Hi
I'm looking to travel from University [Birmingham] to Swindon on Saturday 7th March.
I was going to use an off-peak return, departing at 1436, arriving at 1627 - changing at both Cheltenham Spa and Bristol Parkway. I am wanting to travel on these specific trains but getting an advance on this service would be £26.70 with a 16-25 railcard.
The off peak return is £28.65 and is specified "2V, NOT VIA LONDON" (fare set by Cross Country). However, on NRE, for the return options, there is a blank space for the routes via Bristol Parkway, and you can only select the route via Kemble (which is a bit more awkward for my timings).
Is going via Bristol Parkway not valid for some reason on the off-peak return? It is obviously a permitted route normally, so I don't know why NRE thinks that you cannot use a return this way. Londonmidland's site also does this.
Thank you,
Adam
Thank you,
Adam
