The white panels below the platform?
Harbon 1
30 Apr 2011
Burton on Trent
Can anyone tell me what the white panels, fixed to the side of the platform with the red sliders are for
Cheers, matt
Ps. I'll post a picture later if nobody knows what I'm on about!
Wyvern
27 Oct 2009
From the other thread:
They are called 'Datum Plates'. They are used to moniter the relative movement of the track in relation to adjacent structures.
Top left number is the number of the datum plate, one below is is the Lateral Offset to the plate. i.e. The distance, in milimeters, from the structure to the running edge of the rail. The next one denotes the line. UM = Up Main, etc.
At the bottom is the designed cant of the track.
They are only used when the track runs closer than 3m from a structure, not on all electrified lines as mentioned above. If the plate was fitted with a Red slider, it shows the track condition at the moment the plate was installed, where as if it was Green it would show the designed track possition.
Where a route hase ABT (Absolute Track Geometry) the whole route must be fitter with datum plates, and the slider will always be green.
Hope this helps.
OxtedL
Quizmaster
23 Mar 2011
Check out this: http://www.railforums.co.uk/showthread.php?t=46479
Yup, it's a datum plate.
The "switch" to which you refer is moved up or down (originally) to show the track level, and does not switch.
Check out any of the previous threads on this.
Try http://www.railforums.co.uk/showthread.php?t=44972 or http://www.railforums.co.uk/showthread.php?t=41255
Or http://www.railforums.co.uk/showthread.php?t=20924 .
Or http://www.railforums.co.uk/showthread.php?t=39072 .
Or http://www.railforums.co.uk/showthread.php?t=28790 .
:D
ralphchadkirk
20 Oct 2008
Essex
Can we please have an explanation of this stickied? This question seems to pop up every month or so.
Noguidedbus
7 Aug 2011
Answered a question I have pondered for 20 years before I got around to asking it. If only the rest of life was as simple.
