GRALISTAIR
The magic new technology that the Southern Region first introduced in 1962...
Aka the Class 73 electro diesel as commented on by Roger Ford in September 2017 Modern Railways
But we come back to point that the Government doesn't have a bottomless pit of money and Network Rail didn't just Blow the budget it tore to shreds.
In terms of future Projects it strikes me that the Cardiff Valleys is probably a better priority than Cardiff Swansea.
A program of rolling electrification is still not the wrong option and has been made more pertinent by the dash to electric vehicles in a pan European policy shift. We have no idea what impact Europe's oil consumption dropping will have on world markers and production. As it involves a world market, investment decisions and long term planning we cant blithely assume that prices will drop in fact the opposite could happen as investment in the industry to open up new fields doesn't happen and existing sources start to dry up.This will be very bad news for the UK rail industry.
Bi-mode should be a sticking plaster to gain space not a solution. Whilst there's blame attached to NR a lot of the underpinning causes are consequences of Government policy failure. Theirs a parallel with the 1955 Modernization Plan here Government pretended it was badly let down by British Railways when the reality was it was forced by Government to buy the dodgy British diesels and the Marshaling Yards were a consequence of being hamstrung by Victorian legislation which Government continued to impose on the railways. It cant be allowed to wash its hands of electrification when its the right thing to do just so it can run away from problems of its own making.
But we have to get the show back on the road. .
If you have hydrogen, your best bet would be to react it from carbon dioxide obtained from things like cement kilns or glassworks and make methanol or dimethyl ether.
Dimethyl ether is easy to manufacture, has a very high cetane rating so can work in a diesel engine and has very good emissions figures.
Many of them can't see beyond the end of their noses, let alone past an election.
Doesn't seem to be true for the electro-diesels, 55 years old and still going strong...True - they only think about short term costs. Any bi-mode train is more complicated than a simple electric (or diesel) train, and will inevitably have higher maintenance costs (and more bits to "go wrong").
Taken over the lifetime of the trains, the total purchase / operating / maintenance costs of bi-modes could probably be in excess of the long term capital / operating costs of a fully electrified railway.
As the RSSB and the ORR (the two guilty organisations) have been remarkably quiet on this subject over the last few months - think of the dog that didn't bark in the night - I suspect some face-saving formula is being worked on.What they should do is find ways to make electrification cheaper, e.g. (for a start) ditch over-cautious clearance specifications, and stick to what has been used safely with 25 KV for over 50 years.
standards, and they have no power to 'interpret' the rules differently. They can and will allow clearances below the standards, provided a thorough justification and risk assessment is performed. Apparently risk assesment was already required for the 'national condition' reduced clearances when they fell below the TSI standard, but was ignored.
You have to add Network Rail to your list of guilty organisations. From the ORR perspective little has changed, but it seems NR don't comprehend what's required of them, and don't seem willing to engage with ORR or do the necessary assessments (likely as their projects are late and overbudget already) so just chuck the towel in and clear everything to the TSI standard - it's only money, after all. However, the ORR have a role in overseeing the finances of the railway, so they still shoulder a good part of the blame.
Has he considered that this drawn out risk assesment process might actually cost more than simply TSI clearing everything? Especially since there is apparently every chance the risk assesment will be rejected and they will then have to clear it anyway?
Potentially weeks of paperwork for every single structure sounds like it is going to cost huge piles of money.
It goes on to say:A senior source in Network Rail, however, commented that removing Annex G was a late change that they had not agreed to and that no one in the company had been consulted. Their view is consistent with the impact assessment for GL/RT1201 not mentioning standing surface clearance and stating that it will retain the use of Annex G.
Furthermore, there was also no assessment of the economic consequences of this decision as required by the TSI implementation strategy. In particular, there does not seem to have been any consideration of a minimum clearance of slightly less than 3.5 metres which, as will be seen, would have significantly reduced the impact of this standards change.
So I stand by what I wrote originally and add the DfT to the list of guilty parties.ENE TSI applies to “new, upgraded or renewed ‘energy’ subsystems”, so it is not concerned with the existing infrastructure. Its clearance requirements specify compliance with the notified national technical rules that are the relevant clauses of GL/RT1210.
For projects at an advanced stage, the 2008 Interoperability Directive allows EU member states to issue a derogation against a new TSI. Although the Department for Transport advised the EU that EGIP was such an advanced project, as it had “reached a significant degree of maturity when the TSI was published in terms of tenders, contracts and detailed design”, the project was not issued with a derogation so had to comply with GL/RT1210.
You can do an awful lot of surveys and paperwork for the cost of raising or replacing a bridge! They are more than happy for you to meet the standards, that's their preference, but if the costs are disproportionate then there's the option to go down the risk assessment route, and mitigate the risks as far as reasonable and practicable.
Once you leave the railway, the clearances to a powerline increase to 4.2m, so you can understand why just assuming 2.75m is safe just because it happens to be a railway is questionable. Electricity doesn't care if it's on a railway or not, nor what legacy infrastructure that railway happens to have.
Outside the railway we don't tend to have near total control of what is under the power line though do we?
It is much easier to stop someone walking under 25kV OLE with an aluminium ladder than it is in a field or by a street.
We only have near-total control on fully manned stations. How many stations with OLE are unmanned, or only staffed during certain hours? This, I think, is why a site specific risk assessment has become a requirement, because the amount of control varies greatly.
Back in the real world - how many people on un-manned stations have been electrocuted by the 25kV overhead since, say, 1953 when the Lancaster - Morecombe - Heysham line was converted?
In the light of this answer, how many more people will have their lives saved by these extra risk assessments?
Not at all - that's your conclusion, not mine. You are the one arguing for risk assessments - but it seems that the actual results of 64 years of operation are not good enough.Ah, so we need to kill or maim people before we take action now? The world has moved on from the passive, so-far-so-good approach to safety*.
I don't have any figures, and to meaningfully assess the risk you would need to include near misses which typically don't get any publicity.
There was an argument for pushing back against the clearance changes for projects which were in-flight. These are the ones which incurred the delays and additional costs for design changes. That opportunity has gone, the new standard has been accepted. There's no chance of it being reset now, as it would be seen as compromising safety to cut costs, even if the 'real world' risk is little changed.
*Mostly. Grenfell being an obvious exception.
If you ignore the actual results - then I for one would lay no value at all on any risk assessment that you, or any others, may produce.
So you are prepared to accept that the increase in clearances, both from the overhead to fixed structures and from the platform edge to any live part of the overhead or train, may make electrification of some sections of the existing network unaffordable because of the civils work necessary? This needs to be clearly stated.
Obviously for new build - HS2 and the like - the cost of increased clearances are not so significant as the whole system can be designed to meet the requirements.
In a country where we deny people life-saving medicine because it doesn't save enough lives for the amount it costs, it would be pretty awful for any government body to spend millions of pounds without being able to identify a benefit to the public from the expenditure.Ah, so we need to kill or maim people before we take action now?
That isn't to say that the government doesn't do some pretty awful things from time to time.
