Not in the middle, hence why islands like Asencion exist.Yes, but the magma from the volcanoes has solidified into rock to form this ridge, so a train tube going over the top would not be floating in extremely hot viscous liquid.
There have been plenty of replies here that in no uncertain terms explain why there is no chance of such an underwater tunnel being built. My reply is why would it ever be seen as necessary? Since the days of Walter Raleigh, there has been a continuous stream of vessels carrying goods materials and people across the Atlantic in both directions. It is only in the last 60-70 years that any significnt amount of goods have made the journey by air, and for people with information, there have been telecommunications, (telegraph, telephone, radio, internet etc.), providing far lower carbon modes that are easily better than moving human bodies.What do you think is the likelihood of an electric railway tunnel being built between England and the USA, under the Atlantic Ocean, within either the next 50 or 100 years?
The 'special relationship' is still there and as international business continues to develop, there will probably be stronger links in the future between England and America. However, air travel could eventually start to reduce until it is no longer seen as a viable transport option, because of concerns about pollution. This is where electric rail links could be a solution, and the only obvious way to link England with America is by a tunnel under the Atlantic, with dual-gauge trains.
Could this be the next major project after HS2? In 2123, could we have a 10:00 London Paddington to Manhatton via Cardiff and Nantucket Island?
What are your thoughts? It might seem crazy now, but then the Channel Tunnel idea would have probably seemed crazy in 1900!
If you were going to build a trans Atlantic tunnel, it could be routed via Iceland and Greenland. Obviously this would be a longer route, but perhaps not too much longer as it would take a great circle route that takes advantage of the earth’s curvature.Arguably you would want to build something like Iceland in the middle of the Atlantic really so that the spreading ridge could be managed above sea level.
Still a fair bit longer, about 1,000Km or so (so 20%):If you were going to build a trans Atlantic tunnel, it could be routed via Iceland and Greenland. Obviously this would be a longer route, but perhaps not too much longer as it would take a great circle route that takes advantage of the earth’s curvature.
The tunnel could then pass over the mid Atlantic ridge in Iceland. There would be the issue of ice sheets in Greenland though, but if say such a tunnel is constructed in the second half of the millennium, melting ice sheets due to climate change would make this less of an issue.
A whole new angle on railway preservation.Yes, but the magma from the volcanoes has solidified into rock to form this ridge, so a train tube going over the top would not be floating in extremely hot viscous liquid.
Maybe go via Stranraer and through Beaufort dyke, I believe theres a few particle accelerants there which if disturbed may speed up the journey considerably.Indeed, a projected route might look something like this: (shown linking into HS2 at Crewe as a tease)
If the Greenland ice sheets are ‘less of an issue’, then it’s fair to say that there won’t be a New York or London to connect, as they’ll both be underwater!
At which point, Skynet will be a bigger problem to solve than transatlantic connectivity.Or on stilts.
Yes - engineered by a descendant of Brunel if I remember right, and set in an alternate history where America lost the War of Independence and was still part of the British Empire.The novel "A Transatlantic Tunnel, Hurrah!" by Harry Harrison gives a not very serious but (I think) reasonably well informed take on the matter.
Brassey-Brunel? sounds familiar anyway.
And indeed the US gets it's independence at the end of the book. IIRC the tunnel went to the Azores first? also I think some of the shifting floor issues were "solved" by having the tunnel float ( underwater, obviously ). It had nuclear-powered reciprocating steam locomotives, so that is the level of reality we're talkingalso the enitre tunnel is in a vacuum, which a) precludes through running and b) the insanity of a deep submarine tube with a vacuum in it boggles my mind a bit, as does the logistics of pumping out several thousand miles of tunnel.
About a million times more likely than one for a steam railway.What do you think is the likelihood of an electric railway tunnel being built between England and the USA
Tbf the only existing technology that has a hope of competing time-wise is Maglev (although that's technically electric in a sense I guess).About a million times more likely than one for a steam railway.
For power you'd surely use nuclear, like modern aircraft carriers do?You could evacuate the tunnel in front of the train, saves pumping it out behind!
I'm quite interested in what a modern take on an ocean liner would be like ( a serious take, not a QMII "we still have an ocean liner!" version ). Not sure how big you can scale an Incat-style catamaran, or how much power you can get from the sort of wind tubines ( flettner rotors etc ) you can stick on a ship.
Willy Wonka managed it... and things turning up smaller on the other end would solve the loading-gauge discrepancies... at least in one direction!It may be superseded by teleportation technology straight out of Star Trek
In all seriousness that has been explored in Europe where they successfully beamed atoms from one location to another, we are still decades away from beaming a whole person and reassembling them without anything being out of place, like your eyes on your shoulder or your nose on your backside.
NS Savannah suggests that wouldn't be overly popular.For power you'd surely use nuclear, like modern aircraft carriers do?
We'll send an HST down and meet an XPT coming the other way...Cracking effort for originality.
Once that’s built, years late and over budget, the-more-ambitious-HS2-equivalent could be an asbestos lined tunnel through the Earth’s core to Australia!?
The only thing I can think of that would make the chances of this happening reduce from one in a billion to zero would be Boris Johnson announcing he supports it
