Well, that's another way to prevent the recurring overhead problems at RetfordBoth radio 4 and twitter are reporting that very early this morning Tornado ran an test train between Newcastle and Doncaster that, somewhere between Darlington and York was permitted to run at 100mph - apparently the first time this has been allowed since 1967.
What sort of infrastructure access charge is made for moving a 157t high axel load machine at that speed?
blind eye turned for a one off i should imagine!
( apologies - i missed the thread in the preservation section)
Who would be liable for any damage caused? I seem to recall that BR limited steam to 60mph. Even the Class 86 as built (80t - 4 axels) did enormous damage at 100mph.
According to Heritage Railway magazine's facebook newsfeed, it was an authorised run as part of the certification process to allow Tornado to run at 90mph on NR metals. 101 mph was achieved.
Anyway such a fine example of Darlo built engineering wont damage the track at all
Who would be liable for any damage caused? I seem to recall that BR limited steam to 60mph. ...
... Gobackery akin to returning to blue passports, Imperial measures and £sd.
Our friends across the channel must be highly amused.![]()
60 mph? This may have been true for specials run after 1968 - but prior to that there was no such limit. Even the very last regular steam-hauled train hit 68 mph between Preston and Liverpool, IIRC.
AIR, even in the early 1960s on the WR there was no general upper limit! It was up to the driver, except for PSRs and TSRs. The majority of steam locos didn't even have a speedomter until quite late on. I think the SR had an upper limit of 85 mph, but I'm not sure when that came into force. As diesel and electric traction was introduced, someone realised they needed a general upper limit. and, of course, both diesel and electric had their design limits indicated on the speedometer - at least in the classes I was ever on.
load 8+loco I think. Good weight behind it
When Tornado was built and first tested on the mainline it was run at about ten percent over the 75mph normal running speed. I suppose this is the same situation, running at around ten percent above a 90mph upper top speed.
It must have been quite an experience for the footplate crew.
Does anyone know what the load was?
Even more kudos to the drivers who drove trains with no speedometer and no lineside speed limit boards - having to know all the limits and turnouts and judge compliance.
Indeed the trains went round like thieves in the night with scarcely a light to help the driver or help anyone else for that matter.
Yes, I think in many ways, driving steam (both expresses and unfitted goods) probably took more of a skill-set than it does today - certainly a different skill-set. But there was far, far more leeway for footplate crews.
In general, high-speed running ie above 90 mph for steam, was not the norm. If you look at most logs of steam-hauled trains, there is typically little time spent above even 80 mph, except at known spots, such as Andover on the LSWR, Essendine down Stoke bank and the long decline between MP 34 and Bedford on the down, plus Sharnbrook on the up, on the Midland.
There were a handful of regular exceptions, such as The Bristolian, which demanded speeds of 80-85 mph for most of its route to keep time, but otherwise schedules had to be constructed according to average conditions - locos, crew and fuel. This meant that any crew that might have wanted to push their speeds ended up ahead of schedule and facing signal checks, or waiting time at stations. The only time high speeds were normally attained - of 95 mph plus - was when late running came into play, and crews were keen to make up time - it helped if it was their last duty, and a 'home run' as it were. (I think this is still true, to an extent, today.)
There were other odd exceptions associated with 'last flings' from enthusiastic crews before diesel or electric traction took over: these included a Royal Scot on a Sunday working near Ampthill Tunnel (100 mph achieved according to the loco speedo, I guess this was in 1960) and, most famously, a spate of 100 mph+ runs with Bulleid pacifics in the early summer of 1967.
10(?) MKii and a 67
So, assuming that included quite a few Commonwealth bogies on the stock, around 275-280 ton trailing load. Easy-peasy for an LNER pacific in fine fettle on level track.![]()
A bit of digging on Youtube, and here she is: https://www.youtube.com/watch?v=xbbIhZAkpiU
Is that the MK3 rake that Tornado will run with once it gets its 90mph cert?- are they looking at powering the aircon with an external generator van (as was common in Ireland) or use the back up diesel?
