Trivia: Large towns which deserve more trains per hour
exile
16 Jul 2011
I wish St Helens Central had a proper link to Manchester rather than a suburb of it. It’s pretty bad that even the village of Rainford at the top end of the borough has a link (admittedly not a very good one) but the main town doesn’t. I think it’s links to Liverpool are undoubtedly still the weak link in Merseyside when the rest of the system has a clockwork 4 an hour service but ours is 2 slow and 1 semi fast. (St Helens Junction is a suburb at the southern end of the borough some way from the actual town). I appreciate though, that it coul d be worse and be like Oldham, Bury or Leigh which don’t now have any heavy rail links at all and should really be fully integrated into the national ticketing network fully. No doubt someone will mention the bus service which is good from the town, but it is slow, with no express bus anymore and has to go through some comically rough parts of Liverpool. (I think even it’s biggest supporters would not defend the Sheil Road area of Kenny and Page Moss!)
The last time you could get a train direct from St Helens to Manchester was 1952, from St Helens Central via Lowton St Mary's and Irlam to Manchester Central. By the end there were only half a dozen trains each way per day.
philthetube
5 Jan 2016
Watford, (Virgin services). Virtually London prices for vastly inferior services.
The Ham
6 Jul 2012
(Not picking on you individually, but just using this as an example for the question)
It's probably worth also answering the question "and how would you like to see the improvements being made?" as well.
It's fairly easy to highlight somewhere where more services would be good, however often there's a fairly good reason why there's not more services.
In the above example is suggest that the only way that Watford would gain more long distance services is if HS2 is built. Although that would mean that most long distance services were diverted away from passong through the station there's little to no chance that most of them would ever stop there anyway. For those which did continue to run Watford would be a key place to stop.
