If the trains go toward Oxford Road then it would count!Not sure if it counts since 13/14 are only just the same station but Man Picc to Huddersfield/Leeds
Yes, the Man Airport to Redcar via Ordsall, and the Man Picc to Hull via Guide Bridge.If the trains go toward Oxford Road then it would count!
Only applies from Blackburn.Yes. Not the same fares though.
I’ve done Derby-Sheffield in both directions. During the remodel the trains went via long Eaton way. Very unnerving the first time I thought I’d got on the wrong train!
You can only go direct via Bradford on Sundays and the first/last trains IIRC.Brighouse to Leeds..?
Unless my memory fails me, I did Sheffield, Barrow Hill, Chesterfield, Toton, Derby on a weekend CrossCountry!Fairly uniquely (for a line that isn't normally run as a loop like Man Vic-Blackburn), this can be done from both ways at Derby (via Duffield and via Toton) and at Sheffield (via Dronfield and via Barrow Hill). Of course, both relying on engineering work/occasional route retention services.
Not within my understanding of the thread title - both involve starting out south-eastward from Wigan and going through Ince and Hindley.Wigan North Western / Wallgate to Manchester Victoria. One route is via Bolton & Westhoughton, the other via Atherton & Walkden.
CJ
Glasgow Subway doesn't count, as it's operated as a continuous circle. Neither does Cathcart Circle as it's a continuous loop.If were talking stations as a whole, SPT Subway since it has the Inner Circle and Outer Circle.
There's a lot of stations on the old SPT train routes in and around Glasgow as well.
Quite!And historically there's nothing to compare with Trent....
All trains leave Swansea station in the same direction, but Gowerton would count for that example!Swansea towards Craven Arms / Shrewsbury
The OP ruled out services that run round a loop.Perhaps I’ve misunderstood, however all the stations on the Richmond / Kingston loop?
There is no through service from Redbridge to Southampton via Romsey and Eastleigh. You can leave any station between Redbridge and Chandlers Ford either way to get to Romsey, but that‘s effectively an ordinary loop to/from Romsey that appears to have been ruled out.Redbridge to Southampton Central. Via Romsey and Eastleigh or direct.
I still don’t see this one. There are only 3 Southern trains at Eastleigh on a weekday, one is an ECS Littlehampton to Southampton. The other two are from Southampton and go to Brighton via Fareham and Havant.Correction, not Southampton Airport (Parkway), just Eastleigh, and the peak Southern services via Hedge End
