TFL/Overground Journey Fare Oddity
jumble
1 Jul 2011
Can anyone here explain how the £2.80 fare in the attached photo from Woolwich Arsenal to Rayners Lane is calculated ?
Thanks
Tetchytyke
12 Sep 2013
Isle of Man
It's the avoiding zone one single fare, charged if you travel via Stratford and the Overground. Finchley Road and Frognal <-> Finchley Road is an Out of Station Interchange (OSI), which joins the Woolwich Arsenal-Finchley Road and Finchley Road-Rayners Lane journeys together. Either you touched the pink reader at Stratford or the system has decided that you avoided zone one because you used the OSI at Finchley Road.
jumble
1 Jul 2011
Thanks Artic
However the TFL single Fare finder says £1.50 for that trip !
£1.50 off-peak
£2.80 peak.
But journey made on a Saturday? Oyster system fault that day? Call help line?
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Is it because the default fare from Woolwich Arsenal DLR to Finchley Road and Frognal if you don't touch the pink reader at Stratford is £2.80 (see here)? Thus unless you touch the pink reader at Stratford, you can never actually be charged the £1.50 fare to Rayners Lane because when you touch out at Finchley Road & Frognal you will (unless you touched the pink reader at Stratford) have already been charged £2.80, and the system can't refund you the £1.30 upon reaching Rayners Lane.
So presuming the person making the journey changed at Stratford, the moral of the story is you need to touch a pink reader there. Do we know what the route actually taken was?
Be3G
14 Sep 2012
Chingford
Yes Indigo2's got this right I think. Not the first time someone's been caught out by the fact that a higher fare can be charged to a mid-point OSI than is supposed to be offered for the full journey length. In this case however the single fare finder does state that a pink Stratford touch is required for the OP's journey, so it's not a fault with the system (as other cases of this problem can be, in a sense at least).
I assume the Stratford touch is required as the default route from Woolwich DLR to FR&Frognal is probably set as being via the Jubilee and former East London lines. Thanks, Shoreditch High Street.
MikeWh
15 Jun 2010
Crayford
Yes, that's right. And Indigo is definitely right as well.
Tetchytyke
12 Sep 2013
Isle of Man
Ah yes, that's what I was expecting it to be until I misread the Single Fare Finder.
FWIW both a journey to Finchley Road and Frognal and Rayners Lane require a touch on the pink reader at Stratford to be charged the lower fare. As you point out, this is mostly because of Shoreditch High Street. If the OP didn't touch the pink reader at Stratford then they have been charged correctly.
Paul Kelly
16 Apr 2010
Reading
It looks to me that it may be more "interesting" than that. All fares between Woolwich Arsenal and Rayners Lane are listed here: http://www.ltfares.com/#!fares?orig=DLWLA&dest=LURYL
There is an Off-Peak £1.50 fare for "Avoiding Zone 1 via Stratford and West Hampstead (or Finchley Road & Frognal/Finchley Road)", with a touch on the pink reader at Stratford showing as required, or a default Off-Peak fare of £3.10. If the touch at Stratford really was required in order to avail of the £1.50 fare, should failing to touch not then result in the default fare of £3.10?
The fact that the fare charged is less than £3.10 says to me that the system is attempting to charge the £1.50 fare but can't because the intermediate touch out at Finchley Road & Frognal already charged more than that and a later touch-out on the same journey can't refund part of a fare that's already been charged.
So what I'm wondering is if the pink touch at Stratford has some kind of equal status to the Finchley Road OSI in the way the fare is calculated. I think there are a lot more subtleties in the Oyster fares database then is given away in the data used by the fares finder (but I know MikeWh has been saying that for years!).
jumble
1 Jul 2011
Just to complete the thread
Indigo2 may be bang on the mark here
I did travel via Stratford but forgot to touch on the pink reader
I have to admit I would never have thought of the explanation but I did notice that £2.80 was deducted at Fr and F before I went on down to Fr
I am surprised however that I wasn't charged £3.10 as the system believes I did travel via Zone 1 and that is what the single fare finder says is correct for Woolwich to Rayners single So I still think this is a wrongly charged fare
( ie the price I was charged does not appear on the Fare finder page for that journey)
It is still of course possible that the system has charged a peak fare by mistake
Who knows....
MikeWh
15 Jun 2010
Crayford
This is correct.
I'm not sure about equal status, but you are pretty close your conclusion.
See above. It's charged the correct fare for part of the journey and then can't reduce that when it wants to later on. Therefore you are charged an intermediate fare.
Who knows....
Definitely not.
