TfGM Bee Network - fleet discussion
mayneway
29 Mar 2024
Manchester
Regarding Middleton electrification, I was told by our senior management that the survey of the site in readiness for the works was either misjudged or done badly as apparently there's an awful lot more work needed than first thought, to the point that we've been storing two huge transformer boxes for Middleton at Bolton for what must be getting on 12months now (they were obviously meant to be installed on site upon delivery so goodness knows what they found to cause such a delay!)
It must be something big as TFGM have been renting a large yard in Hollinwood since last autumn for Middleton to run out of while the final phases of electrification are completed - what a waste of money!
It also seems that the early work on electrifying Queens road has also stalled after it was decided the Roof was too weak to hold cables and gantry’s for the chargers so it’s unlikely to go ahead any time soon.
Since acquiring the depot TFGM constantly switch from replacing the whole depot roof to not having the funds to do it. The cost supposedly runs into millions of pounds.
Leyland Bus
20 May 2021
York
The roof at Queens was "being replaced" 20 year ago when I started, then First wanted to remove the roof ala Todmorden and ever since its just gotten worse and worse... I'm pretty sure it could be done in stages to spread the cost but remember, in council ownership days a new roof was the death knell of a garage, see Swinton and IIRC Rochdale for that!! :rolleyes::lol:
M60lad
31 May 2011
1> Is the roof at Queens Road Depot in a worse state than the roof at Oldham Depot was as I know Oldham Depot's roof when under First was in a bad enough state that it whenever it rained it was like a heavy downpour inside the depot at times?
2> Regarding the BZLs for Stagecoach instead of just leaving them sat around in storage couldn't they temporarily use them in service at Oldham Depot which is electrified already and replace some of the diesel fleet?
mayneway
29 Mar 2024
Manchester
Didn’t say it was in a bad state I just said it’s too weak to hold the cables and gantry’s for the chargers. It will do the job but the likely hood is electrics won’t be coming any time soon.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
I’ve noticed that while Metroline and Stagecoach services helpfully have “Piccadilly” or “Shudehill” displayed on the front, Go North West services simply read “Manchester,” which is unhelpfully vague for a rather big city with multiple destinations. They also don’t have scrolling via points underneath, unlike Metroline and Stagecoach. They have the same bus types as the other operators. Time for an update perhaps?
MCRTransitYT
15 Nov 2024
Bolton
But on GNW's blinds, on the bottom line, it switches between the routes vias and Shudehill Interchange/Piccadilly Gardens
toms
14 Aug 2024
Manchester
I know that for some reason Stagecoach’s south Manchester services will have the actual destination on the top line of text (eg. “Piccadilly”) but north Manchester will have “Manchester” then “Piccadilly Gardens via Whitefield - Heaton Park - Cheetham Hill.” In a scrolling fashion. I know that in terms of AVA systems, any route that starts off with showing Manchester on the screens will automatically update once the bus reaches a certain point to its actual final destination.
Leedsbusman
9 May 2021
Layton
Perhaps that’s because many GNW services start outside Manchester and only enter it close to the terminus whereas Metroline and Stagecoach ones serve much more of Manchester.
TheSmiths82
29 Jun 2023
Manchester
Noticed that the areas the destinations are in on Metroline buses are still wrong. According to Bustimes.org the ticket data is showing many stops as being in Whalley Range when they are very much in Chorlton. This might cause some confusion, it seems that the destinations are programmed into the ticket machines, hence the data is showing up on Bustimes.org.
toms
14 Aug 2024
Manchester
Go North East definitely don’t, though I assume you meant any Stagecoach route.
I’m talking about the interior next stop screens and announcements, only on the E400EVs and most E200MMCs as they are Hanover systems, anything else will not do it because the Mobitec system hasn’t been updated yet. I think it’s only on Manchester routes too like the 36 but I could be wrong and they might not do it. I know they did way back at the start of last year.
From what I have seen the destination code is not updated mid route. If I am correct the blind will alternate so it will have “Manchester” in bold at the top and will alternate between “Piccadilly Gardens” “via Pendlebury” and so on on the bottom line of text
Boltons Hanover buses, if the destination doesn’t actually change on some routes they definetely change on 471 and 524 as I’ve seen. As it approaches Bury interchange, the announcement string and screen changes to Rochdale
mayneway
29 Mar 2024
Manchester
GNW have always used ‘Manchester’ as the main destination with the actual stopping point flashing up with the via points below.
To be perfectly honest I think out of all the operators I find GNW’s destinations the clearest and most informative, and it’s obviously not an issue as they have not been asked to change them by TFGM.
Redmike
13 May 2018
Are Diamond short of vehicles? The 309/310 were always operated by a new Mellor strata or occasionally a Fiat Ducato until recently. Now there are some rather tired looking Diamond liveried Mellor Stratas and an occasional Optare Solo.
Charles Street
13 Jan 2024
Mills Hill
They appear to have stopped using the two Fiat Ducatos for some reason and have brought in the two Diamond liveried Mellors. The two white Enviro 200s 20639/40 have gone to Preston.
mayneway
29 Mar 2024
Manchester
According to reports, Andy Burnham was at Metrolines Ashton depot on Friday 30th celebrating the Bee Networks first fully electric depot. Everything diesel has or is being moved out to other depots.
47550
14 Jul 2017
Manchester
Quite an achievement. There were just a couple of VHAs there yesterday, presumably being moved on soon.
11 Aug 2019
On the ZEBRA-subsidised BZLs specifically (150 DDs & 20 SDs; originally procured by Stagecoach Manchester)...
* 104 DDs (VMD367-470) allocated to Metroline Manchester - only 412 yet to enter service
* 6 SDs (VMS361-366) allocated to MM - registered/taxed but still yet to enter service
* 39 DDs (86031-069) allocated to SM - awaiting Middleton electrification works, which (per driver comment) still hadn't commenced as of a week ago
* 4 SDs (76001-004) allocated to SM - still yet to enter service
* 7 DDs & 10 SDs remain unallocated
Is the above correct?
Are the unallocated ones earmarked for Bolton to replace the Citaros which are likely to go to Wigan after refurbishment
