norbitonflyer
Maybe it wasn't that recently...... I used to ride it regularly in my commuting days. If it's gone, then 55555 may have outlived it.How recent was this? I thought 455 726 had been scrapped after being roaded out from Wimbledon last December to Long Marston and later went to Sims in Newport? @Siemens Staines maintains a list of these somewhere, I think? He'd be interested if it has in fact returned instead.
12345Anything numbered 12345 or 54321?
The LMS had one - a former Lancashire & Yorkshire "3F", built in 1896 and scrapped (as 52345) in 1962
I can't find any others
Coaching stock - would be a Mark 4 Open Standard (Disabled) but the highest numbered one is 12331
ex-SR electric stock: there is a gap between S12276S from 6PAN unit 3037, and S12351S from 4SUB unit 4378
BR 1948 numbering - the 12xxx series was allocated to LMS-design shunters, later known confusingly as Class 11, but their numbers only reached 12138. Had they continued building them instead of starting on the very similar 13000 series (later D3000, and then Class 08), the locomotive that was actually numbered D3205 (08137) - for many years Lincoln's station pilot, would have had that distinction.
TOPS Class 12 (Former Southern Railway Shunters) never got their TOPS numbers, and there were only 24 of them anyway (15211-15236). Note that the antepenultimate one (15234) did have all the right digits, but (to paraphrase Eric Morecambe) not necessarily in the right order.
54321.
Can't find any at all, which surprises me
Coaching stock - 54321 woold have been a 1st generation DMU driving trailer. These were all originally numbered in the 56xxx range, but renumbered in the 54xxx range to avoid duplicating Class 56 locomotives. However, there is a gap in the numbering between Class 100 No 56319 and Class 101 No 56332 (presumably a cancelled order). Because of the withdrawal of Gloucester RCW driving trailers in classes 100 (and 122) without renumbering, the gap in the 54xxx series actually ran from Class 121 54289 to class 101 54331
BR 1948 numbering - The LMS had used the 14xxx range for passenger locomotives built by its Scottish constituent companies, and these were renumbered by BR into 54xxx range). However, the lowest number taken into BR stock was 54363.
TOPS Class 54 has never existed
