bb21
Emeritus Moderator
- Joined
- 4 Feb 2010
- Messages
- 24,164
Does anyone know if you need to touch in on replacement buses when using Oyster Prepay?
So effectively they are free buses?
No, you can still get penalty fared for not holding a valid ticket.
Not quite 'free' because 'free' suggests you can simply walk on one, with no Oyster card and no means to pay, which does not appear to be the case.If there are no oyster readers, they are effectively free to anyone with an oyster card with some credit on it.
Sounds like free buses to me!
Really? I foolishly took a rail replacement bus the other week and my journeys weren't joined up. :-xIf the bus is in the middle of your journey then the two halves will be joined up by a special OSI, possibly by processing a retrospective refund.
I have experienced this on a LUL replacement bus from Euston-Golders Green. My journey was Kings Cross-Brent Cross (scooping the crossovers at either end of the possession), I touched the barriers at all four stated stations and was charged for the through journey.AIUI from a conversation with the helpdesk, you need to have an Oystercard or a valid paper ticket, but the section of the route covered by the bus is free. If the bus is in the middle of your journey then the two halves will be joined up by a special OSI, possibly by processing a retrospective refund.
Unfortunately I have not managed to check this out because it is many years since I last used a replacement bus. Like many people I try to avoid them like the plague, and with several lines to London from near to me it is usually not a problem.
What happens if you alight at a barriered station I don't know (if you board the bus at a barriered station, you could touch the barrier but not go through it).
