Trivia: What are the quirkiest railway stations in Britain?
DelW
15 Jan 2015
Following on from the above, are there any other stations that share Surbiton's quirk of having different numbers of up and down lines passing through?
The south-western mainline section of Clapham Junction has three up roads (platforms 7 8 & 10) and two down roads (9 & 11). Platform 8 isn't used for calls, but has lots of through trains.
Overall CLJ is more complicated to count because of depot tracks and Overground routes terminating there.
24 Mar 2019
The Canny Toon
Twickenham has two 'up' platforms and one down, although as that handles Kingston loop trains as well as the Reading and Windsor line services it could be considered half of an up platform.
Class15
30 Dec 2021
North London or Mildmay line
I would say that Bedford only has one down platform, Platform 4, down fast. The up fast has no platform, and Platforms 1-3 are all reversible and all three are used by terminating Thameslinks, calling up EMR services, and I think also freight services in both directions. This can get horribly tangled and can’t help thinking a simple four-track four-platform layout with a bay for some terminating Thameslink services would be operationally simpler. Maybe it will be improved for EWR. Or just made more complicated.
Also Platform 1A (the Bletchley bay) has a completely separate face from Platform 1.
I think we’re less looking for stations with terminating platforms, and rather stations which are fully through platforms. Good point about the Bletchley bay however. Stratford might be 1 of 2 then!
Maybe another example of the uneven platforms could be Northampton? Two down platforms, one up platform and an up non-platform track. There are also bays, but just counting through platforms…
BeijingDave
26 Jul 2019
Acton Bridge has three platform faces, although I can't remember if it's 2 on the up or 2 on the down.
BeijingDave
26 Jul 2019
If it was still in existence (or reinstated in full), Ditton, which was the first station to close post-privatisation.
5 platforms (giving it a bigger footprint than Runcorn, Widnes or Warrington Central - much more important nearby stations) but very sparse services.
norbitonflyer
24 Mar 2020
SW London
Lincoln has five through roads, with one platform on the eastbound and two on the west bound (although they are now all signalled bidirectionally). The two bays face the wrong way for most of the traffic now on offer ("up" was originally eastward, when London was reached via Boston or Grantham)
Purple Train
16 Jul 2022
Despond
Chathill deserves a mention. The only station in the UK where every calling train starts or terminates but they still have non stop through passenger trains. Also possibly the only mainline station in the UK to have a platform where you can only board and a platform where you can only alight.
Will the same be true of Aberdare when the new platform opens there?
aliceh
11 Oct 2019
Bournemouth
Not sure about school trains; I think its main use was to allow luggage and mail to be transferred to the other platforms without having to use the footbridge.
I think that was the original use, but when I was at Brockenhurst College in 2004-6, it was used fairly often for students arriving by train - although by no means every single morning. The footbridge and stairway to platform 1 & 2 (now replaced) was very narrow and steep, and not all that pleasant when you're in the crowd that just stepped off a 12-car train!
Parallel
9 Dec 2013
Depends perhaps what is meant by main line, but Neilston has two platforms, one for arrivals and one for departures.
Paignton has a platform where you can only alight from terminating trains, although the other platform allows both terminating and departing trains.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Hinchley Wood, Surrey has up and down platforms distant from each other as the tracks diverge to join the SWML at Hampton Court Junction. Epsom has pairs of up and down lines which cross at the London end, giving cross-platform interchange. Gomshall (now my local station) has a ramp and stairs footbridge whose bulk is possibly greater than the whole of the rest of the station!
TheRightTrack
Verified Rep - TheRightTrack
1 Oct 2024
Cambridgeshire
Kenilworth feels quite weird, a small, non gated station having 2 footbridges spanning a single track line, both serving exactly the same function at the moment, which is enabling non rail users to cross over! It's not as if the older footbridge is especially attractive or historic looking.
View attachment 175666View attachment 175667
This really is an interesting one! When did they put up the second bridge?
