Train allocations between Hungerford and Paddington
DonnaB
27 Sep 2016
I'm travelling to Paddington. Does anyone know which services between Hungerford and Paddington are Intercity 125s?
DonnaB
27 Sep 2016
How do I know how many coaches they have. I'm trying to work out from the timetable which are 125s..... Does the timetable say how many coaches?
I would expect the following would likely be HSTs:
  • 0637
  • 0653
  • 0735
  • 1640
However it's possible some of them may be rostered for Adelantes. Someone local to the area could confirm. Unusual allocations can also occur, particularly at times of disruption.
Rich McLean
6 Feb 2012
All are 165/166 operated except:
0635
0651
0732
1639
The 0546 pointed out by Yorkie is booked for a 166
However, the 0609 off Newbury to Paddington is Class 180 operated, but obviously that does not apply here
jimm
6 Apr 2012
Quick and easy way to check for GWR trains operated by HSTs/125s is to look at the GWR pocket timetables, which have a little H in a blob at the top of the column for any service they are used on.
If you go to the GWR timetables page here https://www.gwr.com/plan-journey/train-times, open the dropdown section headed East, you can open up a pdf of Timetable East 4, which shows services between Hungerford and London and back.
As well as direct HST services, in the afternoon and evening there are two or three cases where you can use an HST from Paddington to Newbury and change there into a Turbo for the last 15 minutes to Hungerford.
