Trivia : Popular tube journeys requiring a change
md2016
3 Feb 2023
Haddenham
I'm sure this has been asked already but couldn't find it with a brief search...
What are the most common tube journeys, that require at least one switch of tube line?
danm14
24 Jun 2017
A lot of people originating from the northern extremities of the Piccadilly heading into town will often change at Finsbury Park to the Victoria.
I seem to recall reading somewhere that for journeys from one end of the Piccadilly Line to the other, assuming you position yourself in the correct part of the train, it is quicker to change at Finsbury Park to the Victoria Line and then back to the Piccadilly Line at Green Park.
Revaulx
17 Sep 2019
Saddleworth
Quote from the DG blog:
“Then it's North Greenwich to Canary Wharf and back again. It's only a one stop journey but it helps a lot of south London residents get to work in Docklands.”
Excuse me for being thick, but how do all those south London residents get to North Greenwich in the first place? It isn’t a tube or DLR interchange and the housing round it is still pretty sparse. Does it have lots of buses?
PTR 444
22 Aug 2019
Wimborne
Yes.
jon81uk
17 Aug 2022
Harlow, Essex
Yes there is a large bus station at North Greenwich.
norbitonflyer
24 Mar 2020
SW London
District Line to the City via Notting Hill Gate?
Why? There are several stations in the City on the District Line (four, in fact - the same as the Central). And they are so close together there is little to be gained by changing for, for example, St Pauls instead of Mansion House
Gigabit
7 Dec 2022
United Kingdom
For Liv Street I find Central faster and it’s always very busy when I change
When we were staying at my grandmother's house we would often go into London by Tube from Stanmore. Fun to change at Wembley Park and overtake the train you were on, and one or even two ahead of it.
PTR 444
22 Aug 2019
Wimborne
Similarly I’d imagine any end to end journey on the Bakerloo Line would be quicker if you took the Jubilee Line between Baker Street and Waterloo. Not sure whether the interchange times at those stations negate the faster Jubilee Line journey timing though.
J-2739
30 Jul 2016
Barnsley/Cambridge
And just adding to the previous comments, the Greenwich Peninsula is being developed rapidly, so will soon become a major employment destination in its own right.
HarryF
31 Jul 2022
Kings Cross/St Pancras to Waterloo
Kings Cross/St Pancras to Paddington (direct service rarely runs, on the rare occasions it does, it takes longer than changing Victoria to Bakerloo at Oxford Circus)
miklcct
2 May 2021
Cricklewood
A direct Hammersmith / Circle line train runs between Kings Cross and Paddington every 5 minutes.
Taunton
1 Aug 2013
It's one of the major bus hubs of the region, from points like Blackheath. Before what is now the O2 reopened as an entertainment, and then shopping, centre, it was in the middle of nowhere but quite a busy station from first opening. In fact the extensive recent further development of out-of-town style shops there has had a downside in notably extending bus travel times through them all.
BJames
27 Jan 2018
The direct circle/hammersmith & city runs frequently and takes just 10 minutes.
If you are starting your journey at King's Cross then it's 5 minutes to Oxford Circus, and a further 8 minutes from Oxford Circus to Paddington, not including any change/waiting time at Oxford Circus.
May be a few (fairly) popular journeys to/from Marylebone that come under this.
I assume the previous poster is thinking of the Praed Street platforms, which probably have easier access to main line departures.
miklcct
2 May 2021
Cricklewood
I am not sure if the main line platforms really have easier access from the Praed Street platforms, as I normally use the back footbridge for direct access to the Hammersmith line platform, and position myself in the rear coaches of the mainline train upon arriving Paddington if I am targeting Euston / St Pancras / Liverpool Street.
Enthusiast
18 Mar 2019
Possibly. The running time for the Victoria Line is about five minutes quicker between the two. There is cross platform interchange between Piccadilly w/b and Victoria s/b at Finsbury Park. The change at Green Park is far less friendly involving three flights of stairs (though there is lift access but of course that would usually take longer). Although this is nowhere near as long as changes to/from the Jubilee (with the Jubilee Platforms seemingly somewhere under Buckingham Palace by my reckoning :D). But it's still a hoof. But even with immediate connections at both ends, I doubt there'd be much, if anything, of an advantage
I think the Jubilee running time advantage is similarly about five minutes. The change from n/b Bakerloo to n/b Jubilee is (from memory, I haven't been there for a while) particularly cumbersome, involving a number of passageways and a travelator. The change between n/b Jubilee and n/b Bakerloo at Baker Street is cross platform. Once again, I would be surprised if there was much of an advantage even with good connections.
Some examples of walking instead of taking the tube spring to mind. Blackfriars to Farringdon is a ten minute brisk walk but it's nine stops on the Circle Line and with the usual dwell at Aldgate would usually take twenty minutes. Then there are ridiculous examples such as Bayswater to Queensway and probably the most exasperating of all, between the two Hammersmiths, which are about 70 metres apart. Or 15 stops and two changes (unless you use the Wood Lane/White City OOS interchange which cuts it down to just eleven stops but three changes).
BJames
27 Jan 2018
Or - my preferred Green Park interchange route - a quick dash up and down the escalators via the ticket hall ;)
Probably only really worth it if you know there aren't large gaps in the service - if you've already waited 4 minutes for your Piccadilly line train at Arnos Grove, say, I doubt it'd really be worth it. Plus, depending on how far you're going, you might have a seat and by the time the train gets to Green Park, there may not be any seats available.
Joe Paxton
12 Jan 2017
I would have thought Waterloo to King's Cross St Pancras would be up there.
I suspect a lot of people take a suboptimal route between these two via the Northern line and then Piccadilly line (change at Leicester Sq) or Victoria line (change at Warren St), as they look like they make sense from the Tube map, rather than the Bakerloo + Victoria line route via an easy level change (essentially 'cross-platform') at Oxford Circus.
I suppose this helps spread demand somewhat.
AlbertBeale
16 Jun 2019
The interchange time at Waterloo would surely take up any time saving ... even when the travelator to/from the Jubilee at Waterloo is working!
etr221
10 Mar 2018
TfL did some research on which route people took - links from the DG blog post I pointed to in comment #3 up thread: less than a third used the Oxford Circus change between Bakerloo & Victoria lines. 1.4% were noted as 'others' - and when you see the two routes both recorded as 0.1%, you have to wonder what some of them were...
I agree it's a good route for those in the know, and the change at Edgware Road or Oxford Circus probably offsets any slight time saving that might result from arriving via Praed Street. But for those not in the know, arriving by a back entrance over a twisty footbridge with almost no station facilities is a bit offputting, so I suggest many will choose to go via the main concourse.
