Legolash2o
- Joined
- 27 Sep 2018
- Messages
- 604
Blue - TPWS grid
Blue - TPWS Crate
Red - Disconnection Box (Dis Box for short), say a tamper burst the cable between the AWS and the dis box, then we would only have to replace a short piece of cable instead of either replacing the whole length back to the loc or jointing in a new piece. Also allows us to fully remove equipment and cable for PW work instead of leaving it coiled up at the side of the line where it could be damaged.
Yellow - AWS, from left to right, ramp - electro-magnet - permanent magnet - ? possibly another permanent, not seen anything like it before - ramp
What are the ramps for around the AWS magnets ?
Makes sense. Thanks !Protects the magnets from strikes from anything that may be dangling under the train.
I wonder why the AWS is covered in oil.
Thanks!
It was at Doncaster Platform 4. I was trying to notice anything different since the recently completed W12 clearance to Immingham and wondered what they were.
is there a plug and socket in the disconnection box so the AWS kit is 'plug and play' or are there junction boxes needing screwdrivers etc?A disconnection box & tails must also mean there’s no or reduced need to enter the equipment during installation, it can be factory sealed with standard tails. You can then connect to main run cables of whatever size is necessary to minimise volt-drop, and make that connection at a convenient position for maintenance activities?
see them on level crossings too.Protects the magnets from strikes from anything that may be dangling under the train.
looks like the setup you get on a reversible line. I've seen a few AWSs set up like that.
I think that’s the case with new or recent equipment installations, and that’s not just AWS and similar kit, I think there was an article in rail engineer magazine about it a while ago, I’ll have a search, here’s a couple of articles from a few years ago:is there a plug and socket in the disconnection box so the AWS kit is 'plug and play' or are there junction boxes needing screwdrivers etc?
The permanent and electro magnets are opposite magnetic poles (but I don't recall which is which!). I assume the suppressor electromagnet is the same magnetic pole as the main electromagnet, and is more powerful than the permanent magnet. When a route is set in the direction not requiring any indication then the signalling energises the suppressor which cancels out the permanent magnet, so that the train detects either nothing at all or a pole that doesn't do anything without the opposite pole being detected first.I think the track is normally for trains running left to right. First they pass the square box that has an electro magnet in it, usually de-energised. Then the permanent magnet - you can see the square of iron filings in the middle. Then the electro magnet that is energised when the signal is clear.
If the train is running the other way, it sees the electro magnet, de-energised, then the permanent magnet, then the square electro magnet which is energised.
An energised electro-magnet passed after the permanent magnet gives a clear indication.
How the train knows the square magnet that supresses the caution AWS indication is to supress and not give a clear indication (Bell) I dont know.
