Trainee driver / depot driver greater Anglia!
Discussion in 'Railway Jobs & Careers' started by Bucephalus, 28 May 2019.
  1. Bucephalus
    Bucephalus Member
    150
    5 Feb 2018
    Rail Forums
  3. OneLowban
    OneLowban Member
    593
    30 Oct 2017
  4. Bucephalus
    Bucephalus Member
    150
    5 Feb 2018
  5. UpRoad
    UpRoad Member
    8
    12 May 2019
    Tip for the Group bourdon. Try and memorise/recognise the shapes of 4 dots.
    What slows down most is the actual attempt to count the dots.
    There are only a few actual shapes of the dot variations. They turn around at different angles similar to Tetris.
    One looks like a Y when you connect the dots another like a C
    One looks like a radiation symbol
    The normal 4 side dice face
    The spacing between the dots has slight variations but as a whole you should be able to see what I mean.
    It’s a technique that works very well for me and just an option for people to look at.
    https://traineetraindriverinfo.com/...merce_uploads/2013/12/Mock-Assesment-Copy.pdf
    Always good to print off some copies for practice
    Best of luck second time round
Share This Page
