Ticket - breaks in journey
Mtrain
22 Jan 2019
Hi. Can someone tell if it is at all possible to do this journey on a
LEDBURY TO BRISTOL day return. I know the routes are fine it’s how I break the journey
Using the outward portion
1: Hereford to Newport
2:Newport to BPW
using the return
3: BPW to Cheltenham
4: Cheltenham to Ledbury
5: Ledbury to Hereford
thanks
JB_B
27 Dec 2013
That wouldn't be valid - see national rail conditions of travel condition 11.3 :-
https://www.nationalrail.co.uk/National Rail Conditions of Travel.pdf
"11.3. A return Ticket must be used in the correct sequence (you must use the
outward portion of your return Ticket before you use the return portion). The
outward portion of a return Ticket is no longer valid for travel once the return
portion has been used"
Mtrain
22 Jan 2019
Thank you I thought it wasn’t just would have saved a lot of money.
pelli
15 Sep 2016
Just to be clear: You can still do the first four steps on that ticket ("starting short" at Hereford -> Newport -> Bristol, then returning Bristol -> Cheltenham -> Ledbury). You just need to buy a separate single ticket to cover the final hop from Ledbury back to Hereford, which may or may not cost less than the "lot of money" you're saving...
AlbertBeale
16 Jun 2019
Wouldn't a Hereford to Bristol return do the trick? Isn't a route from Bristol to Hereford via Ledbury valid?
JB_B
27 Dec 2013
Unfortunately, I don't think that's a valid route.
a) The only mapped route is on map MP - that only allows via Newport not Ledbury;
b) The shortest route is also via Abergavenny - that's a lot more than 3m shorter than any route via Ledbury;
c) I don't believe there's a through train via Ledbury (I could be wrong - I've not checked exhaustively); and
d) I don't think there's any easement that would help (ditto)
AlbertBeale
16 Jun 2019
Aha - sorry - I'm no expert. I just looked at a map and used my (erroneous) common sense!
I'd found in the past that some permitted routes were much much more varied than I'd expected (eg from the middle of the Heart of Wales Line to London, you can zig-zag all over the place, via Swansea, or Crewe, Newport [from Swansea or Shrewsbury], on all sorts of routes through the midlands or southern England, and so on), and in my amateurish way I imagined that most routes were that flexible...
30907
Ledbury to Bristol is equidistant via the two routes, but Hereford is 70m direct vs 100m via Worcester.
By contrast the various HoW main routes to London are within 10m (Crewe longest, Llanelli shortest to the midpoint).
Mtrain
22 Jan 2019
Ledbury to Bristol via Hereford and via Worcester are valid routes. Just cheaper to do it that way then buy a ticket from Hereford to Cheltenham Spa
Mtrain
22 Jan 2019
It would have been a £1.20 saving even if I did but the extra ticket the final leg. Still worth doing
