Tell me about the S8 de-icing equipment
tranzitjim
4 Jun 2013
Australia
I am doing a study on de-icing equipment, and am particularly interested in the equipment that is found on the London underground S8 stock trains.
Please whatever detail you can provide, in respect to how they operate. Or in deed any other trains in the UK with the same or similar feature too.
Dstock7080
17 Feb 2010
West London
S7 units 21301-21385, located on M2D cars 25302-25386
S8 units 21001-21055, located on M2D cars 25002-25056
De-icing equipment:
- Fitted to around 30% of S Stock trains
- Applies de-icing fluid to the current rails; the flow-rate depends on speed of the train.
- Applies sand to the running rails in difficult adhesion scenarios; the flow-rate depends on speed of the train.
- Selected from the train control management system (TCMS) control panel screen.
Sleet brushes:
- Sleet brushes are fitted to all S Stock trains on DM cars (21xxx).
- Lowered to brush sleet/snow off the current rails.
- Selected from the TCMS control panel screen.
Ice mode:
- Fitted to all S Stock trains.
- Selected using the push button above the master control switch (MCS) when stationary. After selecting, train operators should wait 15 seconds before attempting traction in either tripcock mode (TM) or restricted manual (RM).
- Reduces the risk of trains losing traction due to ice or snow on current rails by widening the parameters by which the correct operation protection (COP) monitors the traction supply.
- Ice Mode should be selected before reaching icy rails or as soon as difficulty is experienced.
- Ice mode is de-selected by shutting down the cab
- Ice mode does not need to be de-selected until completion of the trip
- It is important to re-select Ice Mode upon start up, after crew changes and when changing ends.
tranzitjim
4 Jun 2013
Australia
Thanks for that DStock7080
De-icing equipment is on 30% of the fleet. I guess that means the S8 stock?
Sleet brushes are only on the contact rail, which I presume is the one that provides power to the train? Do you have these Sleet brushes on both positive and negative rails.
The DeIcing fluid and the sand. Are they used together in any way?
Does anyone have any photos of these devices please?
Nym
2 Mar 2007
Somewhere, not in London
It is fitted to a number of trains assinged to each line, so is fitted to S7 and S8 stock, indeed the S7+1 units in use on the met to cover the shortage of S8s are S7s with a de-icer car inserted into it. This can be spotted on S Stock as the car is numbered in the 25xxx series rather than 23xxx (it is fitted to the M2 car) and has a blue circle by the car number, and a white circle by the train number on the cab ends.
Indeed it is the one that provides power via the shoegear, and yes, the sleet brushes are fitted on the posi and negi rail contacts (all three positions).
In terms of Sand and De-icer, they are used for different things, but is can be possible to need the use of both of them.
The sand is used in areas of poor traction, where leaf fall or other contaminants have reduced the adhesion on the running rails, sand is used to improve the 'grip' between the wheels and running rails.
De-Icer is used to remove a film of ice that tends to build up on top contact 3rd and 4th rail systems, the sleet brushes then remove the sleet that remains on the rail head to give a good contact between the shoegear and rail head of the conductor rail.
Problems come when there is a total ice layer built up, no amount of de-icer or brushes can remove, this then needs to be removed by hand with ice scrapers, or with a de icer unit that does not need to take power from the conductor rails.
In practice, the last sets of shoegear at a minimum are able to maintain contact with the conductor rail, but on older stocks (and new stocks with silly battery charger methods like S Stock and 09TS) if you run in one direction for too long with no juice on the front end in high iced conditions, you will end up loosing the control supply on the leading end and have a dead cab. (I beleive a couple of mods have solved this issue on S7s and the rebuild work on the 09TS, the 92TS, 95TS and 96TS never suffered this problem).
The D78 Stock has had a problem for a while that it is very hard to distinguish when to place de-icer with the way the detection circuits are set up, this was addressed on the 73TS (very similar electrical design) by changing to a more modern detection system, similar to that fitted to the S Stock from new.
Dstock7080
17 Feb 2010
West London
De-icing nozzle (with lazer dectector immediately to its left) for positive current rail (just above block-joint), which identifies which side positive rail is.
sanding pipe for running rails (just ahead of wheel). Sand reservoir filler to right.
tranzitjim
4 Jun 2013
Australia
Thanks again for that valued input peoples. I should have known about the sand, as it is used by the trams in my home city of Melbourne Australia. I have not noticed it on our trains here though.
Here was me thinking that it may have been to do with the ice making the running rails slippery.
I guess the main issue would be the overnight buildup, when the first services of the day start operating?
I guess that LU would need to ensure that you can allocate a train with the equipment on the runs of which you need them on.
Mojo
7 Aug 2005
If you look in the Working Timetables, which are available for the public to view on the TfL website at http://www.tfl.gov.uk/corporate/publications-and-reports/working-timetables you will see which trains are required to be de-icing trains, as these are marked up with the letter D after the train number, either in the actual times, or depot working, or rolling stock working sections.
At the front of the timetables you will also see a box about de-icing trains, for example the Jubilee line:
WORKING OF DE-ICING TRAINS
Certain trains are equipped to spray de-icing fluid from one of the trailer cars. Instructions for the operation of this equipment are contained in Rule Book No. 6, Section No. 6.
Trains which are required to be so equipped in this timetable are denoted by a “D” suffix to the train number, for example 301D. Trains should spray fluid at least every 2 to 3 hours between Stanmore and Finchley Road and between North Greenwich and Stratford.
First Trains
The following trains are first trains over sections of line. In the event of there being a threat of icing, it is essential that the following trains convey de-icing trailers.
Code:
[B]
Mondays to Fridays                Saturdays                   Sundays
310, 323, 324, 357         312, 333, 347, 353             320, 336, 356[/B]
tranzitjim
4 Jun 2013
Australia
Why do they not just fit de-icing equipment to all trains, so that way it would not matter which train is where.
Also, does any of your diesel rolling stock have de-icing equipment fitted on them at all?
mainframe444
23 Feb 2010
de-icing nozzle for positive current rail (just above block-joint)
This is not the de-icing nozzle, it is a laser detector which identifies where there is a positive rail, and only drops fluid onto that rail.
The positive (outer) rail changes sides, and this device means the train is not dropping fluid onto ballast, making it last longer.
MF
