It's part way up the steps, if I recall correctly.That’s interesting, I didn’t see it on the platform when the train stopped there last week. Is it on the station approach? Should probably be a half-hourly service really.
I don’t think this does apply to Leeds, as most of the first stations out are actually quite a distance away so are in places of their own right, like Cross Gates, Outwood, Woodlesford, rather than the Ardwick situation where the station is within a run down industrial area. If Leeds had stations near Neville Hill or maybe in Holbeck or Armley you’d end up with that situation.
If Severn Beach has that number of passengers, why did a number of services in the past terminate short at Avonmouth?You'll have to take that up with the ORR...
Again, I don't know - I'm just going off what the statistics say. If it saves a unit without severely damaging ridership then that might make sense.If Severn Beach has that number of passengers, why did a number of services in the past terminate short at Avonmouth?
So I take it the station was unstaffed then, even tho long distanced trains were calling there.I would nominate Coatbridge Central, it now has a fairly regular service to Cumbernauld and Motherwell but in the 1970s it was ripe for closure as it only had one or two long distance trains a day including the Clansman which were progressively taken away from that route . At that time the platform buildings were demolished and the main street level building sold off and became a pub. Access is a challenge especially if you want a train to Motherwell if you are coming from the town centre, you have to walk under the bridge up a ramp that used to access the goods yard then negotiate a subway which is used by the local neds as a drinking den and toilet, there is no access to this platform for disabled passengers as the slow line still runs behind the platform Think the platform surfaces have recently been improved but access to the station really should be given a total overhaul
The local stations in Plymouth. All in built-up areas on a direct line to the city centre, all receive roughly 2 hourly service. Surely this must be one of the biggest untapped demands in the country? An hourly service to Liskeard and perhaps an hourly service up the Gunnislake branch (not necessarily all the way) would be transformational.
Before. They put up white 'board' walls and fluorescent lights in the tunnels. It's still dingy but not quite as bad as the before photo. The refurbishment was mostly above-ground. There wasn't much TLC put in to the platforms.Was that photo of Dalmarnock taken before or after the Commmonwealths as it had a refurbishment for the games? It is also prone to flooding.
A fair nomination. Coatbridge Sunnyside is by far the 'better' station, it's a short walk away, and it has frequent services to Glasgow and Edinburgh via the North Clyde Line and Airdrie to Bathgate line. Coatbridge Central was mostly used by an hourly Motherwell-Cumbernauld service run by a single 156, and a couple of peak-time EMUs from the Argyle Line that were extended from their usual Motherwell terminus up to Coatbridge Central. It gets a slightly better service now the line has been electrified all the way to Cumbernauld, but it's still a fraction of the service Sunnyside has.I would nominate Coatbridge Central
