Chairs mounted on them to support the rails possibly in an engine shed.
Or where there was an inspection pit between the rails.
It’s the Great Central Gotham branch, parts of it are now a footpath.
Can you provide a map reference?
Far too closely spaced for that function. Point rod supports are/were between 6-10ft apart depending on straightness of run, signal wires 15-20 ft on straight runs. And I've only seen them attached to posts buried in the ground or for signal wires wood or metal stakes driven into the ground.Could they have been supports for rollers carrying either signal wires or point rodding?
OS maps and the aerial vew certainly seem to show it on the route of an old railway, and "Railmaps on line" show it is part of the Gotham branch of the GCR that led to the Weldon Gypsum Mine, but it also shows another un-named line that crossed the Branch at roughly that point.
http://www.RailMapOnline.com/UKIEMap.php?lat=52.86459&lng=-1.20681&zoom=15
If they were stone sleepers where is the other parallel set?
How far apart are the studs in them?
How big are they?
Always a tip if photographing something to be identified is to put a ruler or something that is a fairly well known size by them, so that some idea of scale can be seen.
If this link works it should lead to a large scale historic map alongside a current map.
http://maps.nls.uk/geo/explore/side...=52.8665&lon=-1.2100&layers=168&right=BingHyb
I can't see anything at the reference you quote, but there are other features that might be quarry railways intersecting with the standard gauge railway both further north and further south.
Perhaps the foundations for some kind of conveyor? For this the fixings on each block would be (I guess) about half a metre apart.
If you use the above link but change the map date to "OS Six Inch, 1888 - 1913" it shows the Gotham Branch. The modern Gypsum Way follows much of the route.
Are you thinking of "Britain from Above"? My delving brought up https://britainfromabove.org.uk/en/search?keywords=Gotham&country=global&year=all which showed some 10 photos, 8 of which were of Rushcliffe golf course and did not show anything of the branch line in question. (Warning: Internet Explorer users may not be able to view the large images for some obscure technical reason!)Isn't there a library of Aerofilms which might show stuff not on maps?
Panning my "OS 25 inch 1892-1914" northwards the standard gauge track ends near the area you mention but the trackbed continues to a "Plaster Mill". I suppose it's remotely possible the gypsum was unloaded here and taken by conveyor to the mill (or conveyors could have brought it from the mine further south or to a railhead from the mines further north). The existence of the trackbed suggests the track went all the way to the mill at one stage but confusingly it also continues on the 1937-61 mapping so it's possible it was taken out for a period and put back later.That’s right it’s parallel to it, it doesn’t really go over the track bed very much. Gypsum Way was built when the DSG plant was put into Ratcliffe power station. In the end most of the gypsum went by rail to East Leake Gypsum works (by Rushcliffe Halt). Parts of the trackbed is now a footpath called the Logan trail. The part where these artefacts are has recently been cleared and opened accessed off Gypsum Way or Pygall Avenue.
I don't think there would have been chairs bolted to these, because when salvaged the square nuts would have been taken away with the scrap chairs or just dropped around rather than being re-threaded onto the studding. I've seen concrete sleepers with bullhead chairs dating from around WW2, but always single pieces rather than twin-block.They are twin block sleepers connected together to maintain gauge by a steel bar cast within each. Current concrete sleepers being a single mono block supporting both rails. I suspect if you excavated down between the blocks you would find the bar. Bull head rail chairs would be bolted onto each block using the cast in studs. I believe they were quite common after WW2 when resources were scarce. There would be little scrap value in the concrete block but the chairs would be, hence why none remain.
There was the big army depot just up the line in Ruddington (now the country park and the base for the GCR(N) heritage operation) but I'm not aware of anything at this site. If there was then it wouldn't have been on any of the OS maps we have been looking at! It may have been a wartime expansion perhaps - was gypsum a strategically important material?Don't forget these twin blocks will be a bit older than those on the metrolink.
I think a guesstimate date period would be WW2 as the Railway operating dept of the Army used these style of sleepers extensively.
Is there any known Military History near this site, in particular storage depots?
