robertclark125
Something that's always puzzled me, the eight buffer fitted class 43's, 43013/4, 43065/7/8, 43084 43123. They were used as surrogate DVTs with the class 91s and Mk3 stock, until the mk 4 stock and DVTs came online.
What's puzzled me is why they were fitted with buffers. After all, if a HST failed, the door was opened up under its nose, the coupling eye pulled out, a drawbar attached, and then attached to a locomotive to pull. Pretty simple (in theory if not in practice).
For the surrogate DVTs, the lower end of the nose section was removed, and conventional buffers fitted, with a drawhook. A screw coupling was carried in the engine bay. The main resevoir and brake pipes were fitted as normal, as were the 3 phase train supply jumper/sockets.
So, why was it neccessary to fit buffers to these eight surrogate DVTs?
