Trivia: Things that are used on the railway that have found their way to other completely unrelated industries.
Springs Branch
7 Nov 2013
There are railway style semaphore signals on the Redcliffe Bascule Bridge in Bristol.
In Port Adelaide, South Australia, the Birkenhead Bridge is a bascule road bridge dividing two parts of the navigable harbour.
On top of two elevated control cabins which control the raising of the bridge are two railway-style upper-quadrant semaphore signals. This pair of semaphores - one applying to each direction of travel - signal stop or go to river craft needing to pass through the bridge.
The signals are actually three-position American-style semaphores (which were the type in use on South Australian Railways at the time the bridge was completed in 1940).
Those signals do have a "yellow" spectacle lens, but I'm not sure whether they are capable of displaying a 45° indication, or just horizontal (stop) and vertical (go).
Source: Wikimedia Commons, by Peripitus. Reproduced under Creative Commons licence CC BY-SA 4.0
philthetube
5 Jan 2016
Retired wooden sleepers have found their way into many bits of ad-hoc construction.
I've seen lengths of old rail used in the same way.
Old carriages turned into sheds, or holiday homes.
Station buildings turned into homes.
Diesel power units find their way onto ships.
Where would public footpaths be without railway sleepers to bridge the streams.
Dr Hoo
10 Nov 2015
Hope Valley
I thought that railways actually copied the idea of semaphore signals for traffic control from the canals.
What was in many ways the first proper canal in Britain - the Bridgewater - had semaphores to control the passage of wide Mersey ‘flats’ across Barton Aqueduct. (The narrow ‘starvationer’ coal boats used in the Worsley mines could pass on the aqueduct.)
Semaphores for general communication definitely existed pre-railway anyway.
Rescars
25 May 2021
The "national speed limit applies" sign on country roads throughout the UK looks very much like a Sykes Banner Repeater showing "clear".
The iconic Swiss Railway clock is available as a wrist watch. Some of the watches emulate the 58.5 second sweep + pause of the original clock's second hand.
You can get this as a phone app too.
norbitonflyer
24 Mar 2020
SW London
Long ago in one of the railway magazines I saw a photo of a boat whose wheelhouse was quite clearly the cab from a class 03 shunter
Joe Paxton
12 Jan 2017
Greenwich Mean Time.
This, or more specifically the railways' collective influence on the introduction of standard time zones - for more info, see:
en.wikipedia.org/wiki/Railway_time
Railway time was the standardised time arrangement first applied by the Great Western Railway in England in November 1840, the first recorded occasion when different local mean times were synchronised and a single standard time applied. The key goals behind introducing railway time were to overcome the confusion caused by having non-uniform local times in each town and station stop along the expanding railway network[1] and to reduce the incidence of accidents and near misses, which were becoming more frequent as the number of train journeys increased.
Railway time was progressively taken up by all railway companies in Great Britain over the following seven years. The schedules by which trains were organised and the time station clocks displayed were brought in line with the local mean time for London or "London Time", the time set at Greenwich by the Royal Observatory, which was already widely known as Greenwich Mean Time (GMT).
paul1609
28 Jan 2006
Wittersham Kent
HMS Warrior Britain's first Iron Clad warship in Portsmouth Harbour has a large number of GWR Broad gauge chairs in her fore peak as ballast
kermit
2 May 2011
Many years ago I was given a tour of one of the first experimental wind turbines, climbing up the ladder in the middle (with hatches every 10 metres or so so if you did fall, despite the safety harness, you only went....well, actually, still a lethal distance!). At the top, we could open the nacelle for an amazing view, and inspect the gearbox and generator. The guide told me that the enormous disc brake, used to stop the blades if needed, was a straight lift of parts that otherwise would have been destined for a heavy diesel freight locomotive. It didn't say "BREL" on it or anything that obvious, but I believed him!
Oxfordblues
22 Dec 2013
Commuting. Passengers originally turned-up at booking offices and asked for the same day-return ticket every morning, often forming a queue. One imaginative clerk suggested to his manager that they could reduce the workload, and therefore costs, by issuing a ticket that would be valid for a week, month or quarter, termed a "season". The charge would be a multiple of the daily fare, minus a discount. It would therefore be a commuted charge. This is why season-ticket holders came to be know as "commuters" and the term came to include anyone travelling to work by rail or any other means.
snowball
4 Mar 2013
I'm not so sure. I recently tried to find out when wig-wag lights were introduced, but failed. I did get the impression they were intended for all those uses from the outset.
(The closest I got was that wig-wags must have arrived before 1964, because that is when advance warning signs were added.)
After reading the above I asked the question on the roads forum SABRE. I got a few replies, one of which referenced the Railsigns site, which I should have thought of myself. The thread is here:
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
How many links are there between the railways and Rollercoasters? The name ‘Scenic Railway’, block section signalling, the terms train and station, as well as using multiple staff to dispatch trains?
