Ianmel1969
- Joined
- 18 Jan 2011
- Messages
- 80
Yesterday, 1st Feb my 1311 Portsmouth Harbour to Victoria train on the wonderful Southern Railways was cancelled due to a 'planning error'. Just wondering what the heck that is supposed to be?
Just a guess, but perhaps no crew booked for the job and although that would potentially be a Rostering error, Planning might be more easily understood.Yesterday, 1st Feb my 1311 Portsmouth Harbour to Victoria train on the wonderful Southern Railways was cancelled due to a 'planning error'. Just wondering what the heck that is supposed to be?
As someone guilty of such errors in the past it's probably a clerical error.Yesterday, 1st Feb my 1311 Portsmouth Harbour to Victoria train on the wonderful Southern Railways was cancelled due to a 'planning error'. Just wondering what the heck that is supposed to be?
Years ago a colleague in Train Planning went to catch his train home forgetting he had taken that train off in the timetable change which took effect that very day!As someone guilty of such errors in the past it's probably a clerical error.
Easily done - but very much best avoided.
My favourite was the unit diagrammer who was doing a major project at Lime Street (big engineering job) and ended up with just one train uncovered. The 1850 Lime Street-Allerton EDMU.Years ago a colleague in Train Planning went to catch his train home forgetting he had taken that train off in the timetable change which took effect that very day!
This was 1J37 and it was cancelled due to no driver.
There's so much of this going round at the moment, certainly at GTR. Lots of drivers being uncovered at the same time and running an interim timetable with unusual workings means trains are often cancelled or amended at short notice, depending on if there are any spare drivers knocking about in the mess room (spoiler alert: not usually)
This is Southerns long-standing driver shortage, no driver rostered because none is available. Could be seen as a long term planning error in not having enough drivers employed but also a grey area over how much Rest Day working can be relied on.The perils of short term (STP) timetables is that this can happen from time to time and stock and crew diagrams don't quite align. Or some 3rd supplement and alteration didn't get carried across in time to one system.
And even then, the issue is normally found out only moments before departure time.
So it is a planning error, then? The delay attribution specifically describes a rostering mistake, not a general absence of crew.TI is a train crew rostering error which for some reason RTT lists as a planning error when it’s more a lack of available train crew.
Surely one of the perks of such jobs is ensuring that the your going home train is protected from all danger of cancellation?And a Controller colleague also went to catch his train home which he himself had cancelled it during his shift; He'd totally forgotten and when he asked station staff where the train was, the reply was 'some b*stard in Control cancelled it' !
And is your preferred unit type where possible.Surely one of the perks of such jobs is ensuring that the your going home train is protected from all danger of cancellation?
Then it shouldn’t have been coded as a planning roster error - it should have been coded as cancelled due to a shortage of train crew.
The “planning error” reason is normally due to a train existing on a CIS or public system that was never intended to run or didn’t have a crew diagram attached.
Hoping up to the last moment that someone can be found to cover the duty, we don’t know how often they are found.No. Being unable to roster for a planned 'event', such as leave or notified sickness, (or some berk introducing a timetable for which you don't have enough drivers), goes down as rostering. Shortage of traincrew would be for unplanned short notice absences, such as ringing in sick, or needing emergency leave on the day. It doesn't necessarily mean it's rosters fault as such, just that it's a rostering issue.
We'll have to disagree then. You plan a service for X number of trains with Y number of crew. If Y = less then X, I would suggest that is a "shortage of train crew" which is what most TOCs use.
A planning error is like trying to run a train through a possession or amending a timetable and removing services, yet still having a train showing on public system which was never intended to run. Or a stock diagram with a completely non-existant (note not uncovered) train crew diagram.
It is said that a Deputy Chief Controller (Crewe) led his party (Buxton bound) onto an EMU at Piccadilly on one occasion.You would like to think so, but even Controllers are human (allegedly)......
So he asked the timing section for an Allerton-Lime Street EDMU to work it . . .
Not sure he ever lived it down.
My guess is that it was impossible to run as the line was closed due to the engineering work. The time would have been in days perhaps.?!Sounds like a good joke - if only I knew enough rail jargon to understand it.....
I think essentially there was an uncovered Empty Coaching Stock (ECS) movement from Liverpool to Allerton Depot and the diagrammer requested an ECS from Allerton to form the ECSSounds like a good joke - if only I knew enough rail jargon to understand it.....
Not just confined to the rail industry.Years ago a colleague in Train Planning went to catch his train home forgetting he had taken that train off in the timetable change which took effect that very day!
Correct.I think essentially there was an uncovered Empty Coaching Stock (ECS) movement from Liverpool to Allerton Depot and the diagrammer requested an ECS from Allerton to form the ECS
TA | Train-crew/loco/stock/unit diagram issues |
TG | Driver |
TH | (Senior) Conductor/Train Manager |
TI | Train-crew rostering problem |
