Transpennine Route Upgrade and Electrification updates
Meerkat
14 Jul 2018
Just get on and do it! Even if all the big projects got canned a quadruple route into Leeds and Church Fenton cut off would have big gains.
Wandering into speculation but I would put in a South Milford to Sherburn chord so that those two stations were on the York-Leeds stopper.
CrickUK
23 Aug 2017
The documentation makes reference to the scope including “ realignment of the up and down Leeds lines to achieve A higher line speed of 125mph” given that the works within package E1 finish North of Church Fenton station and the line is near enough dead straight all the way to York, does any one have any idea what work this is referring to.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Yes, promising indeed.
You wouldn't think that wiring 5 miles from Colton Jn to Church Fenton (without any obvious operational benefit) would be authorised without also committing to wire the rest of the route on to Neville Hill.
I suppose the E1 scheme might be linked to other work such as the ECML power supply upgrade.
Let's hope the other sections of the route are in the pipeline.
It will be a pricey job wiring the 4 tracks for 125mph - hopefully not using GW Series 1!
It'll most likely be done using UK Master Series - the same stuff on the MML. (A mix of S1 & S2)
The designers chose to use the S1 Monobooms for Tensorex anchoring as part of the MML design; that doesn't necessarily mean that they'll be used for TRU.
59CosG95
18 Aug 2013
To quote this post again, the ECML PSU Phase 2 plan states that upgrade work will take place on the (MP)TSC at Colton Jn, which might be worth bearing in mind for the TRU works.
Presumably E1 will allow bi-modes to switch at Church Fenton and so equalise speeds on the ECML.
Also it may provide the connection to HS2 (if built). Hence it is a freestanding scheme, although it should make others more likely to proceed.
Not such a black Friday.
WAO
It will be interesting to see if TPE switch their 802s at Colton Jn when regular services start, as opposed to York station while stopped there.
LNER also have a few services between Leeds and York which could do so.
But sometimes operators/NR are quite conservative about switching power on the run (eg at Didcot).
Extension to Church Fenton will give them double the current scope to use the wires.
hwl
5 Feb 2012
North Of Church Fenton is 100mph till Colton Jn but around Church Fenton there is plenty of 70/80/90
Ploughman
15 Jan 2010
Near where the 3 ridings meet
Is the work between Church Fenton - Colton a case of getting the easy site out of the way first? If it is getting wired imminently that is.
No major trackworks needed, Bridges lifted already and a decent Run into the existing wiring at Colton.
Went past today and at least 3 of the work compounds seem to be set up already with various Road / Railers and other plant on site.
Compounds North and South of Copmanthorpe had activity this afternoon.
Visible work seems to consist of dropping out Ballast Dumpy bags every couple of hundred metres or so on the North side of the line.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Is anything happening imminently? The much delayed announcement about the scope of TRU by DfT still hasn't happened has it?
The DfT is general over about the last 9 months seems to have gone much less transparent. Things do leak out but nothing gets confirmed. I wonder if after the General Election there will be a big announcement no matter who gets in.
WAO
10 Mar 2019
The DfT like other Govt Departments is in purdah until after the election.
There could always be pledges by politicians - for what they're worth.
WAO
hwl
5 Feb 2012
I wouldn't say much has changed just that most of the occupants of GMH have been kept busy with cross channel ferry service procurement etc! An election isn't going to remove those issues in the short term.
Just not much happening at DfT for non HS rail due to distractions.
hwl
5 Feb 2012
I'd agree with that.
Plenty of compartmentalised minor track works to get the line speed up to start with followed by piling etc. The masts, SPS and wiring don't need to follow that quickly given the gap towards Leeds.
There is a limit to how much can sensibly be done at one time and many different ways to prioritise but starting off on some easier cheaper completely defined works certainly makes sense financially.
twin turbo
12 Oct 2019
Be interesting to see if we get an announcement now the election is out of the way.
twin turbo
12 Oct 2019
People in Church Fenton and Ulleskelf received a letter from Network rail this week advising of major works over the Christmas period to install 24 ducts under the lines to carry cables.
hwl
5 Feb 2012
That suggests moving a fair chunk of S&C to improve line speed at some point amongst other works.
61653 HTAFC
18 Dec 2012
Another planet...
Huddersfield platform 1 being lengthened over christmas added to at tunnel end and also back into end of platform 2
They kept that quiet! Surprised they're extending P1 at that end, as P2 is already shorter than the originally planned stock for the Sheffield line. Though as the 3-car 150 plan seems to have been abandoned, perhaps that's no longer a problem.
Glenn1969
22 Jan 2019
Halifax, Yorks
But that is just so Northern can run 3 car trains to Sheffield, not necessarily part of the TRU plans about which there has been no public update for at least 6 months unless I missed something. Did the planned Christmas works at Church Fenton and Ulleskelf actually happen?
twin turbo
12 Oct 2019
Yes they have been very busy for the last few days with a lot of activity at Ulleskelf and Church Fenton. Going through on the train it looks like they are setting up a big compound at Church Fenton on land adjacent to the railway just past the station heading towards Ulleskelf.
61653 HTAFC
18 Dec 2012
Another planet...
Platform 2 extension finished in time for first train yesterday (Fri).
Contrary to the initial reports, the platform has NOT yet been extended at the buffer-stop end: just a few metres added at the tunnel end so far.
I appreciate that this work in and of itself is not part of the Trans-pennine Route Upgrade, but it will affect TPE services once the buffers are moved back.
Would it be worth starting a new thread to cover Penistone line platform extensions? I guess it depends how many forum users get down there regularly to keep us updated, as I'm usually only on the line once a fortnight on average.
ajdunlop
25 Jan 2009
Not sure if this is the right thread.
The blue pole barriers that get attached to the rails to prevent railway workers falling onto a live railway are going up all around Miles Platting Junction. Does this indicate that the remodelling will be happening soon?
59CosG95
18 Aug 2013
Not entirely sure, but seeing the "Vortoks" (as they're known) up is surely a sign that something is due to occur...
bengley
18 May 2008
According to the weekly operating notice, the most likely work they're carrying out in this area is simply routine maintenance on switches and crossings (points) on the Slow (Ashton) lines while trains will be running on the Fast (Rochdale) lines, thus the fencing is probably just to protect the workforce