Whilst we’re at it, BR had a hand in finishing off the building of the Ultimate at Lightwater Valley after the original manufacturer went bankrupt. On a similar theme, I read that Taziker, one of the largest manufacturers of railway bridges manufactured the track pieces for the Big One’s track replacements.
etr221
10 Mar 2018
Something not mentioned before, but something I believe first used in railway refreshment facilities - before spreading everywhere - is the long bar counter: to cater for hordes of people wanting service in a short time.
On the the subject of semaphores: I think the first use was in the 'optical' telegraphs developed in the late 1700s...
Deepgreen
12 Jun 2013
Betchworth, Surrey
"We are now arriving into xxxxx..." - first used on the railway and now to be heard on other modes too!
Perhaps the yellow lens indicates that the boat should be prepared to stop at the next bridge!
Ediswan
15 Nov 2012
Stevenage
Thanks for doing that. It looks like, after experimental use, wig-wags started to be added to UK level crossings around 1954. That probably does pre-date other uses. It would still be nice to track down the original legislation authorising their use as road signs.
Western 52
19 Jun 2020
Burry Port
The Post Office used BRUTE trollies in sorting offices when I worked there in the 1980s. They were red to show they'd bought them from BR but the odd blue one appeared too.
61653 HTAFC
18 Dec 2012
Another planet...
British Rail's research department investigated which colours were most noticeable to the human eye from a distance. Yellow was found to be significantly more perceptible and it became the colour on the front of locomotives, DMUs and EMUs. It also became the colour of work clothes worn by staff working on the track. Now, yellow is the colour worn by people in many services where being seen easily from a distance is an important safety consideration.
Ironically though, track workers on the GB National network nowadays wear orange rather than yellow hi-viz, presumably because the fronts of the trains themselves are (usually) yellow. Apparently some worksites during the construction of HS1 required reversible hi-viz with orange on one way (when inside the railway boundary) and yellow on the other (if working inside the boundary of the M20 motorway).
Neo9320
17 Feb 2019
Somerset
Although more and more companies that operate on highways are turning to orange. I used to work for a subcontractor to national grid (or whatever they’re calling themselves these days) and was given orange PPE….on more than one occasion when walking in to my local in work gear I was asked ‘when did you start working for the railway?’
TSG
10 Aug 2020
Somewhere in the South of England
An obscure one - standard BR930 series railway relays are also used on the control systems of Rolls Royce pressurised water nuclear reactors on board Royal Navy submarines.
Makes sense as they are built like the proverbial sturdy convenience. In similar vein, although I'm not sure which came first, ML Engineering in Plymouth (part of Alstom now) made a remote control and indication system (TEML41) that's been used a lot on the railway for panel multiplexers, TDM, train describers, etc. I'm told it was also used on the Royal Navy's type 42 destroyers
6Gman
1 May 2012
The central heating boiler serving an annexe of our local FE College was reputedly a former locomotive boiler. I never got to see it sadly but since the building started life as a railway-linked Technical School and was literally the other side of a fence from Crewe Works it seems possible.
AY1975
14 Dec 2016
Not sure whether these were first used on the railway, but clickers used to count the number of passengers on trains are also used in other settings where people need to be counted, such as to count the number of people entering or leaving an entertainment, hospitality or sporting venue.
I've also seen railway/metro style ticket gates used to control access to some visitor attractions. For example I seem to recall that in the 1980s and '90s the now closed Museum of the Moving Image on the South Bank of the Thames near Waterloo station had Paris metro style access gates where you had to insert your entry ticket to gain access.
Entrance gates or turnstiles released by presenting a key fob or smartcard are also used to control access to many office buildings and other workplaces.
Sm5
21 Oct 2016
Gatwick Airport still does use Brutes.
Butlins Minehead has what looks suspiciously like signal gantries, for lighting rigs, including steps, and protection rails In one of their entertainment venues.
Rescars
25 May 2021
Wikipedia claims that road traffic lights are derived from railway signals. Early on, the GWR changed the all clear signal from a white to a green light to avoid confusion with other lighting.
As a follow-on, presumably we have traffic lights to thank for the "red, amber, green" performance rating system used pretty universally by managers worldwide.
Sm5
21 Oct 2016
Another remote one, was Rock City in Nottingham used to have two panels of track, mounted as a hand rail to manage the queue lines at the turnstile as you went in.
Randomer
31 Jul 2017
I think I've mentioned on somewhere here before but a lot of theatres built or more commonly refurbished in the late 1970's and early 1980's used BR standard T key locks and the more modern T key with central post for areas that were not meant to be easily accessible to the public but didn't need to be locked securely like lighting boxes or removable panels. All specified by one company of theatre architects who must have thought it was a reasonable idea.
Irascible
21 Apr 2020
Dyfneint
I always thought they grew out of flag signals, which are a very old idea - wiki says the idea of using arms dates from 1792 though.
mrcheek
11 Sep 2007
(road) traffic lights also inspired the idea of red and yellow cards in football, which has since spread to many other sports
Fawkes Cat
8 May 2017
I can't remember where I got this from, but I think that I've seen it argued that the joint stock company and limited liability were created to allow railway companies to exist (organisations too big to be funded by one person, however wealthy, and too risky to allow all the investors to lose everything should it fail). Limited companies seem to have taken on at least a little bit of use outside the railway industry.
