TVM Block Marker Boards on the Elizabeth Line.
MOONY
15 Jan 2009
Apologies if this has been raised before. At the departure end of each Elizabeth Line station there is a TVM BMB but immediately in advance of it it there is another BMB annotated as "CA" which I presume to mean Co- actor.
Could some kind person explain the significance of this arrangement please?
Many thanks.
Moony
I would presume the CA marker block is there in case a driver has to drive their train through the core manually, to assist them with their stopping position. It does seem a bit of an anachronism, though, given that you are inherently talking about in-cab signalling which shouldn't require any sighting!
Bristol
Many thanks.
Moony
On a technical point, Crossrail doesn't use TVM but a Siemens CBTC system. Although yes the Block Markers are identical.
From the cab ride video, I would guess that the actual board is located at the place by which trains must stop, however because the board is mounted low down for clearance, a co-acting board is provided behind it so that drivers can see the Block Marker Number clearly.
Railsigns
15 Feb 2010
There's a photograph of a co-acting block marker on this webpage.
CBTC block marker number XR336 on the Crossrail Eastbound line at Custom House station. A smaller 'co-acting' block marker, numbered XR336CA, is provided a short distance beyond for the benefit of drivers of trains standing very close to the primary marker.
Bristol
Argh. Too many abbreviations!
Apologies:
TVM - Transmission Voie-Machine (French in-cab signalling, works through coded track circuits)
BMB - Block Marker Board (replaces signals for in-cab signalling)
CA - Co-acting (as stated)
CBTC - Communications Based Train Control (A technical subset of in-cab signalling over radio)
kevin_roche
26 Feb 2019
That is correct. The failure mode is to use ETCS with the driver manually controlling the train when CBTC is not working.
