Yeh maybe the river is an issue but I can't figure out why a lightweight platform extension can't be erected like has been put up at oxted and upper warlingham. a fella I spoke to the other day down there reckons it might be political and might be a way to justify a large budget for the works....
Location of new platforms
Horizontal track alignment through station platforms
2.1.1 Station platforms shall be located on straight track unless the particular geographical characteristics of the potential sites and the characteristics of the railway infrastructure at the proposed location of the platform do not provide a reasonable opportunity for achieving this.
2.1.2 Station platforms shall not be located on horizontal curves with radii less than 1000 m.
2.1.3 It is permitted for platform extensions to be located on horizontal curves with radii less than 1000 m but not less than 500 m.
2.1.4 Before station platforms are located on curved track, consideration shall be given to the following:
a) Train to platform stepping distances, taking the types of train likely to call at the platform into account.
b) Visibility (either direct, by means of CCTV screens, or by mirrors) along the length of trains for train crew and station staff responsible for dispatching trains.
http://www.rgsonline.co.uk/Railway_...re/Railway Group Standards/GIRT7016 Iss 5.pdf
http://uckfieldnews.com/railway-plat...field-station/
finally it seems things will start moving forward now.
Railway platform extension problem looks to be solved at Uckfield station
Network Rail looks to have found a solution to extending the Uckfield station platform.
It appears as if the construction work will be carried out using the existing platform as the route to the site.
The platform at Uckfield will be extended by about 48m
An official announcement from Network Rail is expected shortly.
The project ran into problems when Uckfield Town Council refused permission for a haul road to be put across part of Hempstead Meadows Local Nature Reserve.
An alternative plan using Mill Lane was likely to meet neighbour objections while use of Alexandra Road was ruled out.
A longer route, via the Bird-in-Eye industrial estate, was also considered.
The Uckfield Railway Line Parishes Committee has been told by Vicky Tilling, Network Rail project co-ordinator for improvements on the Uckfield Line, that construction plans had been reviewed.
A new but not untested design was proposed with access over the existing platform.
Completion target is next July
Prelimary work for extending platforms on the whole line is due to begin this month, with work beginning in September.
Completion is targeted for July next year.
Platforms are being extended along the line to allow ten-coach trains to operate.
The committee was also told at its May meeting that the 12 diesel coaches which had been moved to Southern for the Uckfield line from Scotland were in a worse condition, and refurbishment was taking longer, than expected.
It is expected that some services will be lengthened ahead of the platform work being completed.
Ms Tilling confirmed to the meeting that re-doubling the Uckfield Line to Hurst Green and electrification would be considered in the future.
In February, the UckfieldNews.com independent columnist, Observer, suggested Network Rail should look to its own resources for a solution to access the platform extension site. Observer wrote: First rule in my line of work is to use your own people and your own resources for anything that is likely to be tricky, awkward and difficult to deliver. We dont contract out if we sense rough going ahead. Read the whole article here
A report of the Uckfield Railway Line Parishes Committee meeting was given last night (July 7) to members of Uckfield Town Council Environment and Leisure Committee.
- See more at: http://uckfieldnews.com/railway-pla...ved-at-uckfield-station/#sthash.XQPhj46q.dpuf
Suggest they deliver the materials to site by rail or maybe they have not thought of that :roll:
It has taken NR a long time to think about something they have done elsewhere.-
Using the platform as a "haul route":roll:
Preliminary clearance work has already been undertaken at Eridge where undergrowth has been cleared and a temporary level crossing has been installed at the London end of the station.
Electrification:roll: Been talking about that for xxxxx years:roll:
Doubling the line:roll: Been talking about that since BR singled it in 1990:roll:
Latest information on this project is that to allow the platform works at Uckfield to be carried out the station will be closed to off-peak services for some months, and totally closed for 2 weeks. The works are apparently scheduled for the autumn although it has not been announced when.
This information has come to light because of the impact of the rail replacement buses on the High Street works that are also ongoing in Uckfield. More on the Uckfield news site linked by Physics above but I cant access the site currently to provide a link.
