Travel Fraud Investigation
Titfield
26 Jun 2013
Probably not, as long as it is clear that it is the same person. Is there a particular reason why you do not want to use the other email address?
I would use the same email address. To use a second email address - which they will then see - may raise suspicions that you are using multiple identities.
Haywain
3 Feb 2013
Is there any issue if I reply from different email from which I didn’t receive the email from the wm team.
Have you used the alternative email address to buy tickets as well? If you have you may feel it is better not to reveal that to them.
Mcr Warrior
8 Jan 2009
Hi is there any update on what happened here please? it would be helpful thanks.
Welcome to the forum. If you have a similar issue that needs resolving, please start you own, separate, thread, under the 'Disputes and Prosecutions' sub-forum.
helpme234
10 Jul 2024
west midlands
Hi please can you update us on what happened!!?? Did they give you an option of just paying a fine instead of going to court?
Pls respond
Elecman
31 Dec 2013
Lancashire
Pls respond
Please start your own thread as per Forum rules as no 3 cases are the same., so you can be given the best advise to your situation
