Thameslink timetable improvements
MML
25 Oct 2015
The current timetable has no trains from London to Bedford from 0101 to 0618 on a Sunday.
While a 24 hour service does operate Monday to Saturday, the lack of any trains early on a Sunday does mean it can be difficult for night revellers to return from a Saturday night out in London and equally makes travelling to/from London Luton Airport impossible for late night or early morning departures on a Sunday.
Is there any intention to introduce a true 24h/7 days a week service linking London and stations along the MML with Luton Airport ?
A typical timetable utilising 4 units/drivers would permit an hourly all stations service to Bedford and an hourly all stations service to Luton each departing St Pancras at 30 minute intervals (albeit with an hour interval between 0230 and 0330).
Overnight track maintenance work may prohibit use of platforms A and B for cross London transfer some of the year, but it should be possible to utilise high-level platforms 1-4 at St Pancras instead or indeed on occasions terminate services at Kentish Town where interchange is possible with Northern line night-tube services.
With MML being 4 track, it should be possible to operate this limited overnight service even if 2 of the tracks are closed for maintenance possession.
STP LUT BDM BDM LUT STP
01:00 01:50 02:20 02:30 03:00 03:50 Unit 1
01:30 02:20 02:30 03:20 Unit 2
02:00 02:50 03:20 03:30 04:00 04:50 Unit 3
02:30 03:20 03:30 04:20 Unit 4
03:30 04:20 04:30 05:20 Unit 2
04:00 04:50 05:20 05:30 05:00 06:50 Unit 1
04:30 05:20 05:30 06:20 Unit 4
05:00 05:50 06:20 06:30 07:00 07:50 Unit 3
Aictos
28 Apr 2009
Can you explain the timings better please as I can't understand them.
Pumbaa
19 Feb 2008
Simply put, no. The entire 4 tracks are blocked overnight for maintenance, and then 2 come off to allow the Sunday morning service. All back in use by midday Sunday. Not dissimilar to other mainline routes.
If you want Saturday night access, you’ll have to give up access elsewhere to allow it to happen.
MML
25 Oct 2015
But I guess that's a no then. Can't be done with all 4 tracks closed.
No plans. As @Pumbaa says, it is the one opportunity a week for an all line block to enable such things as headspan inspection and repair, signalling system checks, power system checks, etc etc.
It is also the time used for all Thameslink core maintenance, including patrolling and defect removal. To be honest it’s not really long enough, in my opinion.
Besides, Luton airport doesn’t have any ‘late’ departures on a Saturday night. Typically it has only three after 2000, with the last at about 2230; so well within the train service operating hours. (Unless you are catching a private jet, or the DHL freighter, in which case you’d make separate arrangements!)
There’s very few late Saturday arrivals either; almost all are in by 2300, plenty of time to get the last London train.
The issue is early departures on Sunday morning, ie the first wave of Easyjet and WizzUK departures from 0600-0800. However speaking from personal experience, some very recently, the number of people who catch the train for the very early flights is pretty small when the trains are running on Mondays - Saturdays. The last few trips I’ve done at that time (for 0600ish flights) have seen an average of around 15 people per bus on the 10 minute interval airport link.
Even then, the last train from London on a Sunday morning before closedown is 0143. Plenty late enough for most revellers, and also doable for people catching flights the next morning. That train gets you to the airport station 0230, the airport just before 0300, and Wizz check in opens 0330, Easyjet 0400. I know a number of people who have done that.
MML
25 Oct 2015
I'm on yet another 8 car unit which is operating Brighton to Bedford and will no doubt be rammed leaving London during the peak. When can we expect a follow on order to ensure sufficient core services between Bedford and Brighton are all operated by 12 car units ? And sufficient stabling is provided ?
Siemens will stop manufacturing the model before long and then we'll never maximise route capacity.
And why is the platform at Blackfriars only utilised by a half-hour interval service to Sevenoaks ? I would have thought platform capacity at a London terminus would be at a premium during rush hour.
Horizon22
Jobs & Careers
8 Sep 2019
SE extras in the rush hour from 3&4 at Blackfriars
MML
25 Oct 2015
SE appear to depart from platform 4, but Thameslink service to Sevenoaks depart from platform 3. But there is only one train every half hour. You'd think Sevenoaks would have a 15 minute interval service during the peak.
Kite159
27 Jan 2014
West of Andover
I'm sure in the past there has been 4tph around the Bat & Ball loop to call at all the stations (Shoreham etc). Maybe in the days of
(*breaking out the crayons*
For the peaks divert the 2tph to Orpington to Sevenoaks (via Bat & Ball) and extend the 2tph SE services which terminate at Bromley South to Orpington to maintain 4tph Bickley to Petts Wood)
Aictos
28 Apr 2009
Why is 10tph not enough for Sevenoaks passengers to get to London?
