The Ebor Flyer and aftermath of Tornado's failure.
gtis
15 Apr 2009
darfield sth yorkshire
hi i have looked on real train times
For the times but they are not showing
Has anybody know the times mainly when going through Doncaster
Neil
Spartacus
25 Aug 2009
I imagine it might be being kept quite to prevent any lineside shenanigans, (train planning are also running very late in general) but if it isn't in the standard 0818 KX path by Doncaster (1055), I imagine it'll be close to it.
marcouk2
24 Jan 2012
Reportedly hit something on the track and sustained damage, rescue loco on the way.
38Cto15E
1 Nov 2009
15E
Opentraintimes showing 1Z99 in front, presumably Thunderbird, also 1D08, whether that is assisting?
Cowley
15 Apr 2016
Devon
Was this tour scheduled to run at 90 mph does anyone know?
Any word on what it hit or whether something on the loco became detached?
Hopefully not too much damage done.
Suraggu
23 Oct 2013
The Far North
The A1 Trust have said that due to damaged inside motion but not thought to speed related.
I have read wibble about a drone being used and hitting the train but that is pure wibble.
Andrewh32
11 Dec 2017
Tornado is now at the Nene valley railway to allow proper inspection, hauled by 66744 to Orton mere & then one of NVRs Class 14s from Orton mere to Wansford
Spartacus
25 Aug 2009
What do they mean by inside motion
As stated on they web site
Neil
What happens to the footplate crew when something goes bang at 90mph, and you hope it doesn't become an outside motion because then you'd need new overalls!
Seriously though it's all the mechanical gubbins that's involved with connecting the inside cylinder to the driving wheels, similar to what you get on the outside.
Just been doing a bit of research and according to https://www.a1steam.com/valvegear-and-motion/ the part which has reportedly failed was delivered with small manufacturing misalignment which had to be corrected. This might not be the actual point of failure, but it makes you wonder, especially as they seem pretty convinced that it wasn't a speed issue.
malc-c
1 Dec 2017
Watched a few videos last night and one showed a guy in full high-vis standing between the rails which what looked like the bottom end of a bearing case ( U shaped with bolts either side), that must have caused a hell of a bang when it dropped. So if they feel the failure is not speed related, then other than component failure one other possibility that has been rumoured could be sabotage, which I doubt, and strongly hope isn't the case, but with reports saying it hit something I guess can't be ruled out.
Andrewh32
11 Dec 2017
Given the crew didn't know the reason behind the failure when I had a quick word, anything that has been said is pure speculation
malc-c
1 Dec 2017
I agree, as is the rumour that it was a low flying drone that was hit.... I doubt that as I'm sure the drone would have come off far worse than the loco !!
I presume that either following the 100mph time trial, or preceding this run, the loco would have been inspected to make sure everything is as it should be (loose bolts etc). Lets hope they don't keep us in suspense too long and reveal their initial findings soon.
Andrewh32
11 Dec 2017
Just seen a tweet from Ian Prosser to say that the ORR will be looking into the failure of Tornado so we will know everything in time (sorry can't make the tweet paste into here)
malc-c
1 Dec 2017
Considering that there were no injuries to anyone, and (as far as I know) no damage to the infrastructure or track, why would they get involved, unless there's more to yesterdays events than we currently know. There are so many speculative reports flying around, from component failure to a dog being hit and causing the damage, it would be nice if the trust, tour operator or some official simply confirmed one thing or another, and rule out these stupid speculations. If it was a case where nothing was hit, and it's pointing towards a component failure then put up an announcement, we can then wait to hear the more detailed report later.
Andrewh32
11 Dec 2017
The tweet says which might give a clue or two
"We will be looking closely at the Tornado failure on it's first partial 90mph run with Mk2 stock. Caused significant delays to services south of Peterborough"
Darandio
24 Feb 2007
I think you might be confusing the ORR (Office of Rail and Road) with the RAIB (Rail Accident Investigation Branch) where the latter might have got involved should there have been injuries or damage.
The ORR will be interested because if there is an issue with higher speed running that could happen in the future at large cost to the railway, then they would be looking to revoke the certificate.
malc-c
1 Dec 2017
Right, I hear you. I'm terrible at puzzles, so I'm guessing the clue Andrew is eluding to is the use of MKII's ?? And reading between the lines in Darandio's post, given how crowded the ECML is becoming could this be the nail in the coffin for mainline steam specials ? Would the revoking of the main line certificate be permanent ?? - there would be an outcry from the fans if it were !
Darandio
24 Feb 2007
I think the clue was the specific use of the word 'Failure'.
No, not a revoking of the main line certificate but the one that gives dispensation to run at higher speed.
malc-c
1 Dec 2017
I told you I was crap at puzzles :)
Ahh, so it would be limited to 75mph like most other steamers. Thanks for the explanation
Darandio
24 Feb 2007
Yes, all assumption at this stage though. I cannot see any other immediate reason.
Andrewh32
11 Dec 2017
Was also thinking about the word first, so was proper testing, training, risk assessment done. So how they decided Tornado was upto 90mph with that stock.
Remember in the past ORR have made WCRC change alot of process & proceed, so looking at the same sort of things.
I would agree that I would expect 75mph running in the future as the outcome.
Spartacus
25 Aug 2009
We'll see anyway. From what I've said before the part may not have been 100% to start off with, and in the 11 years since it was corrected it might have been forgotten about, but then again the failure may be completely unrelated to this, and after all in the days before modern toolings and production methods were widespread a bit of fettling to make things fit was expected.
