
Merthyr Tydfil
One solution to help this not happening again. Would be to extend the loop by 2-3 miles towards Caersws but leave the stop board towards Shrewsbury where it is and back up the stop board for trains to Machynlleth further back towards Shrewsbury.
The up loop (the actual loop bit) has a clearance of 175m in the down direction and 181m in the Up direction.
The down loop (the higher speed main line bit) is 176m in the down and 181m in the up. A 6 car set oh both 158’s and 197’s can easily be accommodated with the 197’s coming in at just over 144m for 6 coaches.
The loop was showing as close to 500m in 2010 before some serious Network Rail activity is showing in spring of 2021 (Google Street View).
A level crossing was closed at the western Machynlleth end of the loop. Was the loop actually shortened at this time at the Caersws end?
Lurcheroo
21 Sep 2021
Wales
The loop was showing as close to 500m in 2020 before some serious Network Rail activity is showing in spring of 2021 (Google Street View).
A crossing was closed and a new bridge built instead just at the Machynlleth end.
Not sure if the loop was shortened, where did you find the info ?
56xx
19 Jun 2021
Merthyr Tydfil
Edited the earlier date to 2010 but 2 street views in Google Map. The 2010 shows the loop extending much further towards Caersws. It measures about 500m on map.
stevieinselby
6 Jan 2013
Selby
What is the social purpose that could not be met more efficiently and effectively by electric buses?
Getting somewhere before you die of old age?
The NX coach from Aberystwyth to Shrewsbury takes half an hour longer than the train.
Many journeys along the Cambrian Coast would be significantly slower by road, even where the road parallels the railway, because the roads are so poor and unsuited to large vehicles.
Buses are less suitable for people travelling with lots of luggage and/or bikes, which would make them a poor option for a popular holiday destination.
To provide adequate capacity and mitigate the slower journey times, you would need to run a lot more buses, resulting in an increase in the number of staff needed.
Carno is barely even a village, it's a hamlet of about 300 people.
A station there would have no wider catchment of note – no more than 1000 for whom it would be the most convenient station to get to.
It already has a bus every 2 hours from Machynlleth to Newtown, which is more than adequate for such a tiny place.
There is no justification for spending millions of pounds building a station that would get so little use, not when there are hundreds of other communities that are far more meritorious and would give a much better return on investment.
I dont expect TfW to alter a thing, it will be kept as performance buffer.
DelW
15 Jan 2015
If (hypothetically) it was ever decided to reinstate one or more of the stations east of Mach, might it be possible to serve them with the alternate Aberystwyth-only trains? Since they don't need the splitting and joining time allowances for connections up the coast, there might be scope to allow additional stops without cutting into turn-around times.
Unlike the metropolises of Cynghordy and Dolau, never mind Llanbister Road and Sugar Loaf, from where there's barely a house within sight? ;)
But I do accept that if any of those had closed, the likelihood of their reopening would have been very low indeed, and that the case for rebuilding any of the stations between Mach and Caersws is little better.
stevieinselby
6 Jan 2013
Selby
That's the difference – the cost of serving a station is low (although too many halts on a route will start to impact on journey time and reduce the attractiveness for long-distance passengers), and in many cases probably lower than the cost of closing the station, but the cost of building a station is high. There are hundreds of stations on the network that it is worthwhile continuing to operate, but which would never justify being built now if they weren't already there. And, in cases such as Pilning and Polesworth, in the event of any kind of capital expenditure needed to keep them operating they are likely to be wound down to a token call to avoid the closure process but without providing any kind of viable service to passengers.
Meerkat
14 Jul 2018
Slightly concerned that H&S fervour will lump the railway with a big bill for full protection of loops - ie pointwork into a parallel sand drag
30907
...which you would then logically have to apply at numerous junctions.
Far less costly, but somewhat disruptive, would be to have the traditioal single-line practice of bringing the first train to arrive at a loop nearly to a stand at the home signal - approach control from red would be a modern equivalent I imagine.
stevieinselby
6 Jan 2013
Selby
And if the train doesn't stop, then what?
30907
You have a few hundred metres extra before a potential second SPAD and crash, compared with entering the loop at 30mph.
Of course I'm assuming the cause is lack of adhesion not driver error.
stevieinselby
6 Jan 2013
Selby
If you effectively extend the overlap at every signal (or even just every signal that protects a conflicting move) by that much then the impact on journey times and capacity would be horrific.
The number of incidents and accidents caused by loss of adhesion where this would have prevented or significantly mitigated them is infinitesimal compared with the number of safe movements past those signals.
I'm not saying we shouldn't try to learn lessons from this crash and see what can reduce the likelihood of future occurrences, but we do need to ensure that any response is proportionate.
30907
I agree, sorry if it was unclear.
I was suggesting it for crossing loops on single lines - and on reflection most of those are at stations where the stopping point would be short of the signal anyway so would not be high priority. Talerddig is one of a handful in open country.