Topological
20 Feb 2023
Swansea
This caused me to google Hinchley Wood. It looks like a normal island platform from one end and then becomes a huge V. That is a large junction arrangement that has been constructed to join the SWML.
I cannot think there would be many stations like that where the diverging lines were not separate branches.
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
Nearby Raynes Park is of a similar layout, albeit with four platforms as opposed to two.
RailWonderer
25 Jul 2018
All around the network
Virginia Water and Pitsea have a similar V shaped layout and I'm sure Lewes as well.
Topological
20 Feb 2023
Swansea
Do they?
In both cases the lines genuinely diverge rather than both being to/from the same place.
Raynes park is definitely a case of two lines splitting.
Virigina Water has the split between the line towards Chertsey and the line towards Ascot.
So that leaves Hinchley Wood as still being unique because the dividing lines genuinely do go to/from the same place (the SWML)
RailWonderer
25 Jul 2018
Pitsea branches rejoin the main at Upminster and Barking so I think that one is valid.
Topological
20 Feb 2023
Swansea
That is pushing a bit, but good point. One route is slightly more direct than the other.
Before anyone says, Cheadle Hulme does not count because although Avanti have London Euston trains passing both platforms, there are many destinations that can only be reached from 1 of the 2 routes (e.g. the Marches line from Crewe requires taking the split towards Wilmslow)
Mikey C
11 Feb 2013
Kenilworth station reopened in 2018. The second footbridge provides lift access as well, which the older one doesn't. I assume they weren't able to adapt the older one to add lift access, and it was cheaper to leave it in place than remove it!
BeijingDave
26 Jul 2019
Manchester Piccadilly is fairly quirky. 12 terminus platforms and 2 incredibly busy through platforms.
Always seemed strange to me that it was decided that so many services would be concentrated through there, and Victoria half-demolished. In retrospect, an unwise decision, which has been unwound slightly now.
dtin
3 Nov 2019
Bristol
Polesworth, it only has one platform and trains only stop there heading north, I don't know how many services today but in the Silverlink/Central Trains days there was one London Euston to Crewe service that stopped there per day and nothing in the southbound direction.
frodshamfella
25 Sep 2010
Frodsham
2 Birmingham bound, 1 Liverpool bound.
I think Bromley North and Sundridge Park are quite quirky. Little short branch line in SE London. Haven't been to Bromley North for years and years, but I recall it had a big terminus feel, but mainly 2 carriage units operating. I thinking back to the early - mid 80s, don't know what it's like now.
Kite159
27 Jan 2014
West of Andover
I think Bromley North and Sundridge Park are quite quirky. Little short branch line in SE London. Have been to Bromley North for years and years, but I recall it had a big terminus feel, but mainly 2 carriage units operating. I thinking back to the early - mid 80s, don't know what it's like now.
Still got the big terminus feel but now with 4 coach trains.
Dr_Paul
3 Sep 2013
Following on from Kenilworth and its footbridges, the footbridge at Kew Gardens is unusual as it is external to the station, with the foot of the steps on both sides outwith the station buildings. There is also a subway, but one needs to go through the ticket barriers to gain access to it. I believe that the footbridge was one of the first examples of the use of concrete on such a structure; it is certainly unusual in appearance, I've not seen one quite like it elsewhere. At Twickenham, there is a footbridge that crosses the station without giving access to the platforms, connecting two roads, Mary's Terrace and Cole Park Road.
Akela
20 Jun 2021
Wales
Butetown station once it’s open will be slightly unique in that it’ll have a tram-style level crossing between platforms despite technically being a heavy rail station. Actually the whole branch line will be unique in that it’ll be a line built to heavy rail standards that’s operationally run as a line-of-sight tramway.
Acey
16 Nov 2018
Shout out for Elmstead Woods,surrounded by suburbia but has the feel of a country station,you can barely see another building from most of it's environs and of course the splendid gardens !
