You haven’t been paying attention then. The front dispatcher will use the flag outside the drivers window.As a regular traveller through Haywards Heath (and seated on the platform side of carriage one), I haven't seen a green flag used by platform staff (though they usually chat to the driver)
That's a Southern thing: the dispatcher has to show the bat and flag to the driver through the cab window, whereas (as posted upthread) GWR dispatchers at Slough can do so by making sure they're visible in the DOO monitors in the cab.This is why I asked the question I found it intriguing given that he was stood right next to the driver.
Not on the mainline - at least that I know of - stop markers appear to have solved that problem. It’s still regularly used on heritage railways, of course, though.Thinking back to the 1980's at Settle station. The train (loco hauled) was too short for the platform, so drew up slowly under hand signals from the station man/woman. Hand outstretched and revolving to move up, both hands above heads to stop. Guard remained in his van. Once all station work was done, the guard blew his whistle, then showed a green flag or green bardic to give 'right away'
Is that still a current procedure?
But then you read the sectional appendix and it can become confusing.Green flags are only ever used to enable drivers to pass over a level crossing in handsignalling. Yellow flags are used in all other circumstances.
To quote from the RSSB's "Signals, Handsignals, Indicators and Signs":
- A red flag during daylight or a red light during darkness or poor visibility means ‘STOP’.
- A yellow flag during daylight or a yellow light during darkness or poor visibility is used when giving authority to pass a signal at danger.
- A green flag during daylight or a green light during darkness or poor visibility is used to give authority to pass over a level crossing.
They do, and also used with permission from Control during a complete bell buzzer failure on other stock. I had such an event on a 156 all the way from Stockport to Chester, it was quite fun to dispatch I have to admit, obviously got to be extra alert though!Guards on railtours use them quite often. Just go to your local station next time one stops there and you might see one in use.
From memory: Regulation 5 - Warning Acceptance (line clear to Home Signal of next box but overlap obstructed). Only where authorised and where a fixed subsidiary signal is not provided for the purpose.Green flags were used by a signalman to indicate to a driver that he could proceed after having been stopped by a red flag at a signal box for some reason..
I have a feeling it has been used in lieu of a Calling-on subsidiary as well somewhere.
