The Cuneo Centennial
Coxster
9 Jun 2005
Myself and Dad will probably be seeing it at Winchfield for it's water stop. Runs this Saturday.
LMS Class 8P 4-6-2 no 46233 Duchess of Sutherland
1Z92
London Waterloo 08.42
Clapham Jc 08.51
Housnlow 09.22 - 09.25
Feltham Jc 09.32
Staines 09.42 - 09.43
Addlestone Jc 10.10
Woking 10.24 - 10.26
Farnborough 10.40
Winchfield 10.51 - 11.07 [WATER STOP]
Basingstoke 11.19
Andover 11.45
Salisbury 12.05 - 12.19 [WATER STOP]
Tisbury Loop 12.37 - 12.43
Gillingham 12.55 - 13.19
Templecombe 13.28
Sherborne 13.40 - 13.45
Yeovil Junc 13.57
1Z93
Yeovil Jc 16.36
Sherborne 16.48 - 16.50
Templecombe 17.01
Gillingham 17.10 - 17.16
Tisbury Loop 17.31 - 17.37
Salisbury 17.52 - 18.27 [WATER STOP]
Andover 18.50
Basingstoke 19.14 - 19.34 [WATER STOP]
Farnborough 19.51
Woking 20.05 - 20.08
Addlestone Jc 20.18
Staines 20.42 - 20.44
Feltham Jc 20.57
Housnlow 21.05 - 21.08
Barnes 21.22
Clapham Junc 21.31
London Waterloo 21.44
Ta uksteam.info
4 Nov 2005
Parkstone
u see coz its a ****ty midland engine it has to have 2 water stops on each leg of the tour, our good old southern engines only need one!
Will be seeing it in the evening at Waterloo having returned from manchester!
devon_metro
11 Oct 2005
And 5 sanding coaches ;)
*runs*
kettlefan
3 Dec 2006
Chertsey, a pathetic town in the south
4 cylinders make a nicer sound than "wuffity wuffity wuffity" therefore the extra water consumption is justified!
I just look forward to seeing something that isn't SR!
960012
4 Nov 2005
Parkstone
Has been retimed
Because taht stupid piece of midland rubbish is to big for the turntable at Yeovil also there were gauging issues!
I will be seeing it tonight at Clapham Junction and then tomorrow at a number of places!
Friday 27th April 2007
6233 + POB 5Z61 09:35 Butterley - Clapham Junction Yd (20:20)
47+load9 set WC988 5Z92 12:34 Carnforth WCR - Clapham Junction Yd (19:20)
'The Cuneo Centennial' - Saturday 28th April 2007
Duchess now coming off at Salisbury, with 47 forward to Yeovil
Junction - which will disappoint some and please a few....
Been told turntable may be a bit 'tight' so WCR not taking any
chances ?
5Z92 - Formed 47 + load 10 + 6233
Clapham Junction Yard 08:01
Waterloo Plat 16 08:14
1Z92 NC 08:42 Waterloo to Yeovil Junction
Waterloo Plat 16 Dep 08:42
WLS
Nine Elms Jn. 08/47
Clapham Junction Plat 6 08:51½
Barnes Plat 4 09/00
Hounslow Plat 2 Arr 09:22 Dep 09:25
Feltham 09/32
Staines Plat 2 Arr 09:42 Dep 09.43½
Virginia Water 09/51½
Addlestone Jn. 10/01
Byfleet & New Haw 10/16
SL
Woking Plat 5 Arr 10:24 Dep 10:26½
Farnborough Main 10/40
Winchfield Arr 10OP51 Dep 11OP07 [Water]
Basingstoke Plat 1 11/19
FL
Worting Jn. 11/25
Andover 11/45
Tunnel Jn. 12/01
Salisbury Plat 4 Arr 12L05 Dep 12L24 [remove 6233, shunt 47]
Wilton Jn. 12/27½
Tisbury Loop Arr 12X38½ Dep 12X42 [Pass 1O92]
Gillingham (Dorset) Plat 1 12/52
Templecombe 12/59
Sherborne Arr 13:06 Dep 13:08
Yeovil Junction Plat DS Arr 13:15
0Z62 - 6233
Salisbury Plat 1 13:18
Signal SY240 13RM20 13RM23
Salisbury Plat 4 13OP25 13OP34
Tunnel Jn. 13/41
Laverstock South Jn. 13RM43 13RM49
Laverstock North Jn. 13RM52 13RM55
Tunnel Jn. 13/57
Salisbury Plat 4 14OP06 14OP08
Signal SY240 14RM10 14RM13
Salisbury Plat WCS Arr 14:15 Dep 17:16
Signal SY240 17RM18 17RM21
Salisbury Plat 4 Arr 17:23 Dep 17:25
Salisbury S.S. East Loop 17:28
1Z93 NC 16:41 Yeovil Junction to Waterloo
Yeovil Junction Plat DS Dep 16:41
Sherborne Arr 16:50 Dep 16:53
Templecombe 17/01
Gillingham Arr 17X09 Dep 17X16 [Pass 1L45]
Tisbury Loop 17/25
Wilton 17/34
Wilton Jn. 17/46
Salisbury Plat 4 Arr 17L49 Dep 18L26½ [Shunt 47, add 6233]
Tunnel Jn. 18/30
Andover 18/50
Worting Jn. 19/10
SL
Basingstoke Plat 4 Arr 19OP14 Dep 19OP34 [Water]
Farnborough Main 19/51½
Pirbright Jn. 19/56
Woking Plat 1 Arr 20:05 Dep 20:08
Byfleet & New Haw 20/15
Addlestone Jn. 20/18
Virginia Water 20/29
Staines Plat 1 Arr 20:42 Dep 20:44
Feltham 20/54
Hounslow Plat 1 Arr 21:05 Dep 21:08
Brentford 21/15
Barnes 21/22
SL
Clapham Junction Plat 3 21/31
WSL
Queenstown Road 21/36
Nine Elms Jn. 21/38
Waterloo Plat 16 Arr 21:44
5Z93 NC
Waterloo Plat 16 22:00
Clapham Junction Yard 22:20
Ta YK and RS
matt
30 Jun 2005
Rugby
Theres nothing wrong with the turntable, its due to engineering works elsewhere thats made it out of gauge
Jim
11 Jun 2005
Wick
Is this loco not banned West Of Salisbury due to gauging issues?
