Thameslink 1st class seating provision? Is it more or less?
GodAtum
11 Dec 2009
Am I right in saying there are less 1st class seats on the class 700 than there used to be on the old trains before they were introduced? The Southern class 377, for a 12 coach, has at least 60 1st class seats.
Failed Unit
26 Jan 2009
Central Belt
Depending on what you compare with.
8 car 700 -v- 8 car 365. Same.
8 car 700 -v- 8 car 319. More
12 car 700 -v- 12 car 365 less
12 car 700 -v- 12 car 319 more.
assuming the 319 had 1st in one end of each 4 car set.
standard class seats reduced significantly on both comparable units.
This is first class seats. If you consider the rear declassified section the 700s have less.
GodAtum
11 Dec 2009
Yes I am not counting the rear section of the 700 as it's declassified. How how 1st class ticket holders reacted? I can imagine a lot of them renewing their season tickets to standard if they often fail to get a seat.
Failed Unit
26 Jan 2009
Central Belt
Not seen first class full on departing Finsbury Park so don’t think it has caused an issue on the former great northern routes.
the London - Cambridge I am not sure as the 387 doesn’t really have 1st class anymore, people are paying for the seat. When you see them and the 365s passing Finsbury Park it doesn’t look like the 1st class passengers will be disappointed.
aleggatta
28 Sep 2015
it's worth noting, that when the 377s/387s were in service on TL, only one end of first class was in service, i.e. 30/36 per 12 car dependant on exact seating layout
Ianno87
3 May 2015
Casual observation of on the Cambridge fasts in the peak is first class maybe 40-50% loaded on the 387s....
...though not necessarily all with First Class tickets of course.
Royston Vasey
14 May 2008
Cambridge
No, but you may be right in saying there are fewer.
Minstral25
10 Sep 2009
Yes - where Southern 12 car 377's along the Redhill route were swapped with Thameslink Class 700's there was a drastic reduction in first Class provision along with a large increase in Standard Class Fares (Southern Only Fares ceased to apply so fares went up a lot)