The majority of the services serve Cannon Street or Charing Cross and as the Blackfriars services are peak extras, the frequency is more then enough.
30907
I'm sure in the past there has been 4tph around the Bat & Ball loop to call at all the stations (Shoreham etc). of
The Sevenoaks service in the peaks has never been more than 3tph beyond Bellingham or Shortlands/Bromley S. Before the present pattern was introduced the evening peak on the Catford Loop was only half hourly, so I imagine the present service is an improvement. Things have changed massively since I commuted from SRT in the 60s/70s.
Extending the Bromley S terminators to Orpington would be a welcome move locally AIUI though it isn't really justified by loadings IME.
The Blackfriars services are not peak extras (they've run all day since Sevenoaks was electrified well over 80 years ago) and obviously don't run primarily for Sevenoaks-London passengers.
Kite159
27 Jan 2014
West of Andover
It's more for the passengers for Eynsford, Shoreham & Bat and Ball. Any passengers for Sevenoaks itself won't be using the Thameslink service to travel to central London as they are stoppers, like how any passengers for Central London will tend to ignore the South Eastern stoppers
When you say ‘yet another’, I’d be interested to know how many times you have experienced an 8 car on a service planned for 12. It happened to me for the first time in months this morning.
MML
25 Oct 2015
4th time and all due to unplanned service disruption. There are other planned 8 car services which I make a specific choice to avoid since they become more crowded than those operated by 12 car units.
I would suggest Thameslink have 6 units which should be 12 car rather than 8 and I was wondering whether Thameslink are intending to remedy the situation.
Don't get me started on the retrofit of seatback tables which was promised but not delivered.
On the GN side we of course have an 8-car diagram on the Cambridge to Brighton service, which just happens to hit the peak flow going into and coming out of London. So peak passengers don’t need unplanned short forms, turn up at a particular time and it will be an 8-car 100% of the time!
It doesn’t seem uncommon for 8-cars to turn up at weekends during altered working, either planned or otherwise, on what are theoretically 12-car routes.
Ok. 4 times in 3 years of service is a much lower rate of short forms than in the 319 / 377 days.
To answer the question - Thameslink have no plans for extending the trains but that’s because the Government have no plans.
43074
10 Oct 2012
Equally Eynsford, Shoreham and Bat & Ball are not the centre of the universe to be frank, I'm not sure they justify 4tph in the first place.
Aictos
28 Apr 2009
Indeed, in over a year of using the network I’ve only had a short form happen once which by a strange confidence was yesterday as it’s booked a 12 car but for whatever reason a 8 car turned up.
If they did justify 4tph then those services would be already running.
As to increasing the number of services from Sevenoaks to Blackfriars, which existing services would need to be removed to make room for the proposed services?
There’s plenty of services that people can use to get to London, no need for even more services which gives other passengers a worse service as a result of their services being cut to make room.
Horizon22
Jobs & Careers
8 Sep 2019
Very much doubt there's capacity between Shortlands & Bickley (or Catford loop) for an increase in additional TL services. Indeed the curtailing of 2tph of Victoria - Orpington stoppers at Bromley South was to make room for the additional TL services.
Aictos
28 Apr 2009
My point exactly about how existing services would have to be cut to provide capacity for any more additional services ie it’s not a good idea.
SE%Traveller
23 Jan 2020
The Sevenoaks Services are supposed to only use the bays at Blackfriars off peak, during the peaks they're supposed to go through the core to Welwyn. There doesn't appear to be any firm date on when they intend to implement that (it was supposed to be May 2019) so any additional services in the peaks (specifically the proposed southern London Bridge>Sutton>Wimbledon>Blackfriars service) are on hold until they do.
AIUI December for Sevenoaks - Welwyn. As reported on another thread somewhere!
SE%Traveller
23 Jan 2020
If there was a book running on such things, I’d bet my mortgage on Welwyn - Sevenoaks for December.
Good to know! any idea on when Orpington Kentish Town weekend services are to start? they're another thing quietly dropped it would seem
Aictos
28 Apr 2009
Well this Sunday has the unusual luxury of Luton to Rainhams bearing in mind Sunday’s usually only have Luton’s to Sutton via Wimbledon so is it not possible in the future sometime to have a 7 day service between Luton and Rainham?
westcoaster
4 Dec 2006
DTOS A or B
Engineering works at Herne Hill so no sutton services running, so move the rainham service to luton to compensate.
Aictos
28 Apr 2009
Ahh okay, just never heard of the Rainhams on a Sunday at Luton before.