T
Tom
Guest
From SWRG
Re the Duchess, I'm advised that it's not the weight, but a gauging problem with a bridge on the up side
between Sherborne and Templecombe. Apparently, recent tamping has left the up side line higher than the down. The loco could go down but it couldn't get back as the dual directional working is catered for on the up line only. Something referred to technically as sod's law, I believe.
Ta GB/RT
kettlefan
3 Dec 2006
Here's the two pics I got of the train, unfortunately when I tried to get a front end view, I had the camera switched off and quickly turned it on and pressed the button in rapid succession, so the focus came out terrible. I was able (in between looking on in awe at the engine) to get shots of the Duchess going under Chertsey footbridge, closely followed by 57 "Sheila".
T
Tom
Guest
Saw it at Salisbury....doing the pics now.
None of that boring unit in my gallery ;)
thefab444
27 Oct 2006
The New Forest
A selection of my shots of 6233 passing Worting Junction, and 57601 on the rear.
Apologies that these photos aren't quite as good as they could've been, this is due to still being on Auto mode with my new camera and probably standing in the wrong place.
Kris
14 Feb 2007
Where's that? Don't recognise it unless they've done some building work in the 3 years since I've been away from the W.O.E. line.
Engines and stock still in the yard at Clapham this morning - although the Duchess was alongside facing towards W'loo.
Aureol
29 Sep 2005
With a spanner in hand in D212's engine room
Thanks everyone for your support and excellent phots for the Cuneo Centennal.
The train didn't consist of any Mk1's apart from the Support Coach, the standard class being Mk2's ;)
Anyway, the stock, I believe will be headng back to Carnforth today and the Duchess and Support Coach will be returning to our shed at Swanwick ready for me to clean it tomorrow.
The people who made it happen.
6233 owners and operators PMR Tours pose next to the train at Yeovil Junction. (I'm on the extreme left of the pic.)
Oracle
19 May 2006
Near Ashurst New Forest Station
Where's that?
New(ish) Park N Ride at Salisbury between and opposite the BP garage and the two railway bridges at Bishopdown. Laverstock is in the distance, and the signal with feathers controls the entrance to the Laverstock Loop at Laverstock North Junction I think it is. Train is therefore running Up in the Andover direction.
Kris
14 Feb 2007
Aha! Thanks. Last I saw it was a field with a burnt out Citroen and gypsy caravans (not burnt out).
Oracle
19 May 2006
Seen it developed from a field into what you see plus the shelter with bus layby. However why on earth did they not put a station there? The BREWSTER'S, i.e. the Bishopsdown, is now a Brewer's Fayre again. The pic with the 3-door silver car in it shows the train headed for the arched railway bridge a 100 yards south of the pub/restaurant.
960012
4 Nov 2005
Parkstone
I saw it 7 times over the hole day and took something like 270 odd photos will sort through them tomorrow and post them up
Ok i must say it is a nice engine BUT it still doesnt beat a Bullied!
Oracle
19 May 2006
O.V.S. Bulleid forever!
I know this is totally off-topic but in the pix of Worting Junction are two #-overs from the Up-Down Fast and Down-Up Fast respectively. I gathered from another post that the Down Fast (at least) is now reversible as it is dual-signalled? The evidence was in the photo of an Up Virgin X-Country by-passing a SWT 159 train and also a EWS? train on the Up Slow, which had stopped after passing a red and thus causing an overlap problem.
Also, more on-topic, the loco turned round via Salisbury Tunnel Junction- Laverstock South Jn-Lavestock Loop-Laverstock North Jn (to the right of the signal with feathers). All this I can imagine was signalled except for the reversal from the Down Romsey I think it is called back towards the South Jn. Is there a signalled movement at that Junction?
