Thornaby Items in the Four Foot
MOONY
15 Jan 2009
Hi,
Could someone please explain what these items are in the four foot on the approach to Thornaby please?
MTIA,
Moony
3973EXL
2 Feb 2017
Sleeper anchors to maintain track alignment on the curve.
ASharpe
4 Feb 2013
West Yorkshire
Is it normally the cant that prevents lateral movement?
Would these just be a retrofit if movement was detected?
Or is it to do with thermal expansion or something else?
I think they are a relatively new way of achieving the aim, but there were other means of doing so previously, typically there were “L shaped” plates screwed to the ends of the sleepers, but they were not so visible, so possibly not mentioned so much. These anchors possibly can be retrofitted if there’s a problem, but they are often fitted at renewal as well, presumably if curvature requires.
IIRC in a previous discussion it was explained that an advantage of the new anchors is that they can be slackened off before tamping, and then retightened afterwards.
ac6000cw
10 May 2014
Cambridge, UK
As I understand it:
Cant is used to allow trains to go safely around curves faster, so (mostly) in effect it makes the problem worse as more centripetal force has to be applied by the track to make the train change direction (follow the curve) at the higher speed. The 'equal and opposite' force to that is what tries to make the track move laterally, which is resisted by the ballast and (if fitted) the anchors.
Think about swinging a ball-on-a-string around in a circle - the faster the rotation, the harder you have to pull on the string (apply more centripetal force) to stop it flying off at a tangent.
(Cant has the effect of translating some of the otherwise entirely lateral curving force into a vertical component, thus reducing the lateral force component for a given speed, so in theory there is some benefit from it in this context, but AFAIK it's mostly about increasing speeds and reducing railhead wear on curves).
