TEA-OCC tips
MNM
19 Oct 2021
Cambridge
Hello everyone,
Can somebody please answer me about Tea-Occ assessment?
Part 1 - Low & High. It always starts with a low tone. Count the low tones.
Part 2 - No tones, directory search only - XX OO ✰✰ ☐☐ Are these the symbols?
Part 3 - Directory search and low tones or just a beep tone only. Count tones and search directory.
In part 3, will the directory page change every time the tones page changes?
Thanks
Slinky252
29 Aug 2018
Everything you say is correct but part 3 it’s one page to scan you just keep going back to it.
MNM
19 Oct 2021
Cambridge
@Slinky252 - Thank you for clarifying this.
Stages 1 & 2 are pretty easy but the combination was quite difficult with very less time. What is the passing percentage on Stage 3 though?
Slinky252
29 Aug 2018
I honestly don’t know what the pass rate is, I found this test to be the easiest of them all but you defo have to concentrate more with part 3. But after doing part 1 and 2 you will have a feel for it.
MNM
19 Oct 2021
Cambridge
@Slinky252 - Great, thank you for the info. I have my assessment next week and am feeling a bit nervous but I have to keep preparing myself.
sargentsiri
1 Jan 2018
Without coming across like I'm some sort of genius. My advice would be, please don't over think it - this test, even when the tones are going, is much easier than you actually expect - you'll be fine
Slinky252
29 Aug 2018
Stratford
You sound like no doubt you have done your homework, you will be nervous that’s obvious. Biggest piece of advice I can give you is, don’t rush there is an emphasis on speed but more on accuracy. If you have practised you will fine, they are looking for accuracy. You will find the GB Test easier than the practise material. Regarding the TRP 1 they told us we could write stuff down, this slowed me down so I just kept reading and when test came I remembered it. TRP 2 don’t rush you will probably not finish or even close accuracy is key. TEE OCC we have discussed you will find this the easiest. Relax, take a bottle of water, Remember there is an emphasis on speed but they want accuracy don’t worry if you don’t complete the tests Good luck.
MNM
19 Oct 2021
Cambridge
@Slinky252 , thanks for your great advice. I will let you know how I did at the assessment.
@Slinky252 Hi, can you please let me know if it is on the computer or on paper(the symbol directory) like we hear the sounds on audio and we are given paper to circle the symbols? thanks
NorthernTech
12 Apr 2021
Uk
They will explain each test thoroughly at the test centre and give you chance to ask any questions. Dont worry so much about it. You have the gist of it now, you’ll be fine
Luckyflames
12 Feb 2021
Kent
Best advice.
If you don’t understand anything. Do not start the test until you fully understand.
Slinky252
29 Aug 2018
It’s on one larger sheet of card, and I echo what Northerntech and Luckyflames have stated.
