markymark2000
Looking at the TFL service updates and seeing the upcoming rail replacement services, it got me thinking. Why are TFL running so many rail replacements? In my experience, TFL revenue protection on rail replacement is minimal and so they effectively become a free bus service which stops only at train/tube stations. This must lose TFL a hell of a lot of money (both from reduced fare from legit passengers only ending up paying part fare because the zones traveled are reduced but also freeloaders who would have caught a normal bus and paid but instead used the RRB because it's free) which is in addition to the cost of actually providing the RRBs. Further, by forcing buses to call at all stops to pick up and drop off, you are adding so much time onto the service meaning more buses needed to complete the cycles which again, costs a lot of money. I'd argue that in many cases, RRBs are overcrowded and thus more are put on than actually needed as a result of people coming off normal routes because the RRB is a free for all.
A few examples that I have found where RRBs could not run or be amended are as follows:
1. This weekends Richmond - Acton Central RRB. At Gunnersbury and Kew Gardens stops, PU/SD restrictions could be put on the service to force people onto the 65 or 391
2. Also this weekend, there is a Tower Hill to Canning Town replacement for the District and Hammersmith & City lines. Really, PU/SD restrictions should be put into place between Bow Road and Aldgate (excluding Whitechapel) to push people travelling to/from the city onto the 25 (Doesn't serve Tower Hill but does serve Bank station which links to Monument) and 205 (Doesn't serve Tower Hill but does serve Liverpool Street for connections)
3. Next weekend there is a DLR replacement from Canning Town to London City Airport (non stop). This should really not run and force all passengers onto the 474 and work with operators to provide dupes.
In each of these 3 examples, huge amounts of revenue could be saved and by introducing stop restrictions for passengers, you are reducing the dwell time which can in turn reduce PVR. You are also reducing the amount of people using the bus so there is scope for a frequency reduction which again, reduces PVR.
The only people that I can see being affected by these proposals are those who would have made a longer journey and not a local journey. Could this be worked by making the Oyster system smarter so that if you tap out of a station and then tap onto a route (which is specially approved each week to be an appropriate RRB route), then it scraps the bus fare and just charges you the difference in fare as if it was a through train journey? This instance would work for example 1 if you were travelling from Hammersmith to Kew Gardens, you would have to change at Gunnersbury and due to the restrictions, you would be forced onto the 391. Tap out at Gunnersbury and tap onto 391 at the RRB stop within 10-15 mins of tapping out, you get the bus fare free.
For the other way though where an RRB is needed first, you would likely have to get the person to manually dispute the fare as otherwise you are going to need some complex analytics system in place to work out who to discount the bus fare for.
While some fare revenue may be lost here from people who would have made the journey anyway (using example 1, someone who already travels from Hammersmith to Gunnersbury then catches the 391) but the money lost would be minimal compared to the amount of revenue being lost now.
With TFLs financial situation, they need every penny they can get their hands on and the way they currently run RRBs does not help the situation.
Abbreviation list:
RRB - Rail Replacement Bus
TFL - Transport for London
PU - Pick up Only
SD - Set Down Only
Abbreviation list:
PU - Pick up Only
SD - Set Down Only