In the meantime there is a campaign to replace the rail bridge at Crowborough as it forms a bottleneck being a low height arch. There is a campaign to provide it with a full height bridge. There was a rumour that the paltforms at Crowoborough were to be extended over the bridge although as they are talking about moving the siding I assume they are going the other way. Replacing the bridge would potentially give the option to build a lift access to Platform 2 at the same time, therefore giving the station full disabled access. However not sure any of this will happen. There was a fatal accident recently near the bridge, it will be interesting to see if the dip under the bridge is held to be at fault in any way, although I suspect the predominat cause will be excessive speed.
Yeh I read about the impact on services, yesterday,and I really don't get why they need to have train s terminate at crowborough for two weeks???!!!! I can only guess that they are rebuilding the whole platform...which isn't in the greatest shape.
I also heard about the issue at crowborough with the siding but not about the bridge. I believe the whole project on the line only needs the movement of this siding and the signal at the country end of platform 1 at crowborough,the signal at Buxted and the signal at the London end of platform 1 at Hever, as 'major' issues.
The SOuthern Passenger Forum today has confirmed that the entire line will be closed for 2 periods likely to be around November and February.
I guess moving a siding may take longer than a day or weekend losure, as may moving some of the other kit that needs moving at Crowborough and if it is essential to running the service I assume there is no option but a closure.
But Southern and Network Rail PR on all of this is dreadful, they should be making announcements and seeking to lead rather than allowing information to leak like a sieve.
They said
"We have leased an additional 12 coaches for use on the Uckfield Line. These will be introduced during 2016. Network Rail is developing plans to extend the platforms on the line to take 10 coaches. It is planned that this work will be completed during 2016 but it will require the line to be closed at certain times in November and again in February to enable the work to be carried out. Plans for this work are being developed at the moment and full details will be available shortly."
People in Kent and East Sussex can find out more about a project to boost rail capacity and reduce crowding on the Uckfield line at a series of drop-in sessions organised by Network Rail.
The exciting new project will extend 12 station platforms between Edenbridge Town and Uckfield, allowing the introduction of 10 coach trains that will reduce crowding on the Uckfield line and help to meet growing passenger demand. The new longer trains will increase capacity on the line during the morning peak by 50%.
Network Rail will build the longer platforms and infrastructure, and Govia Thameslink Railway will lease, refurbish and run the trains.
Network Rail Project Manager, Craig Melhuish, said: By extending the platforms we will be able to run longer trains that will reduce congestion and improve the daily commute for thousands of people. Eight of the twelve platforms need to be doubled in length, which is a considerable amount of work when compared with many other platform extensions projects previously delivered on the network.
Network Rail will start setting up site compounds at some stations in early August 2015, and start preparation works later in the month. Permanent works will start in September at some sites and in the New Year for others. The stations will be completed on a staggered basis between February and July 2016.
The main impact is summarised below:
2 November 25 November 2015
Monday to Friday between 0920 and 1640 - The line will be closed between Hurst Green and Uckfield, with changes to last trains Monday to Thursday
4 January 20 February 2016
The line will be closed between Crowborough and Uckfield, all day.
14 March 9 April 2016
There will be weekend closures from Hurst Green to Uckfield at various points between August and May
Umm, Uckfield is at the end of the line. I suspect the people who would suffer most from the overcrowding (at least in the am peak) would be the people who get on the train nearer to London, not the people who live in Uckfield!
It is interesting that many of the platforms in the area used to be rather longer, including those at busy stations such as Edenbridge Town, which IIRC was almost twice as long as it is now. Of course, new platform layouts and equipment/staffing may well have to be modified because of dispatch sighting and risks, but it goes to show that it certainly was done in days of yore, before the line (shall we say) slumbered under the latter reign of BR and others.
update: Edenbridge Town and Cowden now have those barriers/fences (blue piping) up where the platform extension work is due to take place.
Baring Buxted and Uckfield, there has been some clearing work done at all stations and it looks like Hever is having signal relocation work taking place as we speak.
Works well underway at Edenbridge, foundations being dug etc, diggers at Cowden where they have cleared the site, and Crowborough where it doesnt appear to have been out working yet.
its interesting seeing the changes on a day by day basis. Unfortuately iam off for two weeks!
Well I hope you have left us with enough drivers!
Have a good break
