TfW Class 67+Mk4 sets: trip planning/experiences, diagram updates etc
sd0733
7 Nov 2012
67010 is planned to run light loco to Holyhead this afternoon to replace 67020, Crew and path permitting. If not it will go tomorrow and the Holyhead start will be a unit.
67013 is planned to be replaced on HD04 by 67029 tonight ready for 1V31 in the morning.
HD05 is awaiting a slot at Crewe ETD for tyre turning following it's exam.
Welshguy1048
6 Apr 2023
Prestatyn
@sd0733
Afternoon
I see the path for 67010 light loco is in for this evening
Will 1V91 run tomorrow with both locos - 67010 and 67020? - or will it be a unit?
Which loco will be going onto HD05?
Thank you
Dave
sd0733
7 Nov 2012
@sd0733
Afternoon
Thank you
Dave
If the loco is there its Planned for 67010+HD07 to be on 1V91, 67020 will make its way back to Crewe separately.
Loco wise 67013 is planned for HD05.
Jacob Porrett
28 Jan 2022
Telford
It's fairly imminent but it's got a couple of days slack at the moment so it can cover for HD02 and HD05 which are both out of traffic with DVT brake issues and awaiting tyre turning respectively.
So HD04 might not be at Crewe tomorrow then?
sd0733
7 Nov 2012
The path is in for 67020 light loco going to Crewe from Holyhead
Off to the ETD for attention to a fuel leak
Where did it come from?
Crewe ETD, should be followed later today by 67014, that's supposed to go on HD02 and go on a trial run tomorrow, if that's successful it will allow HD04 to stand down for its B exam from Wednesday.
HD05 is also heading over to Crewe ETD for tyre turning today.
Jacob Porrett
28 Jan 2022
Telford
Today at Crewe depot (14/4/25)
67013 connected to HD05
67022 light engine
67014 worked 0T45 from the ETD. It then was put into HD02.
67014 now connected to HD02 which is to go on test run tomorrow.
sd0733
7 Nov 2012
Not ready now so planned to go tomorrow (Wednesday) for test run, gives HD04 yet another reprieve before it stops for it's exam!
67025 is planned to swap off HD03 when it arrives into Cardiff from Manchester tomorrow morning with 67016 taking over for the afternoon Manchester and back.
Jacob Porrett
28 Jan 2022
Telford
Is HD05 at the wheel lathe because it isn't at Crewe depot today?
Welshguy1048
6 Apr 2023
Prestatyn
@sd0733
Hi
Could you please give me a list of which locos are with which set please ? - including the numbers of the DVT's.
I had a list on my old phone - got a new phone now - but cant access my old phone!!
Thank you
Dave
37052 xb mr
6 Dec 2023
Stockport
@sd0733
Hi
Thank you
Dave
Should be
67008 set 1
67014 set 2 Due Test Run
67025 set 3
67029 set 4
67013 set 5 Wheel Lathe
67017 set 6
67010 set 7
67012 Toton repair
67015 Cardiff
67016 Cardiff
67020 Crewe EMD repair
67022 Crewe ATC
sd0733
7 Nov 2012
@sd0733
Hi
Thank you
Dave
All formations in posts 2092 and 2093 are correct. The only change coming up will be 67016 replacing 67025 on HD03 tomorrow.
Welshguy1048
6 Apr 2023
Prestatyn
Should be
67008 set 1
67025 set 3
67029 set 4
67017 set 6
67010 set 7
67012 Toton repair
67015 Cardiff
67016 Cardiff
67022 Crewe ATC
Should be
67008 set 1
67025 set 3
67029 set 4
67017 set 6
67010 set 7
67012 Toton repair
67015 Cardiff
67016 Cardiff
67022 Crewe ATC
@37052 xb mr
Thank you
Dave
