TRIVIA: Replacement Bus Services calling at stations off line of route
cav1975
24 Sep 2010
For the next two weekends Island Line (South Western Railway) are running rail replacement buses from Ryde Esplanade to Havenstreet on the Isle of Wight Steam Railway as the station at Smallbrook Junction is closed.
Ken H
11 Nov 2018
N Yorks
When they had the landslip at the northern end of the Settle Carlisle, were there not RRB's from Appleby to Penrith?
si404
28 Dec 2012
When the Met line in the Amersham-Rickmansworth area is closed for engineering works there's two examples:
1) Chiltern's RRB is Amersham-Beaconsfield (also when Marylebone is closed, with the Met line providing some rail-replacement aspect for the Beaconsfield-London journeys, though they tend to run trains to West Ealing as well)
2) The Met line RRB goes Chesham-Amersham-Chalfont...
Chiltern had a closure between Beaconsfield and Dorridge in June and the RRBs from Warwickshire ran to Aylesbury Vale Parkway (there was a bus doing the stops south of Banbury).
Lewlew
15 Oct 2019
There's no road/path access to Smallbrook Junction. It's a interchange station only.
DavidGrain
29 Dec 2017
When XC trains are diverted via Lichfield then a bus (or sometimes taxis) run between Lichfield and Tamworth rather than putting on buses Birmingham-Tamworth-Burton on Trent which would be an exact replacement service.
Parallel
9 Dec 2013
GWR have run a RRB between Pewsey and Swindon before, so passengers can change at Swindon for services to Reading and London presumably.
Would’ve been nice for the buses to have stopped in Marlborough!
20 May 2018
When the ECML is shut between Welwyn Garden City and Finsbury Park, Great Northern often run a RRB via Oakwood Tube station to allow passengers the option of faster access to London.
Hang on, why Oakwood? Surely an ECML RRB would run right past Cockfosters station then south past Southgate station if it were skipping minor stops or west through East Barnet towards Oakleigh Park otherwise. Genuinely can't see why it would turn east to Oakwood station there.
Mollman
21 Sep 2016
Went to Newquay when there was engineering work, RRB started from St Austell instead of Par
341o2
17 Oct 2011
But does it not say that there will be no service to Ryde Pier Head or Smallbrook Jcn regarding the replacement buses
30907
It does indeed say just that. Smallbrook appears in the timetable IIRC.
bicbasher
14 May 2010
ELL and Jubilee Line RRBs call at Tower Hill and I think Aldgate for additional rail connections.
There have also been instances when the ELL RRBs between New Cross Gate and West Croydon which Southern manage have been extended to Sutton and also additionally call at Selhurst.
One that has never happened but would make sense would be for the SLL bus services to call at East Dulwich. They just go past on their way between Denmark Hill and Peckham Rye.
jopsuk
13 May 2008
I don't know the exact pattern- but maybe it's an express RRB that terminates there?
LancasterRed
21 May 2018
I've been on a Greater Anglia bus service that terminated at Leyton, putting us onto the tube to carry onto Liverpool Street.
Class800
5 Feb 2020
West Country
Greater Anglia RRBs have sometimes run into Newbury Park for Central Line to Liverpool Street - never seen Leyton option being used, but not saying it hasn't
LancasterRed
21 May 2018
It might have been Newbury Park. Leyton is what I remember but I might have got the names mixed up due to being near Leyton Orient's ground
n37077
1 Oct 2014
The ECML RRBS from Potters Bar serves Cockfosters and Oamwood. Oakwood has step free access, Cockfosters doesn't. It does not go past Southgate to get there.
Dave W
27 Sep 2019
North London
This may not be the point of the topic, but as there's lots of talk of the GOBLIN's RRBs being split in two - there's also the weird routeing that the buses take in Crouch Hill - rather than call at the bus stops serving the station, the RRBs drop passengers off at stops on Fairbridge Road - a solid half mile's walk away.
I suspect that doesn't quite meet the OP's description - as the stops are the designated RRB stops for the station - but they're hardly convenient for the station itself!
Class 170101
1 Mar 2014
Does Oakwood have lots of space to hold buses there when compared to Cockfosters.
TheLastMinute
Weston-super-Mare
How about RRBs between Bristol Parkway and Patchway as there's normally no direct rail service between the two? Happens when the Paddington to South Wales services are diverted via Bath and call at Patchway instead or when the tunnel is closed.
island
30 Dec 2010
When Cannon Street and hence Deptford to Westcombe Park, New Cross and St. Johns are closed of a weekend RRB usually runs Lewisham-New Cross-Deptford-Maze Hill-Westcombe Park-Charlton. (Not sure what passengers for St. Johns are meant to do, although it’s hardly a long walk from Lewisham.)
Ryde Pier Head is being served by taxis from Esplanade.
To add to the explanation that’s because normal sized “buses” are no longer allowed on Ryde Pier, I think nowadays a height barrier rules out anything higher than a light van.
cuccir
18 Nov 2009
I've seen timetables with rail replacements on the Settle-Carlisle calling at Hawes, which doesn't have a station, and in Kirby Stephen town centre, rather than at the station. I think they also tend to skip Dent and use local taxi services to get people to/from it. If you look at the local area, the line follows a route that would require lengthy diversions over moorland roads and/or steep hills to hit all the stations.
SargeNpton
19 Nov 2018
I think that the Hawes stop is for the Dent taxi conenction.
